Basically:
2 screws hold the MAF to the air box, undo those with a philips
2 more 10mm hex bolts bolt the box to the car - undo those,
Pull the box back and out of the loop thing on the fender side - nothing holds it there cept force - just pull it cant break anything.
Next, jack the car up and remove the drivers wheel, undo the fender liner.
Look for how the rest of the airbox tubing is attached and remove it - i forget exactly.
Loosely attach the main pipe to the maf with the couplers supplied, then put the cone filter on so its right in front of the wheel. Tighten everything back up and test the car...
Just so you know - puddles will cause water to be sucked up into the motor - which can result in hydrolock... Be careful!
Short rams work well and even better in most cases.
