Yes, it's most likely the injectors. They are supposed to sound like that.
#1
So my friend recently bought a 2006 passat 2.0 turbo. He says the engine has a distinct tapping and that it almost sounds like a Diesel. Is this relatively normal? It has 102k miles on it.
#2
2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
2008 Touareg VR6
#4
the FSI engines sound loud.. should sound like a Diesel as it also uses Direct Injection like a Diesel.
Oh tell your buddy to check the cam follower.. do a search as you can get all the info from better resources than me.. but this will kill a 2.0T (cost $$$ to fix)
JT
Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
#5
I had the same problem... does it only make the noise once it has warmed up? I had to replace the cam chain and tensioner.
#6
Hmm, maybe I need to add that to my list of things to do. Is there a way to check the tensioner?
2008 Touareg VR6
#7
people should really specifiy that the injectors should be loud/similar to diesel injectors. not the rest of the engine/exhaust. they have an almost knocking sound.
a loud ticking from injectors=normal
knocking sound=BAD
