Results 1 to 9 of 9
Thread: Question about removing crankshaft bolt
  1. 08-25-2012 11:53 PM #1
    hi i saw in you tube a trick to remove the crankshaft bolt ,the guy put a rope in the hole of the cilynder one sparkplug ( to hold. Piston),is this right? Can i damage the piston or its ok?
    Regards
    Nov 17th, 2001
    Northern Wisconsin
    08-26-2012 09:02 PM #2
    Why are you trying to remove the crank bolt?
    It doesn't need to be removed to remove the crank accessory drive pully to change a timing belt although sometimes it appears that the pulley is held on by the center bolt.
    I have used the rope in the sparkplug hole trick without causing engine damage but I suppose you could fracture a piston at a ring groove or damage something else using that method. FR
  3. 08-26-2012 09:26 PM #3
    Ok thanks what i was tryingto do is to change the crankshaft oil seal
    Regards
  4. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    Newest, 92 GTi half-swap plus
    08-27-2012 07:04 AM #4
    Quote Originally Posted by RARCGTI View Post
    Regards
    It's a good trick for holding the valves in place to replace the valve stem seals, but I would not put that kind of pressure on the piston.
    Thanks for calling. Your call is very important to me. If you would like to reach me by phone now, please hang up now. If you would like to reach me by phone later, please hang up later. If you would like to speak with a person, please press ten. ..... I'm sorry I do not understand one zero. Please hang up now or later if you cannot press ten.
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    08-28-2012 03:30 AM #5
    rest a wrench on the ground and give the engine a quick crank.
    I really suck at smog.
  6. Member Mtl-Marc's Avatar
    Sep 13th, 2006
    Montreal, QC
    Sciroccos
    08-30-2012 10:52 AM #6
    Quote Originally Posted by ziddey View Post
    Depending on the year, the crankshaft bolt can be held really tight, 175 fl/lbs, or have some loctite.
    It is a stretch bolt, so if you remove it, you replace it.
    Get the oil pan out, and wedge some piece of lumber in the crankshaft to prevent it from turning while you get the bolt out.
    The procedure is in the bentley.
    Sent using smoke signals.
  7. Member respect_my_fast's Avatar
    Nov 18th, 2007
    Lynn MA
    95 rodeo: 86 golf: 01 kidcarrier van
    09-01-2012 07:52 PM #7
    i wedged a screw driver inbetween the allen bolts on the pulley and used an electric impact gun.
    "Why did you do that?"
    " I dunno, because is cool?"
    "Your an idiot"
    -FossZ
  8. Junior Member
    May 15th, 2010
    Harrisburg, PA
    1983 Rabbit GTi
    09-06-2012 11:31 AM #8
    If you use a rope through the spark plug hole, and use that to hold the crank from spinning as you apply force to remove the crank bolts, you will not exceed the forces the piston, rod, and crank see under high speed full load operation. Not even close. Just make sure that the rope doesn't fray alot and leave material left over in the combustion chamber, otherwise it will be burned and hopefully find its way out the exhaust valve without getting caught and holding the valve part open or getting caught on the stem in the exhaust port. Even then, it would eventually burn off.
    This trick is used for holding valves from dropping in while changing guide seals with the head installed on the engine.
    I have also personally used a flat head screwdriver through the bell housing onto the flywheel ring gear to lock the engine while i removed the front crank bolt. A little shaky I know, but it worked.
    Mar 31st, 2008
    PNW - Oregon
    09-06-2012 07:22 PM #9
    personally, i use engine oil, or water to hold the engine from turning..
    fill the cylinder (with the valves closed) with oil, and re-install spark bolt..
    works like a charm, and oh boy, does the engine smoke like a bitch when you first fire it up! lol..
    the rope trick is much cleaner, but the oil trick exerts even force on the piston crown and rings/ring lands..
    and a fairly good sized impact gun as well.. i just use my 1/2" gun..
