Results 1 to 4 of 4
Thread: Light flywheel and crank pulleys
  1. Member 1fast2liter's Avatar
    Apr 3rd, 2005
    beaver dam WI
    2000 audi tt 180q
    08-19-2012 10:20 PM #1
    I have ran both in some other cars in the past. Do our cars react differently to a lighter crank pully and flywheel? I know subies if you run a lighter flywheel you need to run the lighter crank to. So are we externally balanced or internal... thanks
    Sent from my Motorola Electrify using Tapatalk 2
    infinity front,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, modded 225 exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,
  2. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    08-20-2012 02:32 AM #2
    no experience but ECS said they pulleys increase response however removing the harmonic balancer crank pulley causes increased engine vibrations
    he didnt mention that there not good for your bearings, but i asked along time ago too on here and a guy posted his cracked seal and blown engine from the lighter pulleys
    the usual answer to this buy it if this is only left of things to add. otherwise spend elsewhere
    only had a flywheel experience in a e36 and it was very responsive, went out only only a year and a half later though
    id buy a fluid dampr and light weight alternator, steering a/c pulleys if i was you, no flywheel
    more reliable and responsive
    2001 Audi TT Quattro 225 - 1400 watt kicker sound system, dynamatted, foamed frame, carpet jute adhesion, duralined trunk - APR stage 1, TIP, TFSI coils, WG spring mod, EVO9 DV, Tru-Boost, UEGO.
    Theres never an eternal gratification when it comes to making your car faster.
  3. Member 1fast2liter's Avatar
    Apr 3rd, 2005
    beaver dam WI
    2000 audi tt 180q
    08-20-2012 03:47 AM #3
    Were do i get a fluid damper from? Never herd of that. Ive used lighter flywheel s in the past with good results. Just not sure what our cars can take
  4. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    08-20-2012 11:36 AM #4
    Lighter is more or less seen as ok, but don't get underdrive pulleys. I'm going to get a Fluidampr to go with the LWFW (help weight and vibration), but will otherwise skip fancy pulleys
