VWVortex.com - stage 2 unitronic
    Results 1 to 14 of 14
    Thread: stage 2 unitronic
    1. 08-19-2012 09:10 PM #1
      ive been doing some reaserch on unitronics stage 2 chip. my car is already set up for the chip having a 3" neuspeed dp and catback, forge 007 dv, cold air intake and fmic. there site says it will be running 20 psi. will i need to change anything else to support this? ive heard people say they needed to change their coil packs. and will it cause damage or break any of the axles or driveshaft.
      if theres anything else i need or should have to run this let me know.
      thanks
    2. 08-20-2012 11:51 AM #2
      Can anyone help?
    3. Member Nolig23's Avatar
      Apr 22nd, 2005
      Stockholm, Sweden
      pedestrian status
      08-20-2012 12:01 PM #3
      only things i changed when i went stage 2 were sparkplugs (ngk bkr7e) and yellow spring for the forge dv.
    4. Member JrJanowski's Avatar
      Sep 11th, 2011
      Plano, TX
      05 GTI 1.8t - Sold. AP1 S2000
      08-20-2012 12:01 PM #4
      Im getting unitronic stage 2 tune september 1st and have a 3in turbo back, sri, apr r1 dv and was planning on running a fmic but i heard even with this tune it will cause a lag and you will lose psi. so fmic is actually hurting your performance and that a upgraded smic would be the best fit.
      That and i heard a turbo inlet hose is a good thing to change so i bought that, ive got brand new coil packs and i heard spark plugs need to be changed to .032 gap instead of .028 and oil switched to castrol syntec 5w40.. at least that what they told my friend with revo stage 2
      MY GTI BUILD/Instagram: JrJanowski<--Do It
    5. Member cubano717's Avatar
      Aug 6th, 2010
      York, PA
      2003 silverstone gti
      08-20-2012 12:06 PM #5
      have stage II unitronic with stock coilpacks, stock spark plugs, 007 dv with yellow spring, 3" turbo back and stock side mount intercooler, runs awesome
    6. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      08-20-2012 01:41 PM #6
      Quote Originally Posted by autoc-o1 View Post
      thanks
      you dont need to change anything but your spark plugs to ngk bkr7e. yo might need a stiffer dv spring as well, but prob not with the 007.
      Quote Originally Posted by Nolig23 View Post
      Quote Originally Posted by Jrx45x View Post
      you lose psi if you put a giant fmic meant for a big turbo car on your tiny k03. geta properly sized fmic kit and you will not have to worrk about it. i saw 0 pressure loss like many others
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    7. Member JrJanowski's Avatar
      Sep 11th, 2011
      Plano, TX
      08-20-2012 02:07 PM #7
      whats a good fmic?
    8. Member mKsTurbo's Avatar
      Mar 26th, 2009
      Montreal
      VW Turbo
      08-20-2012 03:12 PM #8
      been running stage 2+ uni for the passed 2 years with a k04 .. had zero problems with it and only thing i changed was a inlet pipe and thats bout it ( i have a 3 TBE - TT injecs - TT exah mani - 3 CAI - FMIC - Forge DV )
      MK4 Jetta 1.8 K04 - Summer
      MK5 Jetta 2.0 TDI - Daily
    9. Member JrJanowski's Avatar
      Sep 11th, 2011
      Plano, TX
      08-20-2012 03:36 PM #9
      is it really essential that i get ngk bkr7e plugs since im going unitronic stage 2? I will purchase them now if its actually beneficial but i replaced my plugs about 8 months ago
    10. 08-20-2012 05:23 PM #10
      I recently bought denso iridium plugs. Would those be fine?
    11. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      08-20-2012 06:36 PM #11
      it's the recommeded heat range for chipped cars. .028" gap. look in the FAQ in the 1.8t engine forum for spark plug info. I get my sets from advance autoparts for 8.24 a set, they are cheap i ran them on stock turbo and run them on big turbo, never had a problem
    12. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      08-20-2012 06:38 PM #12
      whats a good fmic?
      there are tons of good ones. eurojet, cts, pwrhaus, eurosport, etc. mine is custom tho, and cost way less than all of those
    13. 09-04-2012 05:27 PM #13
      will the stage 2 chip cause my turbo more stress/shorter life span?
    14. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      09-04-2012 05:32 PM #14
      ^^^ lol, just get the chip that or stop asking silly questions and read the FAQ
