Results 1 to 11 of 11
Thread: 2007 eos top stuck closed fault 02805 system interference
  1. 08-21-2012 02:47 PM #1
    I have a 2007 eos 2.0T. The top recently quit working and will not open. the sunroof moves back and windows go down when conv. top switch is activated and after that I can hear what sounds like the pump running in the trunk. After that i get a warning in the cluster saying sytem error close top. I've scanned car and only code is 02805-system interference- 014 defective. I have no idea what this code means nor can I find any info on the code. It is an active code and can not be cleared. It will come back right away. any help would be awesome.
  2. Moderator just4fun's Avatar
    Oct 29th, 2006
    Alberta, Canada
    2007 Eos, Lux, DSG. 2006 Jetta. 2000 Honda Odyssey. 2011 Ford F150 EcoBoost
    08-21-2012 04:23 PM #2
    Sorry cant help with the interpretation of the code, but a trip to the dealership is obviously in order.
    They can explain the code to you. The roof and it's mechanisms are extremely complex, repairs should be done by a competent mechanic familiar with the system.
    Hope you have success getting it sorted and that it is not a serious problem.
    We would all appreciate hearing what is found to be the problem.
    Kevin
    Nov 27th, 2009
    50 Miles South of Tucson AZ
    2013 CC and 2009 Eos
    08-22-2012 01:45 AM #3
    Quote Originally Posted by dye_jesse View Post
    Although this is the most obvious potential problem, no doubt you have checked the luggage cover in the trunk to make sure it is secured with the clips on each side?
    I know, I know, waaaay to simple. Just had to mention it.
    Other than that, and what has already been said, the system is very complicated and only God, and possibly a VW service department, knows what the problem is.
    I have also know weak batteries to prevent the top from operating. Is your battery fresh?
    2013 CC Sport Plus, K@N Air Filter, LED Interior Lighting Including Foot Wells, 18" Interlagos Wheels w/ Cooper tires.
    2009 Eos, Tech Package, RNS510, K&N Air Filter, Silver/Black Leather Seats, Sherwood Aluminum Dash Kit, LED Interior Lighting, Underbody LED Safety Lighting, Under Seat Drawer.
  4. 08-22-2012 01:52 PM #4
    yes I have checked the luggage compartment cover and the trunk switch. I found with either of those open I get a warning in the cluster saying what is open and it wont even start droping the windows or opening the sunroof unless those are closed. I have tested the battery wich passed and I've got 13.5volts with engine running and load tested alternater.
    It seems that which ever hydraulic latch or latches that are suppose to unlock after the windows and sunroof open is broken, loose or binding. I just havn't figured out where those latches are.
    Jul 26th, 2011
    2004 TTQ 225 2008 VW EOS 3.2
    08-22-2012 03:29 PM #5
    2004 TTQ 225 Blueflame Exhaust, APR, Modshack, Dieselgeek Shortshift
    2008 VW EOS 3.2 DSG
    2009 Volvo XC90 V8 R-Design AWD
    Never underestimate the power of stupid people in large groups.
  6. 08-24-2012 07:16 PM #6
    Thanks for the link! That helped out to locate which latches/switches are suppose to open and close and what order they do so. I now know that my G560 and G561 switches are not switching nor can I hear the latches release. I was able to go to a used car lot and take a look at another one and play with the top and what not. You could hear the latches down in the C segmant release first then the trunk would pop. So i just need to figure out how to release those latches in the C-segmant
    Jul 26th, 2011
    08-24-2012 08:58 PM #7
    I would love to hear the outcome of this problem as we will probably see it soon.
    2008 VW EOS 3.2 DSG
  8. 08-29-2012 04:30 PM #8
    Quote Originally Posted by deltaP View Post
    I will post the outcome when I get some more time to work on the car. I've just been too busy to get around to it
    Jul 16th, 2012
    Glendale, AZ
    2011 VW Jetta S 2.0; 2007 VW Eos 2.0T; 1999 Inifniti QX4
    09-27-2012 09:48 PM #9
    On ours, there is a flap of the ceiling fabric that sometimes doesn't fold correctly and the same exact thing happens. Make sure the interior fabric is folding the same on both sides. Ours was preventing the compartment to fully pop open on the passenger rear side.
    -Einsteinjs
    Sent from my iPad
    Jul 16th, 2012
    Glendale, AZ
    09-27-2012 09:49 PM #10
    -Einsteinjs
    Sent from my iPad
    -Einsteinjs
    Sent from my iPad
  11. Moderator mark_d_drake's Avatar
    Aug 16th, 2006
    Bay Area, CA
    2007 VW Eos Sport with Tech Package, RNS-510 Upgrade. 2009 Jetta Sportwagen TDI, Stock
    09-28-2012 12:49 PM #11
    I had the same problem. My dealer fixed it by replacing the rear window motor module (which apparently is connected to the flap mechansim ?)
    CUSTOMER STATES: CONVERTIBLE TOP MALFUNCTION1
    NOT CLOSING CORRECTLY, INTERMITTANTLY
    SEE OSCAR FIRST
    VRFIEDI CUST CONCERN. FOUND R/R WINDOW INOP
    SCANNED FOUND FAULTY MOTOR R/R WINDOW..
    TESTED VERIFIED REC NEW WINDOW MOTOR AND REHCECK
    REPLACE RIGHT REAR WINDOW MOTOR
    INSTALLED NEW R/R WINDOW MOTOR.. TESTED OK
    TESTED CONVERTIBLE. CHECKED O K ~
    Wierd as it sounds I haven't had a problem all summer..
    Cost was
    REPLACE WINDOW MOTOR UNDER JMA AUTHORIZATION
    PARTS $260.00, LABOR $314.40. TAX $21.45. TOTAL $595.85
    Which was covered by my 7/70 Extended Warranty
