Yes, A1 firewalls are different for factory AC cars. Just leave the factory box is the easiest. You can make an adapter plate for the heat only box...
Chopping the old AC box up wont really help. they are completely different and its not like you could cut the top off of it and use it as an adapter.
Why do you feel the need to remove the AC box anyway? If you want to reduce weight you can just take the AC evaporator out...
