Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 125
Thread: Shankys_14's Air Build
  1. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 01:20 AM #1
    Let me start off by introducing my self. My name is Shank, I have a MkVI GTI. (Some of you might be following my build in the MK6 section but this is a little different.) Plans are to bag it within the next year hopefully by spring. Point of this thread is to ask questions. Get tips and help. Share my air build with all of you. Meet some cool people (I've met a lot in the MK6 section). And just your normal Vortex Whoring/BSing. Misha will be doing my install. If anyone is interested here's my other thread. CLICK!!
    Air Build:
    Accuair E-Level
    Air Lift Performance Series Front Struts
    Air Lift Double Bellow Rear Kit
    Accuair VU4 4 Corner Manifold
    Dual Viair 444C
    Koni Sport Shocks
    SMC Water Traps 1/4"
    Accuair 5 Gallon tank
    EXTA Power Supply
    What I have so far:
    Accuair E-level
    Accuair VU4
    Dual Viair 444C
    Koni Sport Shocks
    EXTA Power Supply
    Bought and Sold
    D-Cups
    Air Lift Slam Series XL
    SS-5
    Here's a pic of my car.
    And a bad Photoshop of what it will look like.
    2011 Candy White GTI 4DR l OEM+ l ORT
    Bout dat life
  2. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    08-21-2012 02:32 AM #2
    Misha does an excellent install
    @gtijoey
  3. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    08-21-2012 09:44 AM #3
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  4. Member llllllll vr6 lllllll's Avatar
    Jul 10th, 2008
    Winchestertinfieldville
    2 MK6's. One with switches
    08-21-2012 11:03 AM #4
    Out of curiousity is there any reason why you're going with e-level over v2?
    BAG RIDERS
  5. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-21-2012 11:18 AM #5
    Same exact setup I have except e-level for switchspeed, youll enjoy it!
  6. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 11:41 AM #6
    Quote Originally Posted by choey View Post
    I've heard nothing but good things about him.
    Quote Originally Posted by Will@BagRiders View Post
    Quote Originally Posted by llllllll vr6 lllllll View Post
    I want a height based system, compared to pressure based. Mainly because of the fact that I take Family/friends places in my car often. I won't have to worry about changing pressures. Also I'm a sucker for small nick nacks, and the key fob thing is pretty neat.
    Quote Originally Posted by 98DUB View Post
    Thanks.
    Bout dat life
  7. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 11:47 AM #7
    So my first question to my build.
    Can anyone help me decide on port size. I understand if I get 3/8 port on the bag get 3/8 npt to 3/8 pts fitting. But if I get 1/2 port on the bag then get 1/2 npt to 3/8 ptc. So what size port would be better? What are you guys running? I'm leaning towards 3/8 ptc x 1/2 npt? Any help is appreciated.
    Bout dat life
  8. Member OVRWRKD's Avatar
    Jul 1st, 2010
    Toms River, NJ
    08 CW GTI
    08-21-2012 11:59 AM #8
    I've never dealt with anything but the 1/2" bungs on the SS-5 bags. If 3/8" is available those would be great. A 3/8" NPT to 3/8" PTC is smaller and will give you a little better clearance in the lower control arm. The way the bags install with the d-cups the fitting is on the bottom. Like the setup plan, and Misha does great installs...sometimes calls me for elevel sensors
  9. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-21-2012 12:05 PM #9
    Quote Originally Posted by shankys_14 View Post
    It should make zero difference between the two setups. The only thing that will differ is the actual size of the fitting you are screwing into the bag, how tall it is and how far it extends from the surface of the bag. There is no performance difference and no speed difference.
  10. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-21-2012 12:13 PM #10
    3/8 is What i went with, its not to fast at all.
  11. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 12:50 PM #11
    Quote Originally Posted by OVRWRKD View Post
    Quote Originally Posted by MechEngg View Post
    Cool, thanks for the advice guys. With E-level it uses 3/8 air line. So when I order the front strut I'm gonna choose 3/8. I think I'm gonna go with these fittings. With 3/8 PTC x 1/2 NPT for the SS-5. Should that be good? Also when I order my Water Trap I should go with 3/8 then correct? Sorry for all the noobish questions.
    Bout dat life
  12. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    coal powered torque monster.
    08-21-2012 01:03 PM #12
    For the SS-5's, I prefer the Alkon Brass DOT swivel elbows as they hold up better to the elements.
    As for the water trap, it's going to depend on which trap you choose as different traps have different NPT sizes. If you get a 1/4" trap, you'll need 1/4" NPT fittings. Then again, what fittings you select is going to be dependent upon the placement of your water trap.
  13. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 01:27 PM #13
    Quote Originally Posted by Andrew@ORT View Post
    The more answers the betters. I've heard good things about the Alkon Brass Fittings too! My installer actually recommend those. I'm going to get 2 of the SMC Water Traps. So if I understand correctly, the water trap if I choose 3/8 port size. Then the elbow fitting I should get is 3/8 PTC x 3/8 NPT. And if I get 1/2 port on the trap. Get the fitting for 3/8 PTC x 1/2 NPT?
    Bout dat life
  14. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    08-21-2012 01:42 PM #14
    Correct!
    How do you plan on integrating them into your system?
    Compressor -> Trap -> Tank or Tank -> Trap -> Manifold?
    That's the only thing that will determine which fittings you select with your water trap. But to answer your question, you are correct 3/8" x 1/2" NPT PTC if you do the 1/2" trap.
  15. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 01:46 PM #15
    Correct!
    Hmm good question. I honestly don't know I'll have to ask my installer I think it was Tank -> Trap -> Manifold. Is there any advantages or disadvantages to either? But thanks for clearing that up for me.
    Bout dat life
  16. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-21-2012 01:50 PM #16
    If youre running one trap then you should go (compressor > tank > trap > manifold). Two traps you should go (compressor > trap > tank > trap > manifold).
    The more traps the better, just taking the moisture out of the air. You dont want in moisture in your mainfold. I little moisture in the tank wont kill ya, and you can empty it.
  17. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    08-21-2012 01:53 PM #17
    If you actually take the time to break down the science behind the compressor and water trap, you'll find that putting the trap after the compressor serves almost no function. The air that the compressor generates is very hot and actually doesn't contain much moisture at all. If you wanted to use the water trap to it's fullest potential, you would actually need to chill the air coming out of the compressor before it hit the trap. In addition to that, seeing as that 90% of the tanks on the market today are aluminum and have a bottom facing drain port, the chance of an explosion is far less. We always suggest running the trap between the manifold and the tank. This way, you can either connect it directly to the tank or run it inline with two PTC fittings.
  18. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 02:04 PM #18
    I'll be running two traps and dual compressors. So I will probably do the second route.
    Thanks so much for answering all my questions Andrew.
    Bout dat life
  19. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    08-21-2012 02:11 PM #19
    No problem
  20. Member ripNdip's Avatar
    Aug 6th, 2010
    McLean,VA/Aiken,SC
    Bagged MKVI Jetta
    08-21-2012 05:55 PM #20
    your going to want to get adjustable endlinks. i have the ksports but there is also the powergrids.
  21. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    08-21-2012 09:02 PM #21
    When I was running two traps why did my first trap always fill with water and my second trap didn't produce more than two drops of water in a 2 month time period?
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  22. Member shankys_14's Avatar
    May 25th, 2011
    North Jersey
    2011 GTI
    08-21-2012 11:03 PM #22
    Quote Originally Posted by ripNdip View Post
    I'll look into them.
    Bout dat life
  23. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    lada 2101,rx7,bmw 318i,87 golf gt,93 1.8t two tone,01 flat blue mk4,02 gti 1.8t. 1JZ e21 in works
    08-22-2012 01:58 AM #23
    science not always right, from my experience i see way more moisture collected by water traps before tank than past the tank.
    that why when ppl give me 2 traps i install both of them before the tank with airline between them.
    if you look at the trap design the air actually travels trough the filter,by doing so it is removing the moisture from air that was compressed by the piston.
    IMG_3619 by misha/rat4life, on Flickr
    Complete air ride installs,frame notching,welding, in north jersey.
    http://www.flickr.com/photos/rat4life/
    roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
    follow me on instagram RAT4LIFE
  24. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    08-22-2012 09:25 AM #24
    Science isn't always right, and every situation is different. In most cases, if you put them between the tank and the manifold AND you run a drain, you've got two methods of removing moisture. Either way works.
  25. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-22-2012 11:12 AM #25
    I am running 3 water traps
    Compressors -> Water trap 1 -> Buffer tank -> Water trap 2 -> Main Tank -> Water trap 3 -> Manifold
    Water trap 1 = 1/2 full per month
    Buffer tank = about the same amount of water as water trap 1 per month
    Water trap 2 = dry
    Main tank = dry
    Water trap 3 = dry
    There are explanations for using traps at both places and why it happens like it does.
    Compressor -> water trap -> tank
    The first water trap does help to seperate water from the air. Because the compressed air is beyond the saturation point it quite easily drops some of the air from having the air directed against a solid surface. If you don't know why this happens, if you take a look through inside the water trap inlet, you will notice that as the air enters, there is a surface perpendicular to the flow of the air, this makes the air directly hit the surface. Since the water particles in the air are heavier than the air, their momentum is different. The difference in momentum is what helps to seperate the water in the first water trap. Of course this only works to get rid of the water that is present above the saturation point of the air. That is why you get water in the first trap.
    In the tank right after the initial water trap (99% of people's main tank), there is air currently in there. This air is at ambient temperature, and thus quite a bit cooler in temperature than the hot air coming from the compressors through the water trap. So what happens is that the hot saturated air (no extra water at this point because of the first water trap) gets pushed through the air line and then into the large reservoir of cool air. This instant mixing of the temperatures causes a drastic cooling of the hot air coming in, causing it to condensate almost immediately. This is what causes the water to form on the bottom of the tank.
    The water trap after the main tank, in between the tank and the manifold, is mainly used for physical particle separation so that nothing gets into your manifold. The only way it will start to collect water is if you only run a trap after the tank and the compressors are running for a long enough time so that the ambient temperature of the main tank rises to an ineffective level and can no longer cause the hot air to condensate.
    Tank -> Water trap -> Manifold
    In this case the saturated air enters directly into the tank and will experience an almost full condensation. The temperature difference however might not cause a full full condensation effect and a tiny bit of water may be left in the air still. This will collect in the water trap, as well as the trap acting as a particle separator. The particles include aluminum oxides and rust, depending on what tank you have as well as tiny bits of teflon tape if you used the tape instead of paste.
    So from this if you only have the budget for 1 water trap i would place it AFTER THE TANK, just so you are guaranteed physical particle barrier and nothing gets into the manifold. Your tank will just get a bit more water in it and need to be emptied more often.
  26. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    08-22-2012 12:05 PM #26
    I run my trap between my manifold and compressor. I don't want water in my manifolds and I don't mind water in my tank seeing as I have a drain **** and drain it. I actually get no water in my trap unless I don't drain it for 2 months or so.
  27. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-22-2012 02:22 PM #27
    Quote Originally Posted by Squirrel Nuts View Post
    You pump straight from your compressors to the manifold, no tank?
  28. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-22-2012 02:27 PM #28
    Of course he runs it somewhere between the start of the system and the end of the system
  29. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-22-2012 02:43 PM #29
    After five weeks of running one trap pre-tank and one trap post-tank, the results are in.
    The trap with water in it on the left was used pre-tank, the dry trap on the right was post-tank.
  30. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-22-2012 02:56 PM #30
    I don't think that this was a fair unbiased test Will. You ran both traps at the same time, hence the results from the first trap altered the results of the second trap. If you wanted to truly show people the effects you should have ran one month with just the first trap then one month with just the second trap.
  31. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-22-2012 03:10 PM #31
    yeah Will, youre not even giving trap 2 a chance to work
  32. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    08-22-2012 03:15 PM #32
    Fair point Sean, but keep in mind, even with the first trap in place (between the compressor and tank), some moisture will still make it's way into the tank. (I know that you're already well aware of this since your setup utilizes a cooling tank). The fact is, during our test, none of the moisture that made it into the tank went on further into the second trap.
  33. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-22-2012 03:19 PM #33
    Yeah i completely agree that water will make it into the tank even if you used the first trap. But if you were to run ONLY the second trap i bet you would see 90% water in the tank and actually get 10% water in the second water trap, try it out and see
  34. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    08-22-2012 03:19 PM #34
    So you still had moisture in your tank and had to empty it right? I assume that without that first trap, you would just have that much more water in your tank, and that trap 2 would be acutally doing work.
  35. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    08-22-2012 04:54 PM #35
    who needs a tank bro?
    I meant I run it between my tank and manifold. Been a long day today.
