    Results 1 to 6 of 6
    Thread: I hate feelers, but... I've got a sweet rabbit I wanna turn into a vanagon.
    1. Member Rusty Shackelford's Avatar
      Jan 3rd, 2004
      Colorado
      08-19-2012 11:07 PM #1
      I've got a rust free 84 Rabbit GTI with a low mileage AEB 20v swap, p&p AEB head, running as an AWP on a fully loaded APR ECM
      K03s
      Remote oil cooler
      TT manifold with VR6 flange/TB
      MK5 intercooler
      Mk3 radiator/fan on custom support/bar
      3" DP and full 3" exhaust Magnaflow
      Spec2 clutch, pp and flywheel
      02j swap with VR gears and a Quaife
      mk3 2.0 knuckles w g60 brakes
      Mk4 aluminum rear caliper swap
      5 lug
      New poly
      Stitched control arms
      Neuspeed rear sway
      Eurosport front/rear tie bars and lower front bar.
      KW V1 coilovers
      Optima gel batt in spare well
      Mk4 tilt/tele steering column
      Mk4 pedal cluster, TT pedal pads
      Mk4 strut tops welded in to use mk4 bush/bearings.
      Full mk4 wiring head to tail
      Mk4 GLI steering wheel
      Mk4 GLI cluster
      New bosch fuel pump
      Most all sensors and coolant plastics new.
      Rounds w German glass crosshairs.
      Euro bumpers
      Probably a whole lot more I'm missing and most everything has less than 7k, suspension has less than 1k.
      The car is sport bike quick, and is pretty much a racecar minus the cage. I would not hesitate to drive it anywhere though.
      Make offer, trade me a vanagon and cash. Point and laugh...
    2. Member SCIROCCO SPEED's Avatar
      Dec 6th, 2002
      Colorado
      73 Superbeetle, 86 Golf (RIP), 88 Scirocco 16v, 93 Corrado SLC, 07 GTI, 04 Jeep GC 4.0L, Cannondale
      08-20-2012 02:52 PM #2
      Wow! All of a sudden i find myself wishing I had a vanagon.
      GLWS
      Engineers do it better.
    3. Member Abtitude's Avatar
      Jan 4th, 2003
      Arvada,CO
      mk3vrt mk4 jettavariant b6s4
      08-21-2012 11:37 AM #3
      i Like it.
    4. 09-01-2012 08:12 PM #4
      I have got Vanagons, about 20 of them. I might be interested in a trade. What do you think the Rabbit is worth on the open market?
    5. Member Rusty Shackelford's Avatar
      Jan 3rd, 2004
      Colorado
      09-02-2012 08:31 PM #5
      No clue what it's worth on the open market. I know what I have in it and I have an idea what it's worth parted. Unfortunately, that's probably what will happen to it if I can't find a good vanny to swap for. I'll just part it and stick it in the garage for an awd swap later.
      Ideally, I'd like to build a syncro, but... We will see what pops up.
    6. 09-03-2012 10:23 PM #6
      Well, I have a couple Syncro vans. let's PM this thing.
