Results 1 to 9 of 9
Thread: Wheel and spacer question... Who thinks they can answer this.
  1. 08-20-2012 10:34 PM #1
    I have a mk4 Jetta and I want to put wheels that are 17x9 with a -12 mm offset, I kno I will need adapters but what size? I want the wheels to poke a little and I'll be doing a medium stretch with the tires.
    Please be serious because it's important and yes I have done research and went through the archives.
    Can't seem to find anything on making negative offsets fit
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    08-20-2012 10:58 PM #2
    not serious... but I'd say... probably at least a 60mm spacer is needed, if not more.
    Not a great way to stress your bearings.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  3. Member Airy32's Avatar
    Nov 14th, 2007
    NC
    MkIV R
    08-21-2012 12:02 PM #3
    You'll need negative mm adapters. But you need to time travel to order them.
  4. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    08-21-2012 07:25 PM #4
    Quote Originally Posted by Airy32 View Post
    Best answer ever.
    For the first reply in this thread, no, 60mm will not work, because then the offset will be -72. Not gonna work. Negative offset and MK4 cars do not go together...
    I can't find the picture to describe what this looks like, but your wheels will have some serious poke. I mean like a Jeep Wrangler.
  5. 08-21-2012 08:42 PM #5
    I photoshopped this but. This is what I want to do
  6. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    08-21-2012 09:42 PM #6
    not gonna work in any sort of way at all
  7. 08-22-2012 01:06 AM #7
    Ok how about 19x8 +32 what size adapters for a little poke and what size tire to use that will give a nice stretch
  8. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    08-22-2012 09:38 PM #8
    you need an offset higher than like 40 for adapters on a mk4 on a 8 wide wheel
  9. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    08-22-2012 11:03 PM #9
    15mm in the front for 19x8 et17 will sit just about perfectly flush in the front (you'll be using 215/35/35) and 20mm for the rear, since you said you wanted a little poke.
