VWVortex.com - 2.0T FSI Engine parts
    Results 1 to 10 of 10
    Thread: 2.0T FSI Engine parts
    1. 08-28-2012 03:25 PM #1
      For sale are various interchangable parts from a BPY/BPG engine. will also fit BWT.
      Intake manifold with fuel rail and fuel lines
      4 injectors
      Rail valve
      water pump
      timing belt
      crank pulley
      EVAP w/ hoses
      coolant hoses
      oil cooler w/ hoses.
      4 pistons with rings and pins
      4 rods with caps and bearings
      crankshaft
      Oil pan
      Block
      Head
      Camshafts
      oil pump
      balance shaft
      etc.
      PM me what you need and I will let you know if I have it.
    2. 09-06-2012 07:11 AM #2
      Parts are available now, let me know what you need.
    3. Junior Member Capt.BluePearl's Avatar
      Feb 9th, 2010
      CT/NY
      08 A4, 79 Fiat Spider
      09-07-2012 12:39 AM #3
      where are you located..? I'm in central CT...
    4. 09-07-2012 05:16 AM #4
      Denver, Co
    5. 09-13-2012 06:39 AM #5
      Could you give me some prices? Cylinder head?
    6. 09-13-2012 11:38 AM #6
      Just sold the head last week. I'll let you know if I run into another. Still have pistons rods,etc on the lower end and stock valvetrain
    7. 09-13-2012 10:27 PM #7
      yo quick queston you got any pics of that cylinder head? would a aeb work on this enigne?
    8. 09-13-2012 11:29 PM #8
      I do not, I sold it. An AEB will physically fit but you will have to tune/code for it to work properly with the ECU.
    9. 10-03-2012 09:14 AM #9
      Gday mate, Is the vacuum pump available? I'm looking for a late model vacuum pump with revision letter F or H! Wat are my chances?!
      Sent from my GT-I9100T using Tapatalk 2
    10. Member Akula Class's Avatar
      Feb 17th, 2005
      Goldsboro
      Audi A4
      03-17-2013 11:07 AM #10
      Pm sent.
      EFR 6758 by UM
      Info:
      Build
      Pics
      Feat'd AZ'er
