Hey Garrett, only use one each of the blue and white wires. You have basically set up a loop antenna by connecting them like that at both ends.
#1
So I made my first attempt at custom mic cables today. I bought cable off of eBay and 90* ends for both sides. The wires are supposed to be good and have two + leads, two - leads and the shielding. I pulled apart an off the shelf cable I had and copied it. The mic cable works but the ground noise is TERRIBLE. I tried splitting the shield between the post and the housing and that didn't work. I removed the ground from the male end and that didn't work. And last I routed as you see in the pics to no avail.
So, I know there are some audio guys one here; what am I doing wrong? I know it's not the mic or board because OTS cables sound great.
Sent from a rotary encoder using my finger
A little Japanese, two Germans and a Swiss two wheeler
#2
A(u). Klasse A, unbeschrankt, ungedrosselt
Compared to a British roadster, all Volkswagens are reliable!
nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
#3
You also peeled the shielding too far back. Keep it as close to the terminals as possible.
#4
Next time, use some heat shrink too.
Sent using smoke signals.
Originally Posted by Mk1Madness
