Results 1 to 17 of 17
Thread: Just wanting to confirm with the gurus (car died while driving home)
  1. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    08-27-2012 05:59 PM #1
    So as I was 3 blocks from home, my car just stopped running. I turned the key off then back on and the car "started" but was running real lumpy and I don't think even with flooring the accelerator it got over 500 rpm. So once I got the car to a safe parking lot I went down and felt the relays and one labeled "67" was rather hot. I assume this is the fuel pump relay and that I should order a new one?
    I'm a mechanical engineer, not a mechanic. I know why it works, not how.
  2. 08-27-2012 08:00 PM #2
    Here is a picture, from an earlir thread re: Mk1 Sciroccos btw.
    The two positions to jumper are larger than the other two 'trigger' positions. It's the larger of the four that carry the higer current to the Pump, it's the smaller two of four that are the Relay Trigger posts/sockets.
    It's sometimes useful to be able to jump around a suspected faulty Fuel pump Relay, but this is only a temp measure to be sure- this thing will keep the pump running disregarding the Ignitian Switch position.
    Note:In-Line Fuse, In-Line Fuse, In-Line Fuse.
    I tell you three times.
    Gas is a dangerous thing, proceed w/ caution, disclaimers apply, Bob's yer Uncle, and God didn't make Little Green Apples.
    Threadthat the above picture pertains to...
    http://forums.vwvortex.com/showthread.php?4038830/page1
    Also, since it's a 16v, I'd think verifying your TIMING hasn't jumped a tooth, hasn't begun to shear it's Crank KEYWAY, and/or other nefarious 16v unpleasantness...
  3. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    08-27-2012 10:25 PM #3
    I just the car back to my house. It started up with no hesitation and idled perfectly around 900 rmp. Drove it the two blocks back with no problems. I already put in a order with GAP for a new relay and see if that fixes it. If not then I guess I will move to testing the pumps.
    Since this has happened to me. It makes me wonder if my split second stall that happened about two weeks ago was because the relay was failing. I had a large open road so I floored it and the car basically shut off very quickly and then came back on. I haven't driven it much since that stall, as I thought it was an electrical thing not getting enough power to the spark plugs. In fact I have spent the past few days looking into redoing all of my major wires and grounding everything I can.
  4. 08-28-2012 12:49 AM #4
    One thing that mashing the pedal does is rock the motor on it's mounts. This can open up an otherwise closed air leak somewhere.
    Also, gas tanks, pumps, and pickups can be susceptible to the force, G-Force that is, w/ crap in the tank and/or swiss-cheezy pickups causing an otherwise OK pump to overwork.
    There's some testing to be done here, you're going to want to see all four spray pattern (esp when you raise the ), a multimeter to see what voltage and resistance are like, and that jumper s pictured in the pic above. Remember, In-Line Fuse.
    It's a drag but this has happened to somebody before, and they fixed it. They prob. had a Bently at hand too...
  5. 08-28-2012 12:49 AM #5
    (Hey, where are the guru's?...)
  6. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    '78,81S,TTQ,S2 8V, race Corvette
    08-28-2012 11:37 AM #6
    1. WHY is the relay hot?
    2. Have you checked for oil inside the distributor....ahhh! 16v's twice the cost, half the reliability.
    3 fuel filter (S)
    4. Booster pump screen clogged as well as the transfer tube....classic symptoms.
    5.Ground wiring to pump
    SOMETHING is making the relay hot. Having a spare relay is good....finding out WHY it is failing is BETTER!
    vacuum leaks generally make the engine RUN FASTER...for a while.
    The feeling of immortality extends right up until the moment of impact.
    I cannot teach you how to be a Zen mechanic, grasshopper.
    The VW Scirocco, the worlds fastest ECONOMY car.
  7. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    08-28-2012 04:13 PM #7
    Quote Originally Posted by sciroccohal View Post
    3 fuel filter (S)
    When I replaced the distro cap a few months ago there there was no oil in the old one. But I will keep that in mind and see, since it takes just a minute to take off and on.
    Edit*
    The distro cap as of today. Just some gunk on the edge of it nothing touching the points
    Fuel filter was also replace about 2 months ago
    Booster pump and transfer tube will be the next thing to look at if a new relay doesn't solve the problem. That really isn't what I need right now.
    Grounding the outer pump is a good idea.
    I had the car smoked at a shop about 3 months ago they they fixed the 2 tiny vacuum leaks that they could find. All of my vacuum lines are pretty new.
  8. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    08-28-2012 05:56 PM #8
    there are two things (at least!) that'll stop a 16 v in it's tracks;
    1. faulty dying quail ignition switch.
    2. Fault seal in the distributor.....you've eliminated this one.....see above.
    good luck.
  9. Member alteschule's Avatar
    May 30th, 2008
    Missouri woods
    77 Roc,75 Roc
    08-28-2012 07:13 PM #9
    Each time the relay is energized...contacts inside touch each other...just like an old school set of ignition points...after hundreds,or thousands of activations,the contacts get burned,creating resistance..(heat). Try a new relay and see if it doesnt get hot...duh!
  10. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    09-05-2012 10:02 PM #10
    Well I would post up a pic of my old relay, but photobucket is giving me hell. So anyway when I pulled the relay I found one of the terminals was really discolored and blacked. Hopefully the new relay will fix it.
  11. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    09-07-2012 12:14 PM #11
    Well unfortunatly the relay didn't fix it. Yesterday when I was driving I hit a bump in the road and it nearly stalled me out. So I guess the next step is look at the in tank pump, because it runs fine most of the time and then at random to starves out of gas.
    And I have just under half a tank of gas, so I know I'm not out.
  12. Member Teighlor O''s Avatar
    Aug 18th, 2011
    Cleveland, Ohio
    88 Scirocco 16v
    09-07-2012 01:48 PM #12
    Quote Originally Posted by Blaines_Rocco View Post
    Ignition switch?
    I wouldnt hurt a fly. Unless it kept buzzing around in my face, and annoying me.
  13. Member scirocconaut's Avatar
    Oct 7th, 2011
    Dallas/pdx
    1979 16v mk1 scirocco S model black with roof rack and no sunroof :)
    09-07-2012 04:48 PM #13
    Have you replaced the fuel filter?
  14. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    09-07-2012 07:15 PM #14
    Quote Originally Posted by Teighlor O' View Post
    Ignition switch?
    Blaine.....disconnect battery.
    Get comfortable in the foot well
    pull relay plate...fusebox
    one by one pull the big plugs from the BACK of the box....check CAREFULLY.
    If you see a burnt pin...fortunately it has a number on it.
    The plugs are lettered A,B etc the the pin has a number on it.....So something like A13
    Look up in Bentley as to what the number goes to. It's on the wiring diagram.
    Look at all the other spade connectors.
    Check the main engine grounds...Especially the one behind and below the battery to the inner fenderwell and to the tranny..it will not run with a bad ground..
    The smoking gun here is when you hit a bump it intermittently goes OFF.
  15. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    09-07-2012 09:46 PM #15
    Funny you should mention the grounds by the battery... since in one of my threads last week I mentioned I am replacing my cables
  16. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    09-07-2012 09:47 PM #16
    Quote Originally Posted by scirocconaut View Post
    Fuel filter was changed in late May
  17. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
    09-07-2012 10:06 PM #17
    I had a over loaded fuse block(fuel pump relay),and yes when I hit a bump it would stall(8V),.Reach down touch the relay varoom away we go.
    E Rear Wiring Harness Black
    E01 License Plate Lights, Luggage Compartment Light (Cabriolet) License Plate Lights, Fuse 20 Gray/Green
    E02 Rear Wiper Motor Rear Wiper Relay Output Green/Black
    E03 Luggage Compartment Light, Interior Light, Central Locking System, Diagnostic Connector (Cabriolet) Main Fusebox Battery Power, Fuse 3 Red
    E04 Water Separator Sender Glow Plug Light Blue/Green
    E05 Fuel Level Sender Fuel Gauge Violet/Black
    E06 Turn Signal, Left Rear Turn Signal Switch, Left Black/White
    E07 Windshield and Rear Washer Pump (only on cars with rear wiper, ground when washing front, positive when washing rear), Rear washer Pump (Scirocco) Rear Wiper Relay Green/White, Green/Red (Scirocco)
    E08 Rear Wiper Park Switch, Water Separator Sender (diesel) Main Fusebox Run Power, Fuse 12 Yellow/Black, Black/Yellow (diesel)
    E09 Parking Lights, Left Rear Parking Lights, Left, Fuse 7 Gray/Black
    E10 Rear Fog Light (Europe Only) B2 Green/White
    E11 Turn Signal, Right Rear Turn Signal Switch, Right Black/Green
    E12 Back-Up Lights Back-Up Light Switch Black
    E13 Parking Brake Switch Brake Warning Light Gray
    E14 Fuel Pumps, Aux. Air Regulator, Control Pressure Regulator Fuel Pump Relay Pin 3, Fuse 5 Red/Yellow and Red/White
    E15 Rear Window Defogger, Heated Mirrors Rear Window Defogger Switch White or White/Green
    E16 Brake Lights C1 Black/Red
    E17 - (no pin) -
    E18 Parking Lights, Right Rear
    **>The black plug,on the the back of the fuse block,<**
    Note E14 says fuel pumps there are 2 pumps running off of 1 relay,This is why I am running a a bottom feed fuel tank.
