#1
another problem i have with a 01v VB.
after rebuild (and that was the problem before rebuild), good reverse when cold. after 10 minutes - no reverse. replacing complete VB solves the problem.
i know that if i have VB bad reverse cold or hot, the reverse acumulator plug is leaking, so it is a diferent probelm.
could`nt find any weak spring or worn valve, replacing all solenoids makes no diferent, but the problem is somewhere in the VB. anybody?
thanks
