Results 1 to 6 of 6
Thread: Missing a bracket in diesel engine bay... Gurus chime in?
  1. Member therichisgood's Avatar
    Mar 7th, 2004
    Vancouver, BC
    1982 Jetta diesel
    08-20-2012 10:07 PM #1
    I posted before about having this random switch in the engine bay and it turns out that it's supposed to be attached to a bracket like in this picture (front of the pump holding the throttle cable):
    What bracket is this? What engines/cars did they come on? The bracket on my 82 looks different and doesn't have a place for the switch. I'm trying to un-ghetto the car as much as possible and this is one of the last things left.
    *edit*
    And this is the switch that's just hanging out in the bay that's otherwise supposed to be on that bracket.
    Jul 21st, 2002
    Boise, ID
    2004 Flash Green V70R
    08-20-2012 10:11 PM #2
    they are the switches for the upshift light controller...
  3. Member therichisgood's Avatar
    Mar 7th, 2004
    Vancouver, BC
    1982 Jetta diesel
    08-20-2012 10:22 PM #3
    I know what the switch is and what it does, I need to know what motor that bracket comes on so I can put it all how it's supposed to be.
  4. Member Iroczgirl's Avatar
    Feb 17th, 2007
    Bend, OR
    '55 Ford 351C, '80 Rabbit AAZ
    08-20-2012 10:31 PM #4
    You should be able to steal that bracket from any diesel Mk2.
    Jun 18th, 2010
    sacramento,ca
    1982 vw truck diesel, 79 rabbit 2 door diesel
    08-20-2012 10:47 PM #5
    all i can tell you is one came on my 85 turbo diesel jetta.
    and the bracket is actually 2 pieces. the main part on the right which has a couple holes so that the smaller l bracket on the left can slide in and pin itself in one, then be bolted to the pump and stay put in the other.
  6. Member therichisgood's Avatar
    Mar 7th, 2004
    Vancouver, BC
    1982 Jetta diesel
    08-20-2012 11:16 PM #6
    Great, thanks guys. Looks like I'll be posting up in the classifieds!
