VWVortex.com - DSG service: before or after track day
    Results 1 to 3 of 3
    Thread: DSG service: before or after track day
    1. Member dav1d's Avatar
      Mar 27th, 2011
      MK6 GTI 2D CW DSG
      08-20-2012 07:34 PM #1
      I'm planning to track my car in 2 weeks at Fastivus and I am at 38,000 miles right now and due for an oil change. My question is, should I do my oil change and/or DSG service before or after the track day. I also have a rev D diverter valve waiting to go into my car, should that be changed before tracking as well or is it nothing to worry about? Obviously money is tight, so what should I do now or can I put things off?
      H&R cup kit - H&R 24mm RSB - APR Stage 1 - oem mud flaps - misc vag work - magnaflow cbe - neuspeed pflo (red) - piaa ion crystal fogs - piaa wedge bulbs - clear side markers - euro switch - alpine amp + lc2i
      Jul 31st, 2007
      Western CT
      2002 VW Jetta 2.0 (gone), 92 GTI 8v (project), '16 Chevy Colorado Z71
      08-20-2012 07:41 PM #2
      Money is tight but you're tracking your dd?
      Definitely do your services before the track day. Tracking your car is one of the most stressful conditions you can put your car through. Oil change before and after. It would be a good idea to change your brake fluid also.
      Sent from my HTC Glacier using Tapatalk 2
      Nov 14th, 2011
      Toronto, Canada
      2016 Golf R + Tech Pack
      08-21-2012 02:31 PM #3
      Before would probably be a good idea. this way you have fresh fluid in there to properly lubricate everything and keep the parts running a little cooler under the high stress you will be putting it under.
