VWVortex.com - Autotech HPFP Upgrade full DIY guide with pics
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 76
    Thread: Autotech HPFP Upgrade full DIY guide with pics
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      08-28-2012 03:30 AM #1
      Suitable Vehicles:
      All cars with the EA113 2.0L TFSI engine such as
      - VW Mk5 Golf GTi (incl Pirelli)
      - VW MK5 Jetta TFSI
      - VW Mk6 Golf R
      - Audi A3 8P
      - Audi S3 8P
      - Skoda Octavia vRS 2.0TFSI
      - etc etc
      NOTE: This DIY will also partly applys to HPFP Upgrade / APR HPFP / KMD etc pumps.
      1) Turn engine off (obviously)
      2) Allow engine to cool for a period of time so you can comfortably touch the HPFP without burning yourself.
      3) Either remove the fuse for the HPFP or tape the driver’s side door up to prevent it from being opened (opening the door will prime the fuel pump and spray fuel all over you = not good)
      4) Remove black screw cap from right side front of the HPFP.
      5) With the black plastic cap removed, stick a screwdriver gently into this valve to relieve the fuel pressure and allow excess fuel to drain out. (the pressure relief valve is like the valve you find on a car or bike tyre). Having a clean rag handy to wipe up the fuel is a good idea.
      6) Once the fuel pressure is relieved, remove the valve altogether from the HPFP body with a 13mm spanner.
      7) Using a 17mm spanner, crack and undo the silver high pressure fuel line leading into the bottom of the HPFP. Undo the nut completely and slide it back out of the way.
      8) Unclip the black switch from the top of the HPFP and the cream coloured one from the side of it and move the connectors out of the way.
      9) Now you will have access to the 3x T30 bolts which hold the HPFP into the engine. Loosen these and remove them.
      10) You will now have to remove the rubber fuel line leading into the bottom of the HPFP. In my case, I found it easier to undo the rubber line where it joined into the silver fuel lines back near the inlet manifold (rubber hose is only 10-15cm long) rather than directly at the HPFP as there isn’t much room.
      11) Once the rubber hose is free, you should be able to slide the HPFP assembly out and away from the engine.
      12) With the pump removed, you will have access to pull out the cam follower and inspect the level if wear on it. In my cars case, the 10,000km (approx 6,000miles) its travelled has not created any wear to worry about on the cam follower. I will check it again every 6 months.
      13) At this stage, I would suggest taking a photo of the stock HPFP to refer to at the end of the rebuild.
      14) Take the HPFP over to a vice and secure it with the spring and piston facing up towards you (I put a clean rag around the pump to prevent scratching it with the vice). Pull directly upwards on the spring and piston and it will pop off. Place these safely on a clean workspace area.
      15) With the spring and piston removed, you have access to the 18mm nut which needs to be removed. You can do this with a standard 18mm socket now, but you will need a long 18mm socket to put it back on later.
      16) With the 18mm nut removed, you can now remove the stainless steel seal holder and cylinder. Place the cylinder with the spring and piston you removed earlier.
      17) You should now have the following items removed from the HPFP. The only parts we are going to re-use are the stainless steel seal holder and the spring.
      18) Now, working in a clean environment, get the new Autotech components (piston, cylinder, spring retainer and guides) out of their packaging.
      19) Ensure the Autotech piston (notice the thickness difference from the OEM piston) is clean and free of contaminents by dipping it in petrol before inserting it into the stainless seal holder. Insert it from below (the threaded end of the stainless steel seal holder) as shown by the arrows in the pic below.
      20) Next, place the cylinder over the piston from the bottom of the threaded stainless steel seal holder. if you look closely at the new cylinder, you will see that one end is a larger diameter than the other. Ensure the end with the larger diameter goes into the stainless steel seal holder. (this is also easy to identify as the larger diameter end also has some holes drilled into the cylinder.)
      21) We will now put these parts back into the HPFP body. Lubricate the rubber seal on the stainless steel seal holder with some clean engine oil. Just use your finger to rub the oil onto the seal. Insert the parts back into the HPFP body.
      22) Clean the 18mm nut you removed earlier and also clean the 18mm long socket you are about to use to tighten the nut up (this is to ensure no pieces of dirt fall into the HPFP during re-assembly). Tighten the 18mm nut up
      23) Now clean the spring you removed earlier by dipping it in petrol. Lift the piston up as far as you can out of the HPFP body. Click the spring back in place over the top of the piston.
      24) Now fit the titanium spring retainer over the top of the spring. Push down on the retainer/spring slightly (a few mm) and insert the 2x black retainer keepers. Make sure these are placed evenly and are flush with the top of the retainer.
      25) Have a quick overall inspection of the rebuilt HPFP and make sure it looks as per the photo you took prior to dis-assembly. Double check the 18mm nut is tight and then it’s time to re-fit the HPFP to the engine following the first few steps in reverse. Make sure to prime the HPFP once or twice before cranking the engine to remove any air in the lines – you do this by opening the car door (you will hear the HPFP prime for a few seconds).
    2. Member sc0ttyb's Avatar
      Apr 11th, 2007
      PHX
      2013 Ibis White TTRS
      08-28-2012 03:46 AM #2
      Wow, you made that look super easy. I was apprehensive about upgrading the internals myself, but with this DIY I'm pretty positive I can do it.
      Awesome write-up. Thanks for doing it!
      (sent via mobile)
      2013 IW TTRS | 1990 TR Cabby Best Seller | 2012 CSG Golf R (sold) | 2008 TR R32 (sold) | 2006 UG GTI (sold)
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      08-28-2012 03:51 AM #3
      Thanks - i was also a little apprehensive about taking the HPFP apart, and the fact that i couldn't find a DIY anywhere is why i decided to make one. The Autotech instructions are pretty rubbish too.
      If you follow this guide you will be ok.
      Quote Originally Posted by sc0ttyb View Post
      (sent via mobile)
    4. Member sc0ttyb's Avatar
      Apr 11th, 2007
      PHX
      08-28-2012 03:56 AM #4
      Do you happen to know the torque spec of that 18mm nut? I just don't want to go nuts on it and damage anything.
      (sent via mobile)
    5. Member velocity196's Avatar
      Feb 19th, 2006
      Washington
      2006 MK4 GTI, 2012 Golf R
      08-28-2012 07:00 AM #5
      great thread thank you
      PTE5858 custom top mounted from ->Todd Cope's Horsepower Barn
    6. Member 6speedvr6's Avatar
      Jan 20th, 2008
      Ajax Ontario
      WOB 012[R]
      08-28-2012 07:31 AM #6
      It's a pretty simple process if you follow the steps as Lucas said the Autotech instructions are a bit misleading cleanliness is the key and make sure you have a vice or something to clamp the pump once it's removed to loosen the 18mm retainer. Nice clean step by step Lucas
      H&R Street coilovers and upgraded sway bars, Unitronic Stage 2 HPFP, Milltek TBE, BBS, VW.:Racing CAI, Autotech HPFP, CTS FMIC, HPA BBK, Diesel Geek SSK. Aasco Motorsports aluminium flywheel, Bully Stg 3 clutch, Haldex Race controller.
      SEM Motorsports 416-636-7575. Toronto. Simply Tire 416-916-9233.
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      08-28-2012 09:13 AM #7
      There is no mention anywhere of the torque specs for this nut. Just do it up nice and tight.
      Quote Originally Posted by velocity196 View Post
      Quote Originally Posted by 6speedvr6 View Post
      Cheers guys. Hopefully it will help others looking to install one of these.
      Nov 6th, 2010
      Houston, Tx
      current 1989 GLI Helios VR6, 87 325is, 87 golf gt lsv, 74 Trans am 455, 99 ctr rep, 94 civic si hb
      08-28-2012 11:34 AM #8
      I appreciate this a lot i was gonna fork over the money for the apr but this looks simple enough
    9. Member Angina's Avatar
      Oct 21st, 2002
      2012 Golf R, 2007 BMW X3, 2002 Jetta 1.8T
      08-28-2012 12:24 PM #9
      gonna use this guide to check my cam follower soon!!!!!
      thanks!
    10. Member
      Sep 20th, 2011
      SD
      '15 GSW TDI SEL 6MT, '12 CW .:R (Gone), B6 Avant (Gone)
      08-28-2012 02:37 PM #10
      "opening the door will prime the fuel pump"
      Ah, I was wondering what that sound was..
    11. 08-28-2012 02:52 PM #11
      Dude great job on the write up !!! I've had me HPfP for a few weeks wondering if I can do this myself after looking at Autotechs directions where like reading a mistle manual. Lol. Now I'll def be doing this this week now!!!
      2013 CW 4D Golf .:R / UnitedMotorsport stage 2/ APR RSC TB Exhaust / Forge TwinTake / NSP Golf .:R boost guage / Autotech HPFP........
    12. Member VWPDX's Avatar
      Jul 7th, 2011
      Portland, OR
      2012 Golf R (2012-) 1997 GTI-VR6 (1998-2007)
      08-28-2012 07:46 PM #12
      Great write up!
    13. Member
      Jul 21st, 2012
      Boston, MA
      2004 R32
      08-28-2012 09:55 PM #13
      Awesome! Thanks for the write up. Some noob questions following (don't worry, I'm not as dumb as it may sound, just don't want to f- this up):
      So after doing this I assume it is no issue to drive without the stage 1+ tune?
      Is it as simple as just doing this install and then getting the stage 1+ flash?
      Is there any downside to this opposed to shipping it to APR or is this the same thing they do?
      Why do some call it high pressure vs high volume? Just because it's the same thing (being able to run a higher pressure allows higher volume..?)
      Thanks again, saved me a few hundred bucks and some down time!
    14. Member
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      08-28-2012 11:05 PM #14
      Quote Originally Posted by mk2gti2 View Post
      Yep it's easy to do if you have some basic tools and some mechanical know how.
      Quote Originally Posted by Angina View Post
      thanks!
      My cam follower at 10,000km (6,000 miles) was still like brand new.
      Quote Originally Posted by Saracen View Post
      Yes sir-ee thats what it is.
      Quote Originally Posted by VR420man View Post
      Quote Originally Posted by VWPDX View Post
      Great write up!
      Quote Originally Posted by nchiarel View Post
      You can drive the car just fine with the upgraded HPFP even if you have the stock tune. The car will only use as much fuel as it needs. Then you can drive to your tuner and get a 1+ or 2+ flash.
      This is the same thing APR will do if you send them your pump for a rebuild. They will use APR parts instead of Autotech though.
      Hi volume / Hi pressure.....same same. The pump itself is a high pressure fuel pump (HPFP), but the pump upgrade makes it a higher volume pump too.
    15. Junior Member dsrtfox's Avatar
      Mar 1st, 2012
      PA
      2012 Golf .:R
      09-11-2012 08:24 PM #15
      just some quick newbie questions:
      1. when you say spanner, you mean spanner wrench, can i just use a box wrench? or is that not feasible in that tight of an area?
      2. when you say to clean the 18mm nut and socket, is this just a dip in gas like the other pieces or should it be wiped down (i feel like that might leave unwanted lint or something)?
    16. Member
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      09-11-2012 09:23 PM #16
      Quote Originally Posted by dsrtfox View Post
      When i said spanner, i mean one of these: http://www.naed.com.au/combination-r...ner-p-188.html
      Not sure if you guys call it something different in the USA.
      Just dip the 18mm nut and socket in clean petrol (gas), let them drip dry for a minute, and then install. No need to wipe them down. Its just to remove any dirt/dust etc that may be on the parts before installing them.
    17. Member sc0ttyb's Avatar
      Apr 11th, 2007
      PHX
      09-11-2012 09:39 PM #17
      Quote Originally Posted by Lucas_R View Post
      That's a combo wrench here in the States. Open end and box end.
      But yeah, spanner = wrench.
      (sent via mobile)
    18. Member sc0ttyb's Avatar
      Apr 11th, 2007
      PHX
      09-11-2012 09:42 PM #18
      Also, gun = rooty tooty point and shooty
      (sent via mobile)
    19. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      09-11-2012 09:52 PM #19
      instead of cleaning with gas/petrol, you can buy non-chlorinated carb/choke cleaner, and blast away dirt, and dries quick, as well...
    20. Junior Member dsrtfox's Avatar
      Mar 1st, 2012
      PA
      2012 Golf .:R
      09-12-2012 06:23 PM #20
      awesome, thanks for all the info guys.
    21. Member GTIVRon's Avatar
      Jul 24th, 2009
      Hurst, Texas
      92 Corrado SLC, '12 Golf R
      10-31-2012 09:47 PM #21
      Thanks for the write-up man!
      Used it just now... Remove rebuild reinstall was about an hour. This included 15ish minutes trying to get the rubber hose off (lack of proper tool for the clamp and VW screwed me with its orientation).
      2002.5 Jetta 1.8T - TOTALED (dodging deer)
      2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
      1992 Corrado SLC - Daily Driven (when it's not broken)
      2012 Golf R - Daily Driven (when Corrado's broken)
    22. Semi-n00b It Hauls's Avatar
      Feb 28th, 2010
      Durham NC
      2009 Passat Wagon 2.0T, 2012 VW Golf R
      11-20-2012 11:12 AM #22
      So, if you use APR parts they'll flash you free to 1+ if you already bought the stage 1. Which I have.
      What if you install the Autotec and stop by your local APR dealer and ask for a 1+.
      What will they charge, or will they even flash you if its not their parts?
      Thx.
      2008 B6 Wagon | United Gray | Revo Technik stage 1 flash | H&R Sport Springs | AMG C63 Wheels | Kamei Lids | Laminex tail and flasher film | Custom vinyl Audi style grille | 35% tint all around.
    23. Member felixang's Avatar
      Oct 19th, 2002
      Skokie, IL
      2002 GTI VR6, 2012 Golf R 2dr loaded
      01-29-2013 10:07 PM #23
      Does anyone know what the proper torque settings for the 3 T30 bolts, the fuel line nut and the pressure release valve? I would like to check the cam follower soon and do not want to strip them or have a fuel leak.
      Thanks!
    24. Member
      Apr 10th, 2012
      Australia
      Golf GTI Mk6
      01-29-2013 11:19 PM #24
      ^ i think people get a bit carried away with torque settings sometimes. When you crack a bolt/nut loose you get an idea of how tight it was in the first place - so just use common sense to do it back up in a similar way.
      The 3 bolts holding the HPFP onto the engine were not hugely tight from memory, and mainly serve to hold the HPFP assembly evenly and flush against the engine.
      The fuel line nut and pressure release valve will only go so tight, and are made from copper so the metal is soft, so again use common sense and just do it up tight without pushing it.
      I created this DIY and have done several thousand miles since the Autotech HPFP install and there are no leaks / stripped bolts etc on my car.
    25. Member hazy450's Avatar
      Jul 22nd, 2010
      Panama City, Fl
      2013 RBM Golf R Stg3, 2002 MKIV GTI
      01-30-2013 02:50 AM #25
      Quote Originally Posted by It Hauls View Post
      Thx.
      from what i know from previous experience is once you get the initial tune you can go up or down for free...
      For example, I got a downpipe on my tiguan i used to have and it was a generic brand DP and went to APR in Alabama and they flashed it to stage 2 for free. They did not ask if it was their DP or not. now if you go to a 3rd party dealer they might charge a small fee...not sure about that one....
      '13 RBM Golf .:R APR Stg3 ***For Sale***
      '10 CW Bagged Tiguan APR Stg2
      '02 Mk4 GTI Stock DD
