Results 1 to 3 of 3
Thread: Fuse Panel Problems
  1. Member Eject's Avatar
    Aug 14th, 2001
    Toronto, Canada
    03 Jetta 1.8T, 89 Cabriolet
    08-22-2012 02:46 PM #1
    I've recently been experiencing some weirdness with my fuse panel.
    2 months ago my 89 Cabrio wouldn't start. The engine turned but there was no fuel delivery. I replaced the fuel pump relay as well as the in-tank transfer pump and it did not remedy the problem.
    I took it to my local vw shop and was told that my fuse panel was the problem.
    I was told that some of the high amp harnesses warp due to heat. The mech was able to fix the car without replacing the fuse panel but he said the problem would surface again.
    Well it returned last night and finally got the car to start after fiddling with the harnesses on the back of the fuse panel.
    Has anyone experienced anything like this?
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    08-22-2012 02:48 PM #2
    Sounds like you need to replace it, or to take it apart and clean the bejeezers out of it as you have some corrosion issues.
    If you haven't replaced your grounds now would be a good time to git-r-done.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  3. Member 87CabrioSK's Avatar
    May 27th, 2010
    S'toon, Sk, CA
    1987 Cabriolet (5 speed)
    08-22-2012 03:01 PM #3
    This happened on my mk1 GTi, turned out it was water getting to the back of the fuse panel due to rust beneath my windshield.
