Results 1 to 20 of 20
Thread: Everyone hates Kinkerstinker passat version
  1. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    92 16v, 97 tdi wagon
    08-25-2012 03:25 PM #1
    Some of you might already know me by this car.
    http://forums.vwvortex.com/showthrea...stinker-thread.
    Well, I ended up buying a b4 wagon to daily. Here are some pics:
    The day I bought her
    and now
    The car has some little rust issues and a water leaking issue that i have yet to figure out, but other than that the 350,xxx mile motor runs like a champ.
    I guess I'll be updating this with questions as i venture deeper into the passat world.
    <---- we are soooooooooo coooooooooooooool
    TRADE FOR MY SHEEP SHOES!
    Quote Originally Posted by tomdooley View Post
    your timing belt should be tighter than kinkerstinker's pants
  2. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    08-25-2012 06:11 PM #2
    meow
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
    Apr 22nd, 2002
    NJ 08002
    2 clunkers & a nicer clunker
    08-25-2012 09:08 PM #3
    Looks good. I'm guessing TDI?
    What did you do to lower it? Spacers in the rear?
    -Todd
  4. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    08-25-2012 09:53 PM #4
    Quote Originally Posted by steveo27 View Post
    meow
    Quote Originally Posted by ToddA1 View Post
    -Todd
    yup it's a tdi. as for lowering, i put on some bilstein struts with 80mm lowering springs and 15mm drop caps in the front. i believe the back are 60mm springs and a 20mm spacer.
  5. Member 91B3DUB's Avatar
    Jul 1st, 2010
    Durham, NC
    91B3PASSAT
    08-25-2012 10:07 PM #5
    nice lookin foward to seein it man!
    pushindubssince'89
  6. Member
    Apr 22nd, 2002
    NJ 08002
    08-25-2012 10:10 PM #6
    Are your corner markers functional? They look different than my nonfunctional Depos.
    Are those 16"s? Offset?
    -Todd
  7. Member max302's Avatar
    Apr 7th, 2010
    TR, QC
    '96 B4V VR6
    08-25-2012 10:54 PM #7
    diesel smogging.
  8. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    08-26-2012 07:50 PM #8
    -Todd
    they are functional but it looks like the amber plastic fell off, or some kind of lens fell off. The wheels are 15's but i have no idea what the offset is. i've had them for years but never looked.
  9. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    09-04-2012 07:28 PM #9
    i guess i can ask this here. my wagon leaks water pretty bad on both sides of the floor whenever it rains hard. i can see water getting behind the headliner right at the front coreners and then the water comes out right in front of the doors. i have checked my sunroof drains and they are not clogged. i noticed that when the windows are up and i close my door the sunroof hops up a little bit. i'm not sure if that is normal or not. does anyone know common places that these suckers leak water around there or common pieces that fail allowing water to drain this way?
  10. Member
    Apr 19th, 2010
    Perkasie pa bucks county
    mk2 gti, 3 mk1 sciroccos, 1 scirocco ll, mk4 gti, vrt b4 passat wagon
    09-04-2012 08:45 PM #10
    It could possibly be the window seal?
  11. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    09-05-2012 10:16 AM #11
    wouldn't it come through the door then? following the trail it acts exactly like it has bad sunroof drains but they all check out. i just don't know what else to look into.
    Apr 22nd, 2002
    NJ 08002
    09-05-2012 10:35 AM #12
    Your roof may be out of adjustment. There are some PDFs online that show how to properly adjust.
    -Todd
  13. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    09-14-2012 10:41 AM #13
    not sure if my mk2 is going to make h2o this year, so i spruced the passat up a little just in case.
  14. Member 91B3DUB's Avatar
    Jul 1st, 2010
    Durham, NC
    91B3PASSAT
    09-15-2012 08:58 AM #14
    sounds like a window, seal if u have checked the drains for the sunroof. the seal around the windshield does and will shrink from weather, but make sure your drain lines are pushed up on the sunroof ends also. also make sure under the hood there is no trash in the drainage area there too. hope that works, car looks good man, passats look dman good with porsche d90s!!!
    pushindubssince'89
  15. Member
    Apr 22nd, 2002
    NJ 08002
    09-15-2012 12:53 PM #15
    Quote Originally Posted by 91B3DUB View Post
    Agreed! Any shots that show the offset from wheel edge to arch? What thickness adapter?
    -Todd
  16. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    12-12-2012 05:10 PM #16
    wow. i haven't updated this in forever. anywho i have since installed coils and gave my gf her wheels back. two nights ago my car stopped shifting into gears. when the car is off it shifts fine (obviously). my first thought was that it was the slave cylinder. replaced it and had a hell of a time bleeding it. finally got it to feel right, fired the car up and all seemed fine. when i backed out of the garage it got stuck in reverse and i was back where i started. i tried to bleed the damn thing again and the fluid was super foamy and i couldn't get all fluid. i'm really hoping i don't have to replace the master because they are way more expensive than i wish lol.
    i thought this pic looked cool
    winter mode
    workhorse
    aaaaaannnnnnndddd my mk2 at h2bro for good measure.
  17. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    01-09-2013 08:23 AM #17
    Well the passat has been off the road for about a month now but i finally got it back on the road. man was i sick of bumming rides to work. any who i ended up breaking my clutch. unfortunately for me i went through the process of replacing the slave and master cylinder first because i couldn't get them to bleed without the fluid being really foamy until i replaced them both. after i finished that up, the car still wouldn't shift and the clutch wouldn't disengage. time to drop the trans. this all conveniently happened right before the holidays so i didn't really have time to do it for a while. but man are these trans' harder to squeeze out and in than my mk2 lol.
    back one is the og clutch fork. it seemed bent and i thought that could be my problem
    but then i found this
    the coil from the spring broke off and wedged between the pressure plate and clutch. the clutch looks like it is the og clutch too. if that is the case i am very please because the car has 355,xxx mile on the damn thing.
    happy maiden voyage!
  18. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    01-09-2013 07:20 PM #18
    woo
    O/R/T
    We Do It Big In PA
  19. Member kinkerstinker's Avatar
    May 9th, 2008
    York PA
    04-10-2013 04:47 PM #19
    havent done any work lately because thankfully nothing had broken since the clutch.
    summer mode.
  20. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    04-10-2013 10:13 PM #20
    :wooo:
    O/R/T
    We Do It Big In PA
