Results 1 to 5 of 5
Thread: stalls / CEL going down extremely steep hill
  1. Member J. Reed's Avatar
    Mar 28th, 2011
    Maryland
    05 GTI 1.8T, 07 GTI FSI
    08-26-2012 02:37 PM #1
    this was an ungodly steep incline going down into a garage. like \
    I had over half a tank of gas.
    I was easing down onto the level road, as to not scrape, I had the clutch completely depressed and the car stalled.
    When I restarted the car it took a while to turn over and came on with the CEL.
    It's gone now. car starts fine ever since I left satan's garage.
    Think it was just confused about the fuel for a little bit given the incline?
    never had it happen..
  2. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    08-26-2012 06:25 PM #2
    Makes me think there might be some cut off in case the car rolls or something? Prolly have to be a hell
    Of an angle for that though.
    Is the fuel pickup in the front or back of the tank?
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | AWE DV | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
  3. Member J. Reed's Avatar
    Mar 28th, 2011
    Maryland
    08-26-2012 08:19 PM #3
    Quote Originally Posted by Tutti57 View Post
    I'm wondering the same thing.
    It was STEEP.
    The cutoff in case it rolls thing makes sense.
    I mean in mk4s next to the moon roof there's an allen key for cranking it open if you go under water. Ha
  4. Member xtravbx's Avatar
    May 21st, 2005
    08 FSI GTI, 09 TSI GTI
    08-31-2012 02:20 PM #4
    Quote Originally Posted by J. Reed View Post
    It was STEEP.
    That's in case the battery dies and you need to manually close the roof, not for if you go under water
  5. Member azunderg's Avatar
    Apr 29th, 2009
    85006 | Garfield District
    MK5 GTI|Fixie|Light Rail
    08-31-2012 05:08 PM #5
    Phoenix DMZ
    The Ghetto
    New South | Neuspeed | ECS | Optima
