Results 1 to 21 of 21
Thread: TWM Performance A6 Leopard Shift Knob
    Aug 21st, 2012
    Ashburn, VA
    2013 BMW 328i M Sport
    08-21-2012 02:56 PM #1
    I know that a lot of people don't consider a shift knob to be of any importance on their list of things to do to a car, but I consider it pretty much essential as I have yet to drive a vehicle with a row-your-own transmission where I was completely satisfied with the stock knob. Whether it's from the shape and feel to the height or weight, I've never liked one. With my last manual transmission vehicle, a 2008 Honda Civic Si, I stumbled upon TWM Performance in my search, sprang for it and fell absolutely in love. I didn't even look anywhere else when I got home with my R and sat down to order parts.
    In the case of my Civic, I chose the M1 Abrams, but for the R I picked the A6 Leopard because of the added neck at the bottom. These knobs weigh over a pound, so you can pretty much just flick it into gear, even without a short shift kit. I chose the graphite finish with the pattern engraved, and it matches the R interior quite well.
    Everything needed for this specific installation is included with the exception of the Allen key required for the base.
    http://www.twmshiftknobs.com/shiftkn...-2012&twmonly=
    Box it comes in:
    Uninstalled, with the extremely detailed instructions:
    Installed:
  2. 08-21-2012 03:02 PM #2
    Wow that looks like a quality piece. If someone tries to car jack you, it doubles as a weapon
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    08-21-2012 04:20 PM #3
    Does it attach the same way the factory knob attaches? I don't like the aftermarket knobs that just use crappy set screws because they always fail. I had a UUC Motorwerks shifter and knob that threaded together using massive thread and it worked super well. I'd rock one of these TWM knobs if it doesn't wiggle loose all the time!
  4. Member
    Sep 21st, 2011
    Canada
    2005 V50 T5 AWD (sold), Black Golf R
    08-21-2012 04:20 PM #4
    I want. If that hybrid one came with the raised bit like this one id jump on it, looks like a good solution to the super hot shifter issue
    2012 Deep Black Pearl Golf [R]|APR Stage 1|Soundaktor unplug|OEM tinted LED tails|H2Sport Roller Follower|EVOMS engine cover|EVOMS V-Flow Intake
  5. Member ecirwin's Avatar
    Feb 27th, 2009
    Lakewood, CO
    '12 Golf R 2Dr Black
    08-21-2012 04:55 PM #5
    I really like the feel of a metal shift knob, except when it is really cold or really hot. There is a lot of thermal mass there and it will either burn you or suck all the heat out.
    2012 Golf R 2Dr Loaded Deep Black Pearl Metallic - Diesel Geek Short Shifter, JOM Badgeless Grille, R Hatch Badge Delete, Soundaktor Delete, 42DD Downpipe, HPFPupgrade Stage 1 Pump, United Motorsports Stage 2, Huper Optik double layer Ceramic Tint (15% equiv), Opti-Coat 2.0, HPA Dogbone mount 78a, Rebadge.com custom Hatch Badge, BSH Phoenix Rising CAI, Forge Twintercooler, Smoked LED Tails
  6. Member hussdog426's Avatar
    Nov 20th, 2011
    North Jersey
    Bagged 2012 Golf TDI
    08-21-2012 09:22 PM #6
    looks cool
    2012 Bagged United Gray Golf TDI OEM+
    follow me on instagram: @hussdog426
  7. Member V8Star's Avatar
    Jun 26th, 2007
    South Orange County, CA
    2013 S4
    08-22-2012 12:54 AM #7
    Quote Originally Posted by ecirwin View Post
    The stock knob will burn your hand badly as it is
    2013 S4 - Monsoon Gray - S Tronic
  8. Member ecirwin's Avatar
    Feb 27th, 2009
    Lakewood, CO
    08-22-2012 07:38 AM #8
    Quote Originally Posted by V8Star View Post
    Yes, I agree. That metal piece on the top gets hot. I assume it will also get f'ing cold in the winter. In comparison to a solid metal shift knob, the stocker is nothing. In the summer, the solid knob would probably take 15 minutes of driving with a/c blasting to cool down. In the winter it would probably take twice that long to feel warm.
    Aug 21st, 2012
    Ashburn, VA
    08-22-2012 08:08 AM #9
    Quote Originally Posted by Atl-Atl View Post
    It's a sort of a hybrid. The knob itself has very serious thread, and what attaches to the actual shifter is threaded for the knob so it can be removed easily from the car or swapped for a different TWM knob. Although that attaches to the shaft with set screws (not the cheap kind), it is not coming off. If I have time, I'll take the knob off later today to show the mounting.
  10. Member
    Aug 21st, 2012
    Ashburn, VA
    08-22-2012 08:09 AM #10
    This knob can be unscrewed and placed in the glovebox if desired, which also doubles as a security precaution.
  11. Member
    Aug 21st, 2012
    Ashburn, VA
    08-23-2012 02:46 PM #11
    Mounting:
    Knob threading:
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    08-23-2012 06:49 PM #12
    Quote Originally Posted by dc/dc View Post
    Thanks for the details and the pictures, looks like a very high quality product. Add another thing to the list!
  13. Member
    Aug 21st, 2012
    Ashburn, VA
    08-24-2012 10:17 AM #13
    They are very high quality, and worth every penny.
  14. Member
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    09-16-2012 08:42 PM #14
    Kind of digging this up from the dead.
    I am curious about the height of this knob. Did it add or subtract any height to the entire shift assembly? If anything when I get an aftermarket knob I'd want it to sit lower than stock, effectively shortening the throw.
  15. Member
    Aug 21st, 2012
    Ashburn, VA
    09-17-2012 01:38 PM #15
    It shortens it a little bit. I didn't measure it, but it's noticeable.
    2013 Alpine White BMW 328i M Sport
  16. Member
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    09-17-2012 01:45 PM #16
    Thanks, it looks like the M1 model sits even lower than the one you got. I might have to pick one of these up soon.
  17. Member
    Aug 21st, 2012
    Ashburn, VA
    09-17-2012 02:16 PM #17
    The M1 is exactly the same as the A6 except for the little neck, so it won't get you any lower unfortunately.
  18. Member
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    09-17-2012 02:22 PM #18
    If you look at the pictures on TWMs site they show the M1 and A6 mounted in the same vehicle and the M1 definitely looks like it sits lower.
  19. Member
    Aug 21st, 2012
    Ashburn, VA
    09-17-2012 07:52 PM #19
    Hmmm... It shouldn't be. It's the same ball, and the threads go to the same spot. The only explanation I could see is if it was a vehicle that had threads on the shaft and they didn't have one of them all the way down. This was the case in my Si.
  20. Member
    Jun 6th, 2006
    Madison WI
    2012 Golf R
    09-17-2012 08:26 PM #20
  21. Member
    Aug 21st, 2012
    Ashburn, VA
    09-18-2012 07:16 AM #21
    Can't explain that one other than my previous thought...
