WHICH one boyo....they're not all the same size.
Was this the allen head from the hinge?
#1
Anyone know the thread pitch and bolt size for an 81 S? I dropped one inside the door panel and cannot find it.
I see on a door sag thread that someone is saying 8mm, but that seems too big, but also doesn't indicate the thread pitch.
Thanks.
#2
The feeling of immortality extends right up until the moment of impact.
I cannot teach you how to be a Zen mechanic, grasshopper.
The VW Scirocco, the worlds fastest ECONOMY car.
#3
It is the top left allen head bolt on drivers door. It holds the hinge into the frame side. There are 4 of those on each door (two on top hinge and two on the bottom) and it looks like at least those are all the same.
#4
M8 x 1.25 pitch, 20mm long, and they are all the same size on a mk1. 4 per door.
#6
You adjust the door sag..somewhat from the hinge point.
The keeper pin on the door jamb is your alignment point.
Interestingly...I worked at a car plant for a number of years....you should see the guys 'adjusting the doors'.
They BEND THEM!
They Smack them with hammers!
They twist them!
I hurts to watch...but that's FACTORY!![]()
#7
I would try thatbut since the lower hinge mount is a little bit torn from the frame I think it is a bad move. I have a friend with some welding experience. I may go that route after the manual adjustment. Even with one bolt right now on the top hinge it is adjusted far better so there is hope..
#8
Maybe the torn hinge is an indication of the issue, has it been twisted out of alignment? Make sure your pins/bushings are good.
Old sciroccos never die....they just go faster....sometimes.......
www.ziggituning.com
My Project...
