Results 1 to 16 of 16
Thread: Brake assist release
  1. Member aprr's Avatar
    Jul 25th, 2012
    San Diego
    2012 .:R, 2011 Duramax
    08-21-2012 03:50 AM #1
    My break assist seems to last a few seconds at most and then let's go. Are all of them that way?
    "Speed has never killed anyone, suddenly becoming stationary... That's what gets you." Jeremy Clarkson
  2. Member GASMAN664's Avatar
    Apr 9th, 2011
    '04 R32 '12 Golf R
    08-21-2012 05:00 AM #2
    Yup...should only hold for about 2 secs
  3. Member spydrz's Avatar
    Mar 21st, 2004
    RVA
    Golf R 2DR Rising Blue
    08-21-2012 07:55 AM #3
    Quote Originally Posted by GASMAN664 View Post
    ^this
    De-Soundaktor'd/Autolamps
  4. Member
    Feb 5th, 2012
    Northern VA
    2012 Golf R CSG 4-Door Nav Sunroof
    08-21-2012 07:44 PM #4
    Quote Originally Posted by spydrz View Post
    ^this
    ^this
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    08-21-2012 07:52 PM #5
    I have heard elsewhere you can change the amount of time the brake holds via vagcom. I don't know any details, maybe someone else that does know will chime in.
  6. 08-22-2012 12:47 AM #6
    Note too that if you rev the engine, it will release right away (say above 1200 RPM or something). So off the brake, on the gas, then let the clutch out. Definitely a different driving technique than if you are used to a "normal" car, where you let the clutch out a tad to keep you from rolling back. If you do that (as I had for quite a while) you'll find yourself fighting the stupid thing as it bogs you down...
    I still dislike it, and will probably disable it when I get access to a vag-com setup (or buy my own), unless I learn to drive around it such that it stops being a nuisance.
    -Fab
  7. Member aprr's Avatar
    Jul 25th, 2012
    San Diego
    08-22-2012 03:07 AM #7
    ive been in situations where ive needed to roll back a bit to get out. brake assist pretty much fixed that. call me old fashioned, but ill take my hand-break.
    Apr 9th, 2007
    St. Augustine, FL
    2012 Golf R, 2011 Honda Ruckus
    08-22-2012 10:10 AM #8
    Quote Originally Posted by ftillier View Post
    -Fab
    Dammit, why have I not figured this out yet?!? Too many years driving the CRX, so now I bog down too often trying to let the clutch out. Idiot!
  9. 08-22-2012 10:59 AM #9
    The only thing i dislike, dare I say HATE it. Is the break assist. The only times I've ever stalled my car are when the brake assist is on and i bog down so hard I stall. Balls. stalling balls.
    Edit: I can't believe how incredibly bad my spelling and grammar are. I'm leaving it just as a reminder.
  10. Member Time for a GTI's Avatar
    Apr 25th, 2006
    MA
    '12 Golf R
    08-22-2012 11:12 AM #10
    Quote Originally Posted by NORSMAN View Post
    Know anyone local with a VagCom? It's easy to turn off. I did mine the day after I took my car home. It was driving me nuts.
    FS: Golf R OEM HPFP
    Scotch. It's time.
    if i got my ass kicked every time I went to a particular bar, i'd own it, and ruin anything in my path.
  11. Member
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    08-22-2012 11:23 AM #11
    I actually really like the assist feature. I still use the handbrake in some instances, say if a hill is super steep, just in case I don't time it perfectly. I wish I could turn it on for an extended period of time. Ideally I would have it stay on until I either move the clutch, hit the brake or push the gas. I wouldn't mind being able to sit at a light for the entire length of the light and have the car stay put.
  12. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    08-22-2012 11:29 AM #12
    its brakes damnit brakes
  13. 08-22-2012 11:35 AM #13
    Quote Originally Posted by monkey7247 View Post
    Wish I could take credit for this, I was moaning about the hill hold thing in the what did you learn about your golf R thread (I think), and someone pointed out that if you hit the gas it releases right away. I assumed it would work like the Subaru setup in my mom's old Legacy, where it was linked to the clutch. The owner's manual is of no help, it doesn't tell you what will release it, and the conditions it lists for it releasing aren't accurate (e.g. must be in gear - nope, it works just fine in neutral)...
  14. Junior Member
    Feb 12th, 2012
    Arlington, VA
    2012 RB Golf R
    10-15-2012 04:53 PM #14
    I liked the hill assist. . . until I was trying to parallel park on a hill. It becomes like a game when you need to roll back a few inches in neutral when trying to park on a hill. A really annoying game. What would take me a few seconds to park. . . extends to: brake, wait for the release. . . brake. . . wait for the release. . . @%@$@. . . gas. . . brake. . . wait. . . brake. . . wait. . .@@#@ my wheel/curb. . . gas.
    Otherwise, when sitting at a traffic light, and getting ready to go. . . it works. Trying to park, when I'm trying to inch my way into a tight spot, it's crap.
  15. Junior Member tgiletto's Avatar
    Feb 23rd, 2012
    Texas
    10-15-2012 05:23 PM #15
    I just discovered break-assist the other day. I think it's a cool feature that is helpful.
    2012 Golf R CSG 4dr Nav/Sunroof
    APR Stage I+ with VWR Intake
    Disconnected Soundaktor
