Results 1 to 9 of 9
Thread: Project: MIDIPedal
  1. Member atomicalex's Avatar
    Feb 2nd, 2001
    Detroit and Düsseldorf
    dark blue stick shift station wagons and one shiny yellow motorbike
    08-22-2012 11:11 AM #1
    It was suggested I start a build thread.
    It started 20 years ago when my spouse introduced me to MIDI. My first thought was, damn, I need a pedal bay.
    20 years, a move to Germany, a chance internet search after the 13YO decided Bach was cool, and 250€, and it turns out that you can fit an entire AGO pedal bay into the back of a MkIII Kombi. Who knew?
    More discussion with the organ junkyard place revealed that no, you cannot buy a used pedal bay in the US. Organs aren't actually scrapped in the US, and they are rarely replaced, so no goodies. I did actually have to move to Germany to get this.
    Next step... acquire a MIDI controller to part out into switches, actual controller parts and controls.
    The final goal: the Weird Al of pedal bays - fully velocity-sensitive with aftertouch, 4-channel multi-timbral, minimum 64 voice polyphony (dependent on what we hook it up to, of course), some sort of piston-type control (multiple programs per channel), and whatever else I can get. The hard part is getting the velocity sensitivity and aftertouch. Once I get that done, I am pretty much there.
    A(u). Klasse A, unbeschrankt, ungedrosselt
    Compared to a British roadster, all Volkswagens are reliable!
    nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
  2. Member atomicalex's Avatar
    Feb 2nd, 2001
    10-19-2012 02:52 PM #2
    Donor controller - first attempt at cutting up the keyboard strip did not go well. I got some new Dremel bits, should be smoother this time.
  3. Member atomicalex's Avatar
    Feb 2nd, 2001
    10-19-2012 02:59 PM #3
    Old electronics removed and ready to scrap.
  4. Member Ed52's Avatar
    May 21st, 2001
    Toronto, Canada
    10-20-2012 11:24 PM #4
    '''interesting''', will watch this.
    Family cars:
    2.slo + 2.0 16V + 2.0T +2.8 Vr = lotsaVws
  5. Senior Member abeR's Avatar
    Sep 13th, 2002
    Joe's Garage / Chicago
    3.2 electric boogaloo bitches
    10-25-2012 12:35 PM #5
    Quote Originally Posted by Ed52 View Post
    agreed
  6. 10-30-2012 02:28 PM #6
    Awesome project!
    These guys might like to see what you're up to. http://casperelectronics.com/
  7. Member atomicalex's Avatar
    Feb 2nd, 2001
    12-09-2012 07:46 AM #7
    More progress, even though I tend to sit on my ass about this for months on end...
    Had to scrap my original idea about using the controller switches as-is. They are not possible to separate for an amateur electrician like me. So, on to the more professional reed switches.
    That there is a pair of offset reed switches that function as a velocity sensitive trigger for the MIDI controller. I have a lot of work ahead with figuring out the proper offset and the magnet distance and so forth, but I have created a velocity sensitive trigger using the donor controller as a power source and a signal harvester. In other words, it works! I triggered an old RX-7 and had a bit of a time trying to get the magnet speed right, but it works! Fully velocity sensitive. Aftertouch will have to wait, but I have a plan for that, too. I'll need a new controller setup, but the switchgear should be suitable for just about any controller out there. Challenge will be finding one with aftertouch and getting those strips positioned properly.
  8. Member atomicalex's Avatar
    Feb 2nd, 2001
    01-04-2013 12:43 AM #8
    Worked on reed switch spacing and directionality of the switches. I think I have it figured out.
  9. Member atomicalex's Avatar
    Feb 2nd, 2001
    02-08-2013 10:20 AM #9
    First of the switch arrays spaced and assembled.
