I first would get the complete service history of that V10 and if you can't I would seriously walk away from it. The mileage is not bad, but if certain things on it were not repaired yet or have gone out, you could be looking at a serious repair bill. There are certain repairs the require dropping the motor to take care of, no way around it. That cost alone is in the 2K range. If that in of it's self scares you then this may not be the vehical for you. Short list of known repairs is turbos and it is best to do them both at the same time since this is one thing that requires a motor drop. O2 sensors that can't be reached any other way other then to drop the motor. Tranny valve body which is a common repair to all of the Touaregs. The center drive shaft bearing. So knowing these few items if you still want one then by all means go buy it. The V10 if you have never driven one is a beast of a motor with over 500 ft lb of torque. You just need to be ready if other things go wrong.
(moderated for content)
