MK1 Scirocco and the Scirocco 16v.
#36
██████████████████Originally Posted by Jeremy Clarkson
#37
Tornado Redneck - Team Infidel
STOP PUTTING CORVETTE WHEELS ON VOLKSWAGENS
#39
It's ok if you disagree with me, I can't force you to be right.
2010 JSW TDI
2011 CC R-line
2012 Beetle turbo
#40
GTI with trailer full of lead bricks wins.
#41
#42
permanent vacation
#43
Dubbers are so funny. The only thing about any old FWD VW that's "better" than an ITR is that it's better at not being as desirable to crooks as ITR's are.
#44
Thanx I just snagged the last copy off ebay.
Here's an excerpt..
1982-84 VW Golf GTI mk1
1988-91 Peugeot 205 GTI
1989-95 Lotus Elan
1992-96 VW Corrado VR6
1993-96 Renault Clio Williams
1994-96 Peugeot 106 Rallye
1995-2005 Fiat Barchetta
1996-2000 Honda Integra Type-R
1997-2002 Ford Puma
1998-99 Peugeot 306 Rallye
2002-03 Ford Focus RS
2004-present VW Golf GTI mk5
2005 Renault Clio Trophy
2007-present Mini Cooper S Works GP
2007-present Renault Clio 197
Remarks on the Integra Type R from the initial round, before determining 6 finalists:
"There has never been a more focused, less compromised front-drive coupe than the Integra. From the moment you drop into its low-slung, huggy seat, clock the 8000rpm redline and give the titanium-topped gearlevel an exploratory waggle, you know that this could be a very special car. It doesn't disappoint.
'Unbelievable,' blurts Bovingdon. 'Superb engine, gearbox and brakes, and a simply awesome chassis.' Oh yes. Immediately obvious is the quality of the steering: its smoothness, its meatiness, its keenness. This Honda exudes quality and precision, and the limited slip diff subtly enhanves the traction of its relatively slim tyres. 'The more revs you pile on, the more neutral it seems to get,' adds Bovingdon. Meaden is more succinct: 'It's fantastic.'"
The 6 finalists are chosen:
"It's been a long time since I've driven an Integra, but it's like seeing an old friend. You sit low, arms and legs outstretched, rather than hunched over the wheel. Everything feels comfortable and perfectly placed, from the tactile titanium gearknob to the fat-rimmed steering wheel and alloy pedals. Longer, lower, and altogether more rakish than the boxy hatchbacks, when you drop into the coupe's classic Recaro you know you're in a different breed of car.
The VTEC motor sounds tinny on start-up, a brittle zing with no apparent guts and a less than sharp throttle response at low revs. The gearshift is delicious: short and precise, even in this 60,000-mile example.
The steering has surprising weight, despite power assistance, but there's a slight numbness to the feel for the first degree either side of dead centre. However, it's soon infused with super-detailed and ever-changing feel as you apply more lock, a constant flow of granular, textural feedback flowing through the rim.
Drive the Integra slowly and it feels a bit flaccid. You could almost wonder what all the fuss is about, but once that firecracker engine ignites, the humble Honda is transformed into a humdinger. It thrives on high revs, that classic VTEC kick hitting home at 6000rpm, from which point the fizzing four-cylinder emits a magical howl as the tacho needle homes in on and then passes 8000. It's like driving a real exotic: the super-high-revving engine, rifle-bolt gearshift, rigid bodyshell and incredibly controlled suspension melding to deliver an sensationally effective performance.
It's a frantic recipe, but there's so much more to the Integra than the binary character we've become used to in subsequent hot Hondas. You need to work the car hard, but it rewards you with a rich flow of organic feedback, tackling this unforgiving road with rare subtlety and composure, while at the same time keeping you involved every inch of the way.
Grip levels are miraculous on such modest rubber, and the limited-slip differential generates tremendous traction. There's no torque-steer to speak of, but then it's hardly rippling with lb ft, which probably explains it. Nevertheless, the combination of taut but supple suspension, a terrifically effective diff, abundant grip and no torque-steer leaves you with one of the purest and least corrupted front-drive helms ever.
As much as becomes abundantly clear as we tackle the corner for the final time. Still accelerating hard in fourth gear, at around 80mph, the Integra doesn't need any cajoling, coercing, or convincing. It simply turns in, biting hard into the tarmac, with a level of adjustability and fluidity that takes your breath away. It ignores the surface change, dances across the camber, and as momentum and lateral force begin to push the Bridgestones beyond even their prodigious adhesive limits, the Type-R enters a completely different realm.
You feel the nose hint at runing wide, but as you apply a little more lock the diff really begins to work, and in so doing brings the tail increasingly into play, to the point where the car actually adopts a mild, natural oversteer stance. Three wheels working hard, one barely in contact with the road, the Integra scythes through at unabated speed, no wasted effort, no scrappy corrections, just searing pace and total involvement.
It's a car as sweet and all-consuming as any I've experienced at any price, and as pure and focused in its own way as any Porsche RS. Forget the accolade of greatest front-wheel-drive car. The Integra Type-R ranks as one of the truly great drivers' cars of any kind."
The 6 finalists listed above are in finishing order. The Integra Type R is the greatest FWD car ever made!
#49
#50
This thread is why I like Honda's, but hate the owners.
#51
DD: 2012 GLI
Gone but not forgotten: 2010 Golf 2.5
Summer fun: 1995 M3
Former E36 318i driver and self-appointed Chairman of the Momentum Preservation Society.
#52
#53
At the time there was no fwd car that could handle like the ITR, but it's been a while since the last ITR was produce. Currently I think the best FWD car is the Megane RS 265 from a performance standpoint, but there are a lot of really good FWD cars right now and many people who like each one for different reason. In other words it's almost impossible to say which is best from a subjective point of view.
#54
Came in to second Mk1 Neon ACR.
#56
I have read that the Megane R26.R is epic. Roll cage, polycarbonate windows, titanium exhaust, Michelin PS2's, and enough stickers to out-rice the original ricer itself.
#59
I test drove a ITR at the dealership and fell in love with it. I also rode in my friends ITR swapped hatch and same results. I personally think it's the best FWD. This is just MY opinion. There are a lot of options for the motor and it's way more reliable than any of the cars you guys suggested. I'll bet anyone that ITR will outlast any one of those cars and will still have the same power. Honda FTW![]()
#60
I think the Megane is probably the best front driver ever, as of today.
That said, I think the top 5 best front drivers(ignoring reliability) has to include the ITR, the 90s Lotus Elan, the Corrado, and the Megane. Those seem to be the most universally accepted "best FWD driver's cars."
*note, I only listed four intentionally for "wildcard entry" status.
1998 VW Golf Mk.III 5dr/1960 Porsche 356B T5
/1980 Honda CM400E
"I drive an '81 Jetta with a Scirocco engine, Rabbit front fenders and multi-colored doors. There's a spiderweb fracture in the driver's side windshield, and a dented bumper sticker that says 'praised are the lowered'"
#61
Another vote for the R26.R with the new Megane RS 265 just behind it.
Algunos padres son poetas, todos los hijos son poesías. ♥
#62
#63
#65
Out partying.
The ITR, while dated, can still hang with FWD performance cars of today. And just give it a little bit of go-fast mods and it'll be more than capable of beating them. It's not the fastest, but it's essentially a FWD Miata; slow, but will be preferred by >50% of people shopping in the same price segment due to the fun factor.
It may not be king of FWD today, but it's indisputable that it is one of the best factory FWD cars ever made (due to it's minimal compromise nature).
#67
#68
nissan sentra...they chirp third.![]()
#69
The Renaults
Shenandoah hot lap 1:46.92: http://www.youtube.com/watch?v=RmYq3mBbwPg
#70
