You can mount a pressure switch pretty anywhere before the actual valves or valve block. As long as it's reading pressure from the tank itself, then it's fine. That's all it's doing is turning on and off the compressor based on tank pressure.
The only thing I can think that would cause a problem with putting on the bottom of the tank is the moisture from the tank getting into it and causing it to fail prematurely.
