VWVortex.com - why don't new cars have a "panic" button?...
    The Car Lounge
    Page 4 of 5 FirstFirst 12345 LastLast
    Results 76 to 100 of 110
    Thread: why don't new cars have a "panic" button?...
    1. Member x_GTI_x's Avatar
      Apr 23rd, 2008
      MA
      Bagged BMP 20th - 1990 Cabriolet with no heart.
      08-28-2012 05:08 PM #76
      Quote Originally Posted by Air and water do mix View Post
      We're not that far apart on our views on this particular subject, but long ago I realized that things on my list of "things I'd like to see happen" and the general list of "things that will never happen" were nearly the same list!
      unfortunately thats very true.
      I didnt think i was old enough to want "the old days" back already.
      No. Smell has a very strong connection in the brain with feelings... or if you're walking past A&F you might think of that chick you fingerblasted when you were 15.
    2. Senior Member @McMike's Avatar
      Oct 9th, 2002
      Northern part of the Virginia
      German Vans and sporty British stuff
      08-28-2012 06:30 PM #77
      This thread is called "why don't new cars have a panic button". It is not called "why don't you need a panic button". I'm actually quite glad it's not a big deal to you, as it shouldn't be. It wasn't to me either when it happened on my '62 Beetle with about 70 hp (this was a 1650 lb car).
      I went for the 1-2 shift and when I did, the engine screamed well past what I was happy with and my reaction was to slam it in second and dump the clutch, as my hands and feet were poised to do so. I still don't think I had enough time to reach up and shut off the ignition switch before the engine grenaded itself. After I shifted into second, I reached up, shut off the switch and coasted into a Hardee's parking lot. The throttle spring had evacuated the entire region. (It was a Baja with an open engine compartment.) I walked into the Hardee's and asked for some rubber bands to fix my Volkswagen. (The girls reaction was priceless. ) I limped home and always carried a spare in the ash tray after that, but never needed one again. (so far)
      What does that have to do with this thread, though? Absolutely nothing.
      I once ran into that with my first van.
      Cold, slushy winter. Coldest morning I can remember. Idling in first and second to get off my street. It wasn't until I reached a main road until I ran into trouble. As I got going, I had just shifted to second and opened the throttle more and then it stuck. Being 4am, I was still pretty sleepy. Still puzzled, I shifted to third. When it redlined before I could engage the clutch, I thought, "Oh siht."
      I tried to pull the throttle up with my toe - no luck.
      I started braking a bit - no luck
      Still accelerating, I shifted quickly to 4th - started panicking.
      Came to red light to make a left - stand on brakes and slow it up enough to make the turn.
      Finally came to my senses and realize that I can just shut off the ignition to slow the car down.
      Continued all the way to work by using the ignition key to kill the throttle to shift and control speed. The only problem was is that on older VWs, the lights go out with the ignition.
      About half way to work, things heated up enough to free the cable.
      Even thought I know how how vehicles work, it still took me some time before I realized I Was in trouble. I have now quizzed everyone in my family (again) on how to survive something like this.
    3. 08-28-2012 08:04 PM #78
      Quote Originally Posted by VwG60Kid View Post
      with all of these stories of unintended acceleration (mostly due to floor mats) wouldn't it make sense to have a button that cut fuel, put it neutral, put on the hazards, and gradually applied the brakes to stop the vehicle?
      i swear... generation of kids these days have no sense of responsibility.
    4. 08-28-2012 08:28 PM #79
      The button makes 100% sense to have, if it worked properly and safely, people were trained on it and it itself never failed.
      Issue is at work I have error messages that pop up when someone does something wrong.
      Pretty much "Are you sure you want to do this..."
      Due to a high level amount of people just clicking "YES" on the screen without reading the error I added an "Are you sure you are sure..." message after they clicked YES on the first message
      How many people clicked through the new error message without reading...100%.
      Goes to show you can do whatever you can to try and help...but people will always find a way to work around or not follow directions or just not have common sense.
      I used to help everyone do anything, then realized I am nothing more than a crutch for a lot of people. Remove me and they are back to their old ways.
      By adding a Panic button you are not changing driver knowledge, behavior or ability...you are just giving them a crutch and requiring them to think less. Two things I don;t want to do for already crappy drivers.
      Aug 17th, 2012
      The thin part of the Land of Potatoes
      2013 Kia Forte SX sedan
      08-28-2012 08:51 PM #80
      I personally cannot wait for the day cars drive themselves. Why? Because it will remove the single biggest cause of accidents: the driver. That's what we're headed for, and I am grateful. I cannot wait for the day I can begin my vacation by punching in my destination, reclining my seat, and sleeping until I get there.
    6. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      08-28-2012 09:57 PM #81
      Quote Originally Posted by urbanrocketeer View Post
      Why not the transporter from the Enterprise then? Why are you even on a car forum?
    7. Member MCTB's Avatar
      Dec 30th, 2005
      The Northern of Virginia
      '12 Focus SE, '15 Outback Limited
      08-28-2012 10:07 PM #82
      Quote Originally Posted by IridiumB6 View Post
      Yeah, it's called putting the car in neutral, turning on the hazards, and easing up on the E-brake or coasting to a stop.
      Any moron with a brain should possess the necessary capabilities to this..but apparently that's asking too much these days
      Or just turn it off?
      People are crazy and people are stupid. There are reasons why cars are becoming more and more technical. Remove as much from the people as possible.
      Looking for a car event on the East Coast? Check here
      I have an idea, we will try it my way first...and then we will finish.
      Pictures Ive taken of stuff
    8. Member .:FrankRizzo:.'s Avatar
      Jul 12th, 2008
      Conshohocken, PA
      '84 GLI, '12 GTI, '94 Miata
      08-28-2012 10:59 PM #83
      All these people speeding out of control claim they try turning off the car...
      Manual transmission (push the clutch in and you stop accelerating) and a real key (glad I didn't get an autobahn package) fo' life.
      IG: t_wick_
    9. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      08-29-2012 12:25 AM #84
      Quote Originally Posted by McBanagon View Post
      No, not on older ones, they didn't start that until '71!
      Oh, I was wide awake when mine happened. Especially during and just after the event!
    10. Member IridiumB6's Avatar
      Nov 29th, 2010
      Toronto, Canada
      2014 Rogue SL, 2008 XC90 3.2, 2012 Golf 2.5
      08-29-2012 03:12 AM #85
      Quote Originally Posted by MCTB View Post
      Turn it off? And lose steering control? I don't think so.
      Quote Originally Posted by DRUB View Post
      What just cause Im new.
    11. Senior Member @McMike's Avatar
      Oct 9th, 2002
      08-29-2012 06:15 AM #86
      It was an '85. For a few minutes, it was flip the key, take a good look at the road ahead, and then turn it off.
      I had two choices. Fast and furious, or blind and curious.
      (raises hand) I think I found the problem. People just don't know how cars work anymore.
    12. Member PlatinumGLS's Avatar
      Aug 2nd, 2003
      Shelby Township, MI
      7.4, 5.7, 5.3 & 3.0TT
      08-29-2012 10:22 AM #87
      You only lose the power assist which doesn't matter unless you are going parking lot speeds.
    13. Member thetwodubheads's Avatar
      Dec 6th, 2004
      13 Tiguan, 12 Golf TDI, 12 F-150 Eco Boost
      08-29-2012 11:24 AM #88
      Really. It's not a tractor with fully hydraulic steering. As long as people know there is an ACC position to the key so they don't lock the wheel
    14. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      08-29-2012 11:48 AM #89
      See, that's what I'm sayin'. My car was almost 20 years old when yours was built!
      Indeed.
    15. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      08-29-2012 11:50 AM #90
      Quote Originally Posted by PlatinumGLS View Post
      I think he thinks that if you turn off the car, the wheel is locked.
      For those that might not know, the lock mechanism isn't engaged until you pull the key out.
      I assume it's solenoid operated if it's a push button start car, correct? That's not creepy at all, is it?
    16. Member Dr. Woo's Avatar
      Feb 28th, 2003
      Hampton, VA
      '03 S2K '16 GTI S
      08-29-2012 12:39 PM #91
      I think the real problem is electronic shifters that won't shift into neutral at speed. Seriously, what on Earth is the point of that? It completely eliminates the threat of a stuck pedal. That's just horrible design, and I find it borderline unbelievable.
      Every automatic I've ever driven allows you to bump the shifter up from D into N without engaging the lock. Even column shifters. It seems stupidly obvious to me. Just pop it into N, start braking/coasting, and hit the flashers. Crisis averted.
      Of course, many automatics now cut off accelerator input when the brake is depressed, so...yeah.
      ├┼┤2003 S2000 | ├┼┤2016 GTI S | 2015 Fit EX (2014-2016) | 2012 Focus SE (2011-2014) | 2009 G8 GT (2011-2011) | 2008 R32 (2007-2011) | 2006 GTI (2006-2007) | 2001 A4 (2002-2006)
      SAVETHERING
    17. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      08-29-2012 12:43 PM #92
      Quote Originally Posted by Dr. Woo View Post
      Yeah, but that's computer controlled, too.
    18. Member 1.8 skeet skeet's Avatar
      Aug 11th, 2004
      VA
      2013 TTRS Panther Black Pearl
      08-29-2012 12:47 PM #93
      When people panic, logical thinking goes right out the window
    19. Senior Member @McMike's Avatar
      Oct 9th, 2002
      08-29-2012 01:05 PM #94
      WTF is this witchcraft? Neutral is not available while in motion? I understand that 99% of the appliance drivers out there have no idea what "N" means, but that's no reason to make it unavailable.
      Speaking of unavailable, are gear selections even available if the battery is dead in these modern fancy vehicles?
    20. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      08-29-2012 01:15 PM #95
      That's an excellent question. Hopefully there's some lever or some such you can hit, but you'd have to know about it for each and every car. NYAAAAAAAAARRRGH!
    21. Member
      Sep 15th, 2001
      The PNW
      2012 CW Golf TDI w/Tech, 2007.5 Ram 2500 CTD 6MT QCLB, 2013 Evil Undead, 2008 Summit X (x2)
      08-29-2012 02:16 PM #96
      I'm not against the idea.
      The more new methods we invent to turn cars on/off the more this makes sense. Some people are useless when panicking - the simpler the answer, the better.
      However, including all your mentioned in that switch would be further complicating things. just cut fuel, ignition, or simply have it be a main battery cut-off, and shut it all down.
      These are in all of the work vehicles that I'm ever in. It makes sense due to the nature of the vehicle but in all my time I only know of one that has ever been used. I was driving and the guy in the passenger seat thought it would be funny to hit it. I wasn't amused. It's just a switch that cuts the main power to the ECU so it didn't really hurt anything except that it prevented a proper write cycle that normally happens during an ECU power down.
      Lately I have been testing "tip-in events". Just the tip-in. Just to see how it feels. Response time is typically on the order of 2-3 seconds. Sometimes the injection timing is a little off...
    22. Member
      May 15th, 2007
      Wilmington, DE
      2012 Jeep Wrangler
      08-29-2012 02:50 PM #97
      It sounds easy to write about it here, but a panic manuver needs to be practiced regularly before it becomes instinct in practice.
      When was the last time you dropped your automatic trans car into neutral at highway speeds? Probably never.
    23. Senior Member @McMike's Avatar
      Oct 9th, 2002
      08-29-2012 03:00 PM #98
      Quote Originally Posted by Jason4 View Post
      When I was a teenager, my buddies used to do this to each other as a prank. Turn the key off while driving, and start laughing as the driver figures out how to get the car started again while in traffic.*
      Later in life, some motorcycle friends would reach other and hit the kill switch on bikes as soon as the light turned green.
      A$$holes will be a$$holes no matter what kind of kill switch they have available to them.
      -edit-
      *which was great training for unexpected mishaps. Maybe driver's ed teachers should throw drivers certain scenarios during their tome together.
      What kind of situations would you throw at a learning driver to train them for their career behind the wheel?
      1. Turn car off?
      2. Throw car in neutral?
      3. Scream?
      4. ???
      What else?
    24. Member
      Sep 15th, 2001
      The PNW
      08-29-2012 03:12 PM #99
      That's true and I probably deserved it. I've been known to set e-brakes and slip transmissions into neutral at stop lights before. I expected I would have grown out of it but the last time I did it I think I was 29.
    25. Member IridiumB6's Avatar
      Nov 29th, 2010
      Toronto, Canada
      08-30-2012 03:53 AM #100
      In a time like that, I'd much rather have the full steering capabilities my vehicle can offer, even at low speeds steering can be vital. If I really cant shift into neutral and coast then yes obviously I'd turn it off
