Results 36 to 70 of 76
Thread: Project: "hopeless"
  1. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    92 Jetta 16vt project, 89 Jetta diesel(gone), 01 GTI VR
    10-03-2012 09:33 PM #36
    Quote Originally Posted by slightly stoopid dub View Post
    actually there are quite a few people in the area who are very knowledgeable on the subject. i did a little search and this thread looks to be the most informative on the subject. http://forums.vwvortex.com/showthrea...ht=digi2+turbo
    like i said, either digi1 or obd2 is the way to go. i have a digi1 ecu and harness i'd let go for next to nothing or hit up zeb and i'm sure he can score you the obd2 harness and ecu from coover for pretty cheap. feel free to ask if you have any questions cause i've done a few different wiring swaps and am more than versed in the ways of obd2 turbo setups.
    pm me about the harness and ecu and maybe ill come check it out. im leaning on digi1. and yeah zeb is a good friend of mine, he might actually sell me his ecu and harness since he has bigger and better plans for his car.
    whoah..16vt: http://forums.vwvortex.com/showthrea...-hopeless-quot
    Quote Originally Posted by 90dub View Post
    these pics make me wanna punch baby monkeys
  2. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-03-2012 11:03 PM #37
    got some goods from H2O.
    some teaser shots..wheel fitment
    dont worry the fenders are now cut and ill be sourcing some flares from a local JY
    thanks for stopping by!
    -TJ
  3. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-04-2012 01:49 PM #38
    by the looks of things, ill be picking up some recaro door cards and black carpet this weekend.
    stay tuned
  4. Member candyvr6's Avatar
    Nov 2nd, 2006
    Snow Hill, NC
    85 Mk2 Golf 2dr 1.8 8v, 01 Mk4 Jetta VR6 RIP, 92 Nissan 240sx SE
    10-05-2012 11:33 AM #39
    i gotta tell you, for a 17 year old kid, you got some mad skillz , car looks great, keep up the great work!
  5. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-05-2012 12:14 PM #40
    Quote Originally Posted by candyvr6 View Post
    thanks alot man!
    most people that see or hear what i do or just even talk to me dont belive im only 17, which i think is weird because im pretty sure i look younger than i am,
    oh well
    on another note, my engine is still at the shop. the engine builder said this is the worst time of year for them
    but he reassured me that it should be done VERY soon!
  6. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    92 monty green gti, 91 audi 80 quattro
    10-05-2012 01:36 PM #41
    Looks good man keep up the progress.
    -Corey
    Quote Originally Posted by Moonequipt13 View Post
    The better question would have been is there anyone running a 15x8 with a properly sized tire
  7. Member candyvr6's Avatar
    Nov 2nd, 2006
    Snow Hill, NC
    10-06-2012 11:39 PM #42
    Quote Originally Posted by riceslayer View Post
    thanks alot man!
    oh well
    not a problem, some ppl start very young , i started at 16 myself, 12 years later i'm still doing it and making a living off of it, the greatest part is its not work, because i love what i do, keep at it and before you know it you won't need an engine shop you can do it yourself good luck with the build, i'm staying tuned
  8. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-10-2012 08:16 AM #43
    i know ive slacked alittle on updates but i assure you i havent been slacking on the car. i picked up a digi1 harness and began swapping them out. as i unplugged the digi2 harness, i plugged in the matching plugs on the digi1 harness.
    when i had the digi2 harness completely out i looked at what i had left. the digi1 harness has a few more little plugs than the digi2 so i started matching up. i figured out two of them but i cant seem to find any place for the last 3.
    can anyone help me out with this?
    Colors in order from left to right: orange/white, purple/black, blue/white
    if there are any digi1 guru's out there PLEASE help! im going to do some other research to try to figure out what these are. as soon as i know i can start the wire tuck
    Thanks for reading!
  9. Member SLC4ME's Avatar
    Apr 16th, 2001
    Dundee, Oregon
    93 corrado, 00 jetta, and a few dragbikes.
    10-11-2012 05:58 PM #44
    what did you use to paint it?
    Spoon fed need not apply
  10. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-13-2012 02:41 PM #45
    Quote Originally Posted by SLC4ME View Post
    paint gun and 150psi compressor. my dad paints plenty of stuff so he had the whole setup.
  11. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    10-14-2012 03:44 AM #46
    Digi 1 sucks, I've been down that road. To the point where I was making my own files, burning chips and could never get it to run right.
    Went ms1 with spark and haven't looked back. Ive got a ton of info if you want to pm me for the specifics.
  12. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-14-2012 09:17 PM #47
    Quote Originally Posted by Dave926 View Post
    im eventually planning on ms but i cant seem to find a setup even relatively close to what i can afford at the time. the digi1 was local and didnt cost me much at all so i figure even if it doesnt run well at first, itll be some good practice with wire tucking. atleast until i can afford standalone
    id have more updates, but im still waiting on the engine shop to spend the whole 2 hours to put the IM shaft bearings in.
  13. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    10-15-2012 04:14 PM #48
    At the very least make sure you get a 16v specific file, as they run way less timing due to a more efficient head design. Running a 16vt with an 8v timing map is a good way to put pistons in your oil pan.
  14. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-15-2012 09:38 PM #49
    all ready have a BBM stage 5 chip burned for 16vt's and 42lb injectors on the way
  15. Member Kenner8v88's Avatar
    Jun 14th, 2005
    MD
    93 vrt corrado, 81 diesel caddy
    10-23-2012 12:01 AM #50
    I'm the smoke for tits dude lol I also run ms1v3 with spark on my vrt Corrado. I've played around with g60's with chip tuning on digi 1 and I would definitely go with something a little more sofisticated.
  16. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-23-2012 07:15 AM #51
    dont worry, i do plan on it
  17. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-23-2012 08:56 AM #52
    just collecting some parts here,
    quick release
    nearly mint dash
    and for those with doubt
  18. Member Ziptied's Avatar
    Dec 1st, 2009
    Campbellsport, Wisconsin
    91 gti with six cylinders / 83 jetta turbo diesel / 98 jetta tdi
    10-25-2012 11:42 AM #53
    Is that one of those super cheap ebay quick releases? let me know how you like it
  19. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-25-2012 11:50 AM #54
    Quote Originally Posted by Ziptied View Post
    the $15 had me sold on it. it seems to work well but it will be alittle while until i actually drive with it. came with all the hardware and the allen wrenches ill get a pic once i get my hub and everything installed
  20. Member DMehalko(DM)'s Avatar
    Nov 1st, 2004
    USA
    2009 Jetta 2.5L, 1988 GTI
    10-25-2012 11:58 AM #55
    Are those red wheels konigs?
    2009 Campanella White Jetta 2.5L
    2000 Jetta GLX PROJECT
    2001 GTI VRT (Sold )
  21. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-30-2012 09:31 PM #56
    Quote Originally Posted by DMehalko(DM) View Post
    no, theyre rotas.
    progress has been alittle slow, but its all for a good reason. Picked up an 89 jetta diesel today for a good price. i need a sign that says smoke for tits
    i would have pics, but photobucket isnt agreeing with me right now
  22. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    10-31-2012 12:04 AM #57
    anymore info on the hub? link?
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  23. Member Ghost''s Avatar
    Aug 6th, 2008
    KTM
    10-31-2012 08:51 AM #58
    like where this is going
    .:Let no man who is not a VAG owner judge the elements of my ride:.
  24. Junior Member slaughter555's Avatar
    Aug 22nd, 2012
    Oakville, Ontario
    2001 1.8t jetta
    10-31-2012 09:10 AM #59
    Amazing thread, im in the same boat as you, 17 with a mk2 jetta as a first car. Good luck with the build man!
    Sent from my jetta
    RedLine Goods, the finest in leather accessories for your car!
    http://www.redlinegoods.com/cgi-bin/...r&id=1&aid=806
  25. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-31-2012 07:33 PM #60
    Quote Originally Posted by steveo27 View Post
    the hub is 'a little' bit of a pain, because it has to be in a certain spot to put it on. but once you get used to it, it is actually pretty cool. i think it works alot like an NRG but ive never seen one in person so im not sure. just go on ebay and search "quick release hub" theres a bunch to choose from.
    on another note..... 89 jetta diesel content
    enjoy!
    -TJ
  26. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    10-31-2012 07:42 PM #61
    Thanks Lookin for one for my Nardi wheel for my girlfriend's car.
    O/R/T
    We Do It Big In PA
  27. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    10-31-2012 07:48 PM #62
    should fit well, i mounted an Isotta wheel to it with no issues. they include all the hardware and allen keys
  28. Member DMehalko(DM)'s Avatar
    Nov 1st, 2004
    USA
    11-06-2012 11:58 AM #63
    Updates?
  29. Member Radmz's Avatar
    Oct 15th, 2012
    Nazareth, PA
    1999 cardboard box gt.
    11-22-2012 10:14 PM #64
    updates you whore!
    Quote Originally Posted by snowyroads View Post
    No no, the bumpers on the inside make the impact feel like your throwing your face into a pile of jello. unlike on the outside.
    wait.......
    i dont even drive
  30. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    11-25-2012 08:20 AM #65
    Updates?
    Quote Originally Posted by Radmz View Post
    updates you whore!
    actually i just picked the motor up from the engine shop two days ago. updates will be coming soon.
    also, i need to find an 020 ABA trans..
    sorry about the wait!
  31. Member skateboards and mk2s's Avatar
    May 16th, 2006
    CO
    85 audi coupe, 85 audi 4000, 85 GTi, 87 scirroco, 87 golf GT, 96 GTi, now 85 Golf.
    11-25-2012 11:31 AM #66
    Should be super quick and fun. Ever get the paint fully finished? How about some outside pics?
  32. Member Radmz's Avatar
    Oct 15th, 2012
    Nazareth, PA
    11-26-2012 01:10 AM #67
    wait.......
    i dont even drive
  33. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    11-26-2012 09:49 PM #68
    Quote Originally Posted by skateboards and mk2s View Post
    im going to take my time wiring since its my first attempt at a tuck. im only hoping it will be fun! i havent even rolled it outside yet to see it in the sun. its been blocked most of the time by one of the other volkswagens in the growing family of cars at my house
    ill see what i can do though, just for some viewing pleasure.
  34. Member FTW201's Avatar
    Oct 17th, 2011
    Pittsburgh pa
    1987 mercedes 190e, 1992 mercedes 190e c36 wald, 1993 mercedes 190e sportline, 1992 Volkswagen gti
    11-27-2012 12:07 PM #69
    still looking for a trans? my buddy has an 02a from a g60 for sale, $175.
    pm me if your interested. located south of pittsburgh pa.
    Balls Deep Squad.
  35. Member riceslayer's Avatar
    Feb 15th, 2012
    17202, PA
    11-27-2012 12:10 PM #70
    Quote Originally Posted by FTW201 View Post
    thats actually in my price range but im not looking to swap to cable shift and hydro clutch. id like to just pick up an ABA 020 because i need the 24mm shaft and longer gears.
