Results 1 to 17 of 17
Thread: Turbo Cool Off
  1. Member Coderedpl's Avatar
    Jul 9th, 2006
    Valley Stream, NY
    2012 VW Golf R 4dr Rising Blue
    08-22-2012 01:46 AM #1
    Just a silly thought that's going through my mind, how many of you actually sit there after you get to your destination and let it "cool off/down"?
    I've honestly done this since I had my A4, and even got into a habit of doing it with my naturally aspirated S4 =O
    The golf r is no different, i let it warm up till the rpm's drop and let it cool off for a minute or two, if i drove it really hard then I let it cool off for much longer.
    I've heard some people saying this is un-necessary but I assume that's a false statement.
    so do you?
    Current: 2012 VW Golf R (rising blue) / UM tuned
  2. 08-22-2012 01:52 AM #2
    I've been driving it easy before getting to my destination, I think having air moving over the radiator, etc., is probably a better way of getting it to cool down. So no, I haven't been letting it idle when I get to where I want to be.
    -Fab
  3. Member StevenPirre's Avatar
    Mar 3rd, 2009
    CT
    01 GTI 1.8t
    08-22-2012 02:06 AM #3
    I have over 224,000 Miles on original engine and turbo. I don't wait for turbo to cool off while idling. I just take it easy the last couple miles of my trip.
  4. Member
    Apr 10th, 2012
    Australia
    Golf R
    08-22-2012 02:34 AM #4
    These engines have an electric water pump to help cool the turbo and engine down once the engine is turned off.
    But another good practice it to just take it easy for the last <1minute of your trip before you park the car - in reality, you are normally coasting in a carpark looking for a parking spot or similar anyway for 30 seconds - so you are safe to just turn it off.
    A freind of mine lets his car idle for about 10 mins after driving which is both totally unnecessary and actually counter productive as heat soak settles in - he would be better off to just turn the car off after 30 seconds.
  5. Banner Advertiser John@Roc-Euro's Avatar
    Apr 25th, 2012
    Rochester NY
    2012 Golf R DPB
    08-22-2012 10:07 AM #5
    Quote Originally Posted by Lucas_R View Post
    That's my thought process as well. Airflow is the most important, but after that, idle sucks.
    Roc-Euro /:\ >> Your source for APR Products, ISC Suspension, Roc-Euro items, and more.
    Email us at info@roc-euro.com, call us at 585.270.8171 or come down and see us at the shop!
    #roceuro on >>Instagram, find us on >>Facebook too.
  6. Member
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    08-22-2012 10:16 AM #6
    Just don't shut it off after immediately running high revs. When you arrive at your destination, sit for 5-10 seconds before turning the engine off. That's what I do.
    Also, like others have said, it's better to just take it easy and let the car walk along at low speeds before shutting it off, this way air if flowing over the intercooler, radiator and so on.
    When I was on the Dragon, I would let the car sit for about a minute at the bottom to cool off before turning it off. On the return trip, I just eased up on the throttle once I hit the NC state line and drove slowly to the pit stop there. When I finish a session at the track (VIR), I take a short drive around the parking lot or on the exit road to South course to let the engine, turbo and brakes cool.
    May 23rd, 2007
    Union County, NJ
    RB 4D Base Golf R
    08-22-2012 10:35 AM #7
    Water cooled and no turbo timer no need
    You're just wasting gas
  8. 08-22-2012 10:41 AM #8
    its not just "cooling the turbo" that they do a cooling process its having hot oil in the turbo and if the turbo is red hot when you shut the car off it can super heat the oil and actually gum up the bearings in the turbo and in turn starve the turbo of oil. this most likely wont happen with the new oils we use in our engines so just as long as you not beating the cr@p out of you car and shutting it right off you should fine......
    2013 CW 4D Golf .:R / UM Stage 1 / APR RSC TB Exhaust / Forge TwinTake / NSP Golf .:R boost guage / Autotech HPFP........
    Feb 27th, 2012
    Niagara Area, Ontario, Canada
    Lurking....Maybe Golf R?
    08-22-2012 12:53 PM #9
    99% of, if not all, modern cars do not require this. If you are romping on the car at the track, stop and give it 5-10 seconds then shut her down. Like someone else mentioned, these cars have electric water pumps that will circulate water to cool the turbo/engine after the car is turned off. Turbo timers are just a waste of money on modern cars, but of course Greddy, HKS etc...will tell you otherwise, they have a part to sell. For every second you have the car sitting and idling, you are getting 0mpg...hurts
  10. Member
    Oct 28th, 2004
    Westchester County, NY
    2012 Golf R DBM
    08-22-2012 03:03 PM #10
    While I agree with the "just take it easy for the last few miles of your trip" crowd, sometimes that's not possible. If I'm deep into the boost right up to when I reach my destination, I just let it idle for a minute or so before I shut it off. Maybe it isn't necessary as some say, but it makes me feel better about it.
    --Chuck--
  11. Member JLCVDUB's Avatar
    Apr 10th, 2007
    Austin, Texas
    2012 CW Golf R
    08-22-2012 03:56 PM #11
    Water lines are there for a reason..
    Sent from my iPhone 4S using Tapatalk
    2012 CW GOLF R #0025
    Maybe I'll make some real power this year.
  12. Member Coderedpl's Avatar
    Jul 9th, 2006
    Valley Stream, NY
    08-22-2012 04:27 PM #12
    Well i honestly thought the responses will be different but that's good to know. ^_^
  13. Member
    Mar 4th, 2010
    Winnipeg
    2013 .:R RB
    08-22-2012 04:40 PM #13
    Doesn't the Manual tell you to let it idle for a few minutes after a hard drive?
    2013 R RB - HPA Comp Controller - HPA Red 75A Motor Mount - HPA Short Shifter - 42DD Shifter Bushings - TyrolSport Solid Shifter Bracket Bushings - Carbotech Bobcat 1521 (Daily) - Carbotech XP12/XP8 (Track) - Unibrace UB - Euro Springs
  14. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    08-22-2012 04:51 PM #14
    Quote Originally Posted by Rebellionelite View Post
    I wouldn't think so. I don't think "hard drive" would be found anywhere in the manual. Vw expects you to drive the car the way 99 year olds who want to live to 100 would drive.
    Sent from my SAMSUNG-SGH-I747 using Xparent Red Tapatalk 2
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  15. Junior Member
    Jul 24th, 2003
    Norcal
    '97 Ginster GTI '01 Techo Blue Eurovan MV Wkdr '07 CW GTI 4dr DSG
    08-23-2012 03:10 PM #15
    I usually wait 5-10 sec then shut down after normal driving. After spirited driving I usually just take it easy for a few miles. I always open my hood to let her cool down when I'm home & other places that I can.
    '97 Ginster GTI
    '01 Techno Blue Eurovan MV Wkdr
    '07 CW GTI DSG
    '12 CW Golf R 4dr
  16. Member A3Performance's Avatar
    Jul 21st, 2006
    New Jersey - 201
    2006 Audi A3 2.0T
    08-23-2012 03:36 PM #16
    These engines have an after-run coolant pump, no need to wait or purchase a turbo timer. For those with an R enjoy, i'm jealous!
    Brilliant Red 2006 Audi A3 Sports Package: FrankenTurbo F23T, Eurodyne Maestro, APR HPFP, RS4 PRV, Forge Twintake , Precision 600HP Intercooler w/ FFE piping, ATP DP, SPM "Street" Exhaust, BSH CC, VF Full Mounts, 42 Draft shifter bushings, Vogtland Coils, APR Rear Sway, BSH End links, VMR Vent Gauge, Well-Done HID
