Page 1 of 2 1 2 LastLast
Results 1 to 35 of 48
Thread: Megan or 42DD exhaust
  1. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-24-2012 08:44 AM #1
    The time has come to replace the rotten stock exhaust on the Golf.
    Here is my issue, I am a proponent of buying quality parts the first go around, saves time and money down the road. But here are some of my concerns:
    NY winters can take a toll on the undercarriage of a car, I'm betting aluminized steel would not hold up over time. I only plan on keeping the car, at the most maybe 5 years.
    So with that in mind, considering price, durability and sound, it's a toss up of the 42DD aluminized steel exhaust or Megan stainless.
    Basically I'd like something that will be durable, but at the same time sound decent and not cost me 1/3 of what I paid for the car, which most other "higher end" stainless systems or the ceramic coated 42DD system will be.
    2000 VW Golf 1.8T - handles daily everyday commuter activities.
    Will see tough NY salt winters, especially where I work.
    42DD exhaust:
    -CNC mandrel bent 14 gauge aluminized steel tubing
    -CNC machined 1018 cold roll steel flanges
    -Professional TIG welded construction throughout
    -Magnaflow resonator & muffler
    -304 stainless steel polished tips
    -Double layer graphite gaskets
    -Grade 5 locking hardware
    -Considered for quality fitment and sound.
    -$487 shipped, add another $210 for ceramic coating. By time all is said and done, it's just over $700 for it, it's close, but not quite 1/3 of what I paid for the car.
    Megan Racing
    - Dual 2.5" round tip with 2.5" piping
    - 2.38" or 60.5mm ID Perforated Core Muffler
    - 3-Piece
    - 100% stainless steel with polish finish
    - Warranty included
    -$350 shipped
    AT face value, the Megan looks to be the best bet, but am not sure how well it fits.
    Thoughts, opinions, feedback?
  2. Member Einkaufswagen's Avatar
    Oct 25th, 2009
    N Kingstown, RI
    1999.5 Jetta VR6 GLS, 2000 Jetta VR6 GLX, 2001 Jetta VR6 GLX, 2001 Jetta VR6 GLX
    08-24-2012 08:51 AM #2
    42DD all day.
    I wouldent bother with the ceramic coating if you are pinching pennies, i have had my aluminized for about 3 years now and its holding up perfectly fine, I daily drive it in new england salt hell as well.
    My OEM+ build thread with a twist: Einkaufswagen's Build
    Quote Originally Posted by jaysleeves View Post
    I'm just curious if I should wipe my ass with the left, or right hand? Any input would be appreciated and yes I searched.
  3. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-24-2012 09:32 AM #3
    Quote Originally Posted by Einkaufswagen View Post
    42DD all day.
    Well in NY we spread salt like it's free, and the fact I work and commute to an underground salt mine, the car will see more than usual salt and muck.
  4. Member Einkaufswagen's Avatar
    Oct 25th, 2009
    N Kingstown, RI
    08-24-2012 10:16 AM #4
    I live in RI its just as bad here trust me the aluminized is fine. My brother has the ceramic coated one and they literaly are both holding up the same.
  5. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    08-24-2012 10:18 AM #5
    Quote Originally Posted by Hondapicker View Post
    i was gonna say 42dd all day because u work in a salt mine, i'd prob go with the stainless megan setup. have it welded up instead of using the clamps and you should be good
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  6. Forum Sponsor John@42's Avatar
    Oct 16th, 2006
    Maryland
    Audi TT
    08-24-2012 10:36 AM #6
    We have these systems all around the world, in many areas with conditions worse than NY roads. We took into account corrosion when selecting materials to build our exhaust out of and aluminized steel will hold up to what is thrown at it. There will be some surface rust but you will find out that we use very thick, quality materials that are designed to withstand what they are put up against. If you ever have an issue with something rusting through (which is a very VERY small percentage) give me a call and let me fix it for you.
    Q: So what does all that actually mean? I am concerned about rust.
    A: Let’s start with the piping. Aluminized steel is a basic low-carbon steel with a coating of aluminum bonded
    to the pipe inside and out. Like any coating, the aluminum protects the steel from the elements, preventing
    rust. It holds up to 1600° and will never peel or flake off. The pipe underneath cannot rust until the aluminum
    corrodes and the coating is degraded.
    Our flanges are cut from 1018 cold roll steel. This material machines fairly easily and is consistent. We machine
    to exacting precision to ensure proper fitment on your vehicle. Precision aside, steel rusts. The flanges will get a
    coating of rust on them immediately, but are too thick to “fall apart” within the normal lifespan of this system.
    Our flex section is made from 300 series stainless steel. The flex section will darken as it’s heated becoming a
    dark brown color. This is normal for all stainless steel. The clamping bands on our flex sections are aluminized
    steel and will share the same characteristics as our piping.
    Our catalytic converter is provided in 409 stainless steel. 409 stainless steel is essentially mild steel with
    enough chromium added to slow down the corrosion. It will turn dark brown quickly and will rust slowly over
    time.
    Our hardware is cad/zinc plated. This plating acts as a protective layer reacting with the corrosive environment
    before it can reach the steel.
    -John
    John Pelton
    Sales & Shipping Manager
    http://www.42draftdesigns.com
    42 on Facebook!
  7. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-24-2012 10:55 AM #7
    Quote Originally Posted by John@42 View Post
    I prob drive on one of the worse ones in order to get to the plant.
    With haul trucks using the same road to haul the road salt from there, in the winter, there is lots of snow, mud, salt, water and just muck that accumulates on the road.
    Which I why my concern, which will be the best value for the time I'm going to have the car and hold up the best, based on conditions that I drive it in.
  8. Member WillToBeWeird's Avatar
    Jul 22nd, 2012
    Oconomowoc, WI
    04 GLI VR6
    08-24-2012 01:40 PM #8
    Go with the aluminized system and just be sure to wash under your car as often as you can and spray wax sealant after every wash
  9. Member VR JC's Avatar
    Apr 30th, 2007
    Deadmonton
    20th on Alphards
    08-24-2012 02:00 PM #9
    I would go EuroJet, I have nothing bad to say about mine at all. Sorry if it was mentioned it was a long OP.
  10. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-27-2012 09:19 AM #10
    Quote Originally Posted by VR JC View Post
    No it wasn't mentioned.
    Pics/specs on it?
    VW Daily driver, 88-91 Honda Enthusiasts.
  11. Member baun's Avatar
    Jun 6th, 2005
    Cleveland, Ohio
    2000 Golf VR6
    08-27-2012 09:59 AM #11
    I my 42DD system
    HS TUNINGLOWERED EXPECTATIONS
    http://www.hstuning.com
    My build thread
    http://forums.vwvortex.com/showthrea...-BUILD-THREAD!
    Instagram-@ebaunics
  12. Junior Member
    Jun 13th, 2011
    Pickering, ON
    2000 GTI VR6
    08-27-2012 10:21 AM #12
    if your willing to spend 700$ why not just buy a good stainless?
  13. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-27-2012 10:24 AM #13
    Quote Originally Posted by kylevvGTI View Post
    I never said I was willing too....
  14. Member vweatsvtec's Avatar
    Dec 16th, 2009
    pearl river ,ny
    86 rocco 03 jetta . 2012 r on the wayyyy
    08-27-2012 10:37 AM #14
    Get 42 ive had mine for over 4 winters in ny daily driver and holding up amazing I Love the sound and the fitment.
  15. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    08-27-2012 11:10 AM #15
    I realize all exhaust will rust or show signs of rust at some point, it's a question of when and how much.
    Looking around and using some common sense, it's clear that aluminum will rust faster, SS exhausts will usually outlive the car.
    I may shop around and price out having a local shop, in the Binghamton area, to custom make a SS system.
    Quote Originally Posted by vweatsvtec View Post
    You don't see the same amount of snow we see up here, nor do they spread salt down there like they do up here in Central and Western NY.
  16. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    09-11-2012 09:59 AM #16
    Passed on both of the ones posted above and found someone locally selling a BNIB 2.25" Magnaflow SS cat back exhaust.
  17. Member scirockalot8v's Avatar
    Sep 15th, 2006
    724 to the 412
    mk4 and mk5
    09-11-2012 11:13 AM #17
    i support a US made product. 42DD.
    yeah the megan exhaust might be stainless but i bet the piping is thin and cheap. its just an ebay chinese exhaust that a company rebrands with their name.
    PM me for Custom Coilover Covers.
  18. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    09-11-2012 11:21 AM #18
    Promise that you will not be satisfied with piping that small. and with no down pipe, you won't get the full affect of what an exhaust system could potentially do for your car. You also may find that this wont hold up as well as you expect it to-- mine hasn't. will be switching mine up in the next week
  19. Member Dutchmastr9's Avatar
    Sep 13th, 2004
    Boston
    2 Door bugatti coupe...er, i mean Golf Racecar
    09-11-2012 11:41 AM #19
    quad deuce FTW
    You Aint About That Life | ETYolo
    Ruined Blue Golf | 42 Draft Designs
    Buy My Autopilot V2
  20. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    09-11-2012 12:25 PM #20
    Quote Originally Posted by alankitzmiller View Post
    Piping size was not a consideration or an issue.
    This is for my DD, not looking to turn it into anything else.
    Aluminized steel would not hold up in the moist, salty, muck covered road I drive on in the winter, and the Megan was no longer being considered.
    It was down to the Magnaflow or a simple OEM replacement.
    As far as SS not holding up, I've had TWO Thermal Research exhaust for two Hondas' I used to own and they held up beautifully over the 5 yrs I had them.
    So from some past experience, SS has held up much better than anything else I've seen.
  21. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    09-11-2012 01:19 PM #21
    i think the 2.25" is too small as well, but if you dont care i dont care. it is a nice stainless setup tho, not if they only offered this in 3" piping lol
  22. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    09-12-2012 08:24 AM #22
    Quote Originally Posted by Big_Tom View Post
    Piping size was not a deciding factor, wasn't looking for performance gains, just needed something durable that will last and look good/close to factory at a great price, which with this, I think I got.
  23. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    09-12-2012 08:44 AM #23
    yup, i know u were shooting for a nice durable stainless setup and not so much for performance
  24. Member MrSavvy's Avatar
    Mar 21st, 2011
    Augusta, GA
    20v monster truck
    09-12-2012 11:22 AM #24
    You have an American company, 42DD, who even posts on a user-level here on a VW forum for support. And they have gaurenteed it won't rust. And who is backed up by a majority of forum members here. I think you have your answer.
    Quote Originally Posted by Atlantonius View Post
    I think the seller died.
    ~TheGreatCatTakeover2012~Dat build thread doe~Lace up~
    Forge 007, GHL 3" TB, EuroJet TIP, drive/pass Raxles, ECS Hybrid Oil pan, Samco coolant hoses, P-flo SRI, VR6 Lightweight single mass clutch, Ultimo's, etc.
  25. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    09-12-2012 11:51 AM #25
    magnaflow is an American company. Also, 42DD uses magnaflow mufflers
  26. Member Fastvolks's Avatar
    Apr 30th, 2003
    Somewhere in MA
    MK4 & MK6 GTI • 1986 Audi 4000CS Quattro
    09-12-2012 11:52 AM #26
    Since the OP went with a Magnaflow exhaust I remember reading a article in Eurotuner which they did HP and torque test with several big names at the time 2.5" exhaust and the only one 2.25" which was the Magnaflow but it came out on top, 171.15 HP & 182.97 TQ. Check it out, granted it was on a VR6 but still...
    http://www.eurotuner.com/techarticle...n/viewall.html
  27. Member MrSavvy's Avatar
    Mar 21st, 2011
    Augusta, GA
    20v monster truck
    09-12-2012 01:23 PM #27
    Ah. I didn't read posts since yesterday in this thread. I was just talking about Maegan vs 42DD.
  28. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    09-12-2012 03:46 PM #28
  29. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    09-13-2012 08:11 AM #29
    Magnaflow is an American Co and an established one at that. Even 42 uses their mufflers.
    You can't guarantee aluminized steel will not rust, it will.
    304 marine grade or even the lower grade 409 SS will last longer than aluminized steel.
    Stainless steel is stronger of the two, it' more durable than aluminized steel.
    Stainless steel has a higher tolerance to corrosion. Aluminumized steel will rot if the coating gets broken.
    So yes, the choice is clear.
  30. Member A-Bugg's Avatar
    Oct 24th, 2000
    Ohio
    20AE GTI, 04Golf Wagon, MK2 golf
    09-13-2012 09:34 AM #30
    Quote Originally Posted by Fastvolks View Post
    That might be the complete opposite on a 1.8t. The VR6 needs the backpressure the 1.8t needs the free flowing openness. A larger exhaust on a NA motor isn't always a good thing.
  31. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    09-13-2012 10:00 AM #31
    I also live in NY and my 42DD has seen 2 winters and not one issue. If anything, the very outter edge of the flanges show weathering but nothing else. And mine is NOT coated.
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  32. Junior Member
    May 30th, 2012
    04 GLI 1.8T
    09-13-2012 11:29 AM #32
    Definitely picking up a 42DD
    Sent from my DROID RAZR using Tapatalk 2
  33. Member Einkaufswagen's Avatar
    Oct 25th, 2009
    N Kingstown, RI
    09-13-2012 11:32 AM #33
    Quote Originally Posted by Bierce IV View Post
    Prety much how mine is. 2 winters deep salt, slush, daily driven, and it looks great under there.
  34. Junior Member Hondapicker's Avatar
    Aug 24th, 2012
    Near Syracuse, NY
    2000 Golf 1.8T
    09-13-2012 11:44 AM #34
    Here is my old commuter Civic. The rear quarters were complete, not rotten through when I bought the car, through 3 winters of driving the muck, slushy salt road, this is how it ended up when I was getting rid of it.
    [IMG]
    A lot of guys at work for some reason spend crazy amounts of money on new(er) trucks, only to have them showing elevated signs of rot after 2-3 yrs. The salty roadway, mixed with the moisture from the lake and salt in the air, is a corrosion nightmare.
    I'd rather put my money on the stainless rather than some coating.
    Everyone has their opinion, I feel based on the environment and elevated corrosion, my money was better spent on the stainless.
  35. Member Einkaufswagen's Avatar
    Oct 25th, 2009
    N Kingstown, RI
    09-13-2012 11:58 AM #35
    [IMG]
    Ehh more than likely although your exhaust is "Stainless Steel" it is probably a lower cheaper grade like 409SS which isn’t actually "Stainless" in fact it will stain (Rust) just not as easily and quickly as a straight steel alloy. A ceramic coating if done properly such as 42DD's is still worlds better than a SS exhaust, lighter, more insulated, and completely "Stainless" unless the coating is compromised by removing it. Either way enjoy your exhaust just don’t think its invincible to the elements.
