Results 1 to 6 of 6
Thread: MK 1 Rabbit wont start
  1. Member TyeGTI's Avatar
    Apr 6th, 2007
    Thunder Bay, Ont
    2006 Jetta TDI, 1983 Rabbit GTI, 1980 Rabbit GTI
    08-21-2012 10:59 AM #1
    My 1980 with a 84 GTI motor wont start. When I turn the ignition on, the fuel pump runs but when I turn the ignition to start it cuts out. The PO has bypassed the fuel pump relay and it runs constantly when the ignition is on. So it not cutting out like a stock system when it gets up to pressure. As soon as turn the key to crank over the pump cuts out.
    Any thoughts on this
    Aug 14th, 2005
    Germany
    08-21-2012 12:39 PM #2
    Did it run before or did you buy it "as is"? The problem sounds like a splice was made into the X-mode power supply instead of the ignition power. Either one is wrong in my book as it makes the car dangerous in a way that is really not required, but hey . . . This power supply is what runs things like the rear window de-fogger or the heater fan or windshield wipers. Things that are not required for the engine to start, so more power can be directed to the starter on cold days. These things lose power when the key is switched to the cranking position and power comes back when the key is released to the run position.
  3. Member TyeGTI's Avatar
    Apr 6th, 2007
    Thunder Bay, Ont
    08-21-2012 04:07 PM #3
    Quote Originally Posted by WaterWheels View Post
    I did run i drove it from were I store it to the garage to work on it. Went to put it back and it wouldn't start. I didn't do anything to the electrical or fuel system.
  4. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    88 Scirocco 16v (Wilda); 86 QSW (still unnamed); 90 325iX (Nina - kid's car)
    08-25-2012 12:19 PM #4
    It sounds like you have a bad ignition switch. Very common failure mode:
    X contact (hot in Run only) works; terminal 15 (Run power) works; term. 50 (Start) works. But, term. 15 drops out when turned to Start.
    Get yourself a quality new switch (I'd only use one from the dealer, or from GAP - nothing else.)
    (and, if you don't still have the original, get a fuel pump relay, too. Hell, even if you do, get a new one for a spare! Same suppliers recommended.)
    New switch in hand, just drop the column plastic, unplug old switch, and plug in new. Carefully operate with a screwdriver. Car start? Tear into the column & replace the switch.
    - Cup
    '88 Scirocco 16v, 'tastefully' modified.
    things currently broken (Scirocco): 5
    things currently broken (QSW): too many; but, slowly getting better
  5. Member Esevw's Avatar
    Dec 27th, 2002
    Puyallup, WA
    83 rabbit GTI
    08-28-2012 03:19 AM #5
    Also check your grounds, even though you didn't touch them they could've been loose or corroded from last owner... Never know. Check.
  6. Member TyeGTI's Avatar
    Apr 6th, 2007
    Thunder Bay, Ont
    08-29-2012 10:34 PM #6
    I going to guess water in the fuse box because I found holes in the rain tray right above it.
