Absolutely beautiful! I love how simplified your engine bay is - must be a pleasure to wrench on. Any more pics of the body - side view maybe - in the Jazz Blue? What's the curb weight?
#1
figured a new look, new thread.
old info here
http://forums.vwvortex.com/showthrea...attro.../page7
started August of 2008 with this here....
ended up with this here in the spring/summer of 2011
648whp/508tq 38psi e85
car made 4 passes down the track that fall, went best et of 11.1@133 and best MPH was 11.8@137, on 225 street tires.
winter of 2011
Spring 2012
And finally, fall of 2012 and we have a completed, driving car again.
plans for 2012 season are a bit more power, not that its needed but 700 was the goal when the project began...and why ****ing not right?
wider street rubber in hopes that the car can go mid 10's on STREET tires, i believe the current Audi record for that is 10.5's done by the 034 VRT A4. then to kiss the 9's on some slicks, and after that just cruise around the streets and enjoy the car. a front torsen diff to replace the stock open one. new paint, new engine bay scheme, new interior setup/dash and have more fun.
Build Specs:
2.0l 20v
AEG crank
Custom pinned crank gear
Welded crank trigger wheel/bolts to crank
Welded oil pump gear
Calico rod and main bearings
SCAT connecting rods
83.5mm 8.5:1 compression teflon coated skirts JE pistons
Clutchmasters FX700 twin disc with steel flywheel
AEB head
Supertech Titanium retainers
Supertech Exhaust valves with single groove keeper
Stock intake valves
Cat 3652 billet cams
Custom built intake manifold
BBK 75mm Throttle body
Bosch 044 Fuel Pump x 2
Holley low pressure high volume pump
1 gallon (ish?) surge tank
2000cc T1 injectors
Aeromotive adjustable FPR
-8 fuel line
Vibrant Performance 800 core
Custom tubular exhaust manifold
Custom 4" stainless down pipe
Custom 4" aluminum exhaust from down pipe back
Custom 3" intercooler piping
PTE 6765 t4 .81a/r
Lugtronic ECU tuned by Kevin Black....and no matter how many shiny or expensive parts are IN a motor or a car, without a tune....you just have an expensive pile of schit.
||-Audi 90Q-||-2L-||-6765-||-LugTronic-||-10.7@136-||-33psi-||-255 street tires-||-2800lbs-|
http://forums.vwvortex.com/showthrea...llet-LugTronic Instagram -:- JON_ZERB
-:-All powdercoat was done by me! PM me for powdercoating pricing to make it happen!-:-
#2
Jeremy Brehm: Regina Wedding Photographer
'02 Audi TT 225 Build Thread - 2.0L - PTE6262 Daily @ 30PSI - 10.0:1CR - AEB @ 9000RPM - Maestro - RIP
'06 3.2Q A3 - Stay tuned!
#4
Looking good.![]()
Douglas VW
Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
Innovative Motorsports + UM
#5
when i first built the car one of the main things i made sure of was that almost everything was easy to replace, tweak, tighten, loosen, check. theres nothing ****tier then working on a car like this and having to be a contortionist just to yank an alternator or a crank sensor. i will be getting some pics soon with my DSLR instead of just my iphone and ill be sure to post them up in here when i do, thanks for the kind words. car weighed with me in it last year 2880 on the scales at Etown, im about 165 and the car had the 12 gallon fuel cell pretty much full with e85. added some weight this year im sure though with the new exhaust and the different wheel/tire combo.
#6
#7
Looks purdy John![]()
#8
Blue looks nice and mean!!
I have those tires and really like them...but then again my car isn't 650hp
#9
I hope those tires hook all of 650hp!!
#10
Are you running the 01e 5 speed, or the s4 01e 6 speed? If the latter; I need to have a little pm chat with ya![]()
#11
im running the 01E 5 speed, but if you have any questions still shoot me a pm
#12
#13
looks great.
glad to see the progression pix all on sequence too.
we been at this for long enough, its time you go take some street cred away from fools, and hit that 10.xxx on the street tires!
#14
034 went 10.5x on continental street tires in their vr6t a4, so that's the number that I'm gunning for on true street tires.
#15
got some pictures taken by a local photog this past wednesday at a meet. these are just the versions i pulled off of facebook, i should be getting the full hi-res files emailed to me today or tomorrow.
#16
She looks amazing john!![]()
#17
Holllyyyy sll!t well done!!!
20th build ~9:5:1 wiseco 81mm forge pisons~IE 20mm rifle drilled H beams~Calico rod bearings~snowperformance single injection water/meth~stock small port AWP head matched to a IE intake manifold~hemi throttlebody~Custom downpipe/turboback~Self maestro tuned~tial 38mm wastegate~GT3076r .63ar Vband~6 puck Clutchnet~PTE600.
#18
Thanks guys! Glad its running well to boot. Hopefully making it to the track at least once before fall show and go to see what I can do with it.
#19
#20
looks great![]()
DONT PM THIS ACCOUNT!! I RARELY CHECK IT!
IF YOU HAVE QUESTIONS/CONCERNS/ISSUESWITHZOMBIES PLEASE IM MY OTHER ACCOUNT BELOW:
Quintin@USRT
#21
#22
car has been running well. upping the boost little by little, shooting to make it to a test and tune this coming week. should be a good time.
#23
lol nice love it... all you E85 junkies![]()
Project GTi-R:. '04 R32 Chassis w/ 1.8t transplant in the werks
'01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, enormous amount of go fast
'03 GTI: Gutted, Parted & Transplanted
'04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, sold to ejg3855
'13 F150 Ecoboost: Ordered, Rec'd, Triple Black, Tow Truck for other Vehicles.
#24
#25
more boooooost lol bikes are hard to run though, smallest **** makes them stupid fast.
WHat is keeping you at 32psi?
#26
ya, i wasnt too upset about it really considering its a 1000...especially at 32psi. only thing keeping me there is just that we are upping the boost little by little from last years map with the 3658 cams vs the 3652s that are in there now. i will say it feels like a whole nother animal up top though with the newer cams, thing seems like it wants to just pull for days. i ran this same bike last year and got walked pretty hard at 34psi, so for me this was really just more of a test to see where the car was compared to last year, hahaha....until i make it to the track.
#27
#28
Love the way it sounds from inside on the second video. Music to my ears.![]()
@balboa_towers on IG
#29
made it to the track last week. first pass hit my personal best et and bettered my best mph from last fall, on 6 psi less boost. it became apparent to me after the second pass that i coudlnt launch the car to save my life, and it was just all downhill from there. i will be hitting the track next sunday at show and go, and hopefully get **** done this time around.
#30
looking good man..![]()
"boy iv'e done everything but die and see the wind"
"keep away from the farm, ya won't have to deal with any s**t"
" if your not living on the edge, your takin up too much space"
82 URQ_2.0L_20VT 62/65 ID2000 LUGTRONIC... 12.3@114mph 93 oct. old setup..
#32
nice pass
next time get more heat in the tires, 4 wheel burnout in the water boxthat should help with forward momentum.
#33
alot would have helped that night, lol.
the car was raping second gear....yet it never did that on the street, and still hasnt after practicing launching and the 1-2 shift yesterday afternoon. i think ive got it figured out though for next weekend down at englishtown, we shall see.
#34
Holy engine movement in that 1st of three videos.... or it at least LOOKS like the engine is moving a ton.![]()
science: it's for real.
#35
ya it does, which is odd because you certainly dont feel that in the car. i think its more of the camera moving around a bit, and the intake tube flopping around....giving your eye the illusion of the motor rocking all around. but i could be wrong.
