Originally Posted by
WaterWheels
First the fuel pump running for a few seconds and then stopping. This is normal and correct. Some like to say it is "priming" the system but it is really just running as normal and stopping because the pump realy "sees" no engine rotation. The relay receives a signal from the ignition coil negative terminal, call it a tachometer signal if you wish, and if that pulse is not at least something like 300 per/min it opens the relay again. So yeah, it is acting correctly.
That you are getting fuel at the cold start injector indicates that it is reaching the fuel distributor. The cold start injector gets system pressure through the fuel distributor, but not through the chambers inside. So the fuel distributor itself "could" have a clog. With your car the diferential pressure regulator (DPR) is the governing factor in fuel being sent to the injectors. If it is bad it is "possible" that it has shut-down fuel delivery by staying/sticking closed inside (it is a valve of sorts). The injectors themself require a min opening pressure, crack-open pressure, and even if you were sprayed in the face at the cold start valve, the pressure still can be too low. The injectors need about 3+ bar pressure to pop open. One or two bar pressure would be more than enough to get you a face full of gas but still not be enough to poen the injectors.
I think a fuel pressure test should be done at least for a first step.
