Results 1 to 7 of 7
Thread: Newly Minted, Slightly Afraid Eos Owner
  1. 08-29-2012 05:36 PM #1
    Hello All,
    Just purchased an 08 Eos, with the extended limited warranty (certified pre-owned) with 54k miles. I've driven it all of about 100 miles. I like the looks, the feel, and so far most everything about the car. However, after reading many reviews and now this forum, I'm getting rather nervous.
    I'm still getting used to the sounds, feel, and other points of the car. Coming from a manual tranny to an automatic appears to take getting used to. For example, went from park to drive at a drive-thru after paying for the burger. Pushed the throttle, no go for about 2 to 3 seconds, then wham, I got underway after a significant lurch. Not sure if it's me or the tranny?
    My previous convertable was an 03 Saab 9.3. I got great service from the vehicle (putting over 70k miles on her over 5 years.)
    I am nervous about the top. Not so much leaks, but of items like the top getting stuck half way or down. What do you do when this happens on a trip? Is there an "emergency" way to put the top up or down just to get back home? The oil usage I'm reading about scares me bit also.
    I've also heard the 80k service is REAL expensive (2.0 T.)
    Tell me I've not made a mistake in purchasing this cool, beautiful car. Please?
    Thanks,
    Perry
  2. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    All original 77 Rabbit; 12 Prius C; 13 Jetta
    08-29-2012 06:22 PM #2
    You haven't made a mistake. I'm also a new owner and can relate. Now that it's yours, the reality sets in that you've bought a convertible with lots of moving parts. I used to think about how complex the top is and what if it breaks. None of that matters when the top's down and the weather is fine. Drive it. Enjoy it for its purpose. Deal with what may come, when and if it ever does.
  3. 08-29-2012 07:31 PM #3
    Hi PSellers,
    I think they call this buyer's remorse. These forums are great resources but they do tend to concentrate the negative. Most people don't write a post about how great their top worked today!
    My 09 has 46k and it has been flawless. Learn about how to lubricate the roof seals. Read up on the DSG and how it operates and feels. All of the info you need is on this fourm.
    Convertibles are all about living in the moment, so do it!
  4. Member
    Jul 26th, 2011
    2004 TTQ 225 2008 VW EOS 3.2
    08-29-2012 09:59 PM #4
    The more you drive it, the more you will LOVE it. I found that the gas pedal is much easier if I place my foot firmly at the bottom of the pedal and push to the middle of the pedal. Remember you are driving an automatically shifting manual transmission, so it will not "slip" like the auto tranny from a Honda.
    2004 TTQ 225 Blueflame Exhaust, APR, Modshack, Dieselgeek Shortshift
    2008 VW EOS 3.2 DSG
    2009 Volvo XC90 V8 R-Design AWD
    Never underestimate the power of stupid people in large groups.
    Nov 27th, 2009
    50 Miles South of Tucson AZ
    2013 CC and 2009 Eos
    08-30-2012 03:50 AM #5
    Quote Originally Posted by psellars View Post
    Hello All,
    Thanks,
    Perry
    I am about to give you some advice that I sincerely believe almost everyone on this forum will agree with. At least, I certainly hope so.
    Spend several hours and read every post regarding the Eos. Concentrate on the positive attributes of this great car but take notes regarding preventative maintenance, as well as things you should do immediately.
    Since your vehicle is a pre 2009, there are certain things that pertain to you, assuming your engine is a 2.0 T, in addition to top seal desingns, etc..
    There is no Reader's Digest version as to what you need to know and what really does or doesn't matter. It is up to you to educate yourself. Spend the time, and if you have questions after that, please feel free to post. Of course, you can post regardless to whether you decide to research or not.
    I did the exact same thing before posting on this forum. I wanted to be as educated as possible. Yes, it took a couple of evenings to get through the information, but it was well worth it.
    We look forward to hearing from you in a few days or so with any additional questions you may have.
    In the mean time, happy reading and end enjoy tht wonderful car.
    2013 CC Sport Plus, K@N Air Filter, LED Interior Lighting Including Foot Wells, 18" Interlagos Wheels w/ Cooper tires, Chrome Mirrors, Chrome Door Handles.
    2009 Eos, Tech Package, RNS510, K&N Air Filter, Silver/Black Leather Seats, Sherwood Aluminum Dash Kit, LED Interior Lighting, Underbody LED Safety Lighting, Under Seat Drawer, R-Line/GTI Flat Bottom SW.
  6. Member BostonB6's Avatar
    Nov 16th, 2005
    2013 BMW E93 328i / 2012 Edge
    09-18-2012 09:46 AM #6
    Your car should have had a required DSG fluid change @ 40k. The fluid change costs about $400 but is required to maintain your DSG warranty. Also, some DSG's from around your vintage had defective Mechatronics issues. Check if your car falls under the recalled VINs.
    Dealership should be able to help you with both issues.
  7. 09-20-2012 07:42 PM #7
    That throttle lag is not normal. I had the same problem with my 2008 Lux. It took the dealership some time to figure out what was actually wrong. But two Mechatronics units and one clutch pack later and they determined that it was a faulty brake sensor. Basically, the Eos has a sensor that prevents you from providing too much power to the transmission (in 1st gear) if the brake is engaged. A faulty switch creates a lag that tells the tranny computer that the brakes are still on even though you've taken your foot off the pedal. There are extensive posts here that i and others have made in dealing with this issue.
