Results 1 to 32 of 32
Thread: Diagnose my Outback's problem
  1. Member dieselraver's Avatar
    Nov 11th, 2007
    Marine Park/Ozone Park NYC Current Cars: - 2012 Honda Odyssey 1996 Toyota Corolla Base
    Previous Cars: 2010 Subaru Outback MT 2008 - BMW 328XI 6MT - 2008 VW GTI 6MT - 2007 VW Rabbit 5MT -
    08-30-2012 02:11 AM #1
    So I have a 2010 outback with 37,XXX miles on it. i have been having some sort of issue with the steering. at full lock (turned completely) and I'm unsure if it does it when turning right as well as left, but I get this really bad slippage, similar to the wheels slipping on the ground and i've never experienced anything like this before.. It isn't anything related to suspension travel, and it's not a bearing (as far as I can tell) because it only happens when i turn the steering wheel fully...
    what does TCL think is wrong with my outback?
  2. Member Horror Business's Avatar
    Mar 1st, 2005
    '91 BMW e30 318is
    08-30-2012 02:16 AM #2
    Is it something like what four wheel drive vehicles feel like when turning?
  3. Member dieselraver's Avatar
    Nov 11th, 2007
    08-30-2012 02:28 AM #3
    Quote Originally Posted by Horror Business View Post
    possibly... i honestly can't describe it, other than its a noticable shifting in the car when its turned to full lock. it sounds on every rotation, i've checked the tires for possibly something embedded or something rubbing against something but nothing. its coming from the front, and only happens when in a full turn.
    when i say shifting, its like the car slips on the road slightly or something chugs and slips... the words to describe this are just not coming.
    its not clicking like a bearing, and its not wheel rub in the wheel well.
  4. Member Turq's Avatar
    Nov 9th, 2001
    St. Charles, MO
    2000 Subaru Impreza Outback Sport
    08-30-2012 02:40 AM #4
    It almost sounds like driveline binding, which shouldn't be happening on an Outback that new. I dunno though.
    "We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light."
    - Plato
  5. Member dieselraver's Avatar
    Nov 11th, 2007
    08-30-2012 02:54 AM #5
    Quote Originally Posted by Turq View Post
    researched driveline binding a bit, and I can almost confidently say it sounds like wheel hop. the main causes for driveline binding or wheel hop sounds like bad shocks/struts, tires with no tread, ball joint, an alignment issue (i don't have any pull in steering and the steering wheel is centered), suspension is all stock, as are the tires conti-pro whatevers. springs seem to be ok, no crazy bouncing etc...
  6. Member digraph's Avatar
    Jul 23rd, 1999
    Bay State
    '12 Impreza, '10 Forester, '09 Matchbox Unimog
    08-30-2012 07:58 PM #6
    I believe the manual states to not do that. i.e. if when turning you hit the limit of the mechanism's travel, immediately back off; do not hold the steering wheel against the physical limit.
    (ok I'm extrapolating - it says that in the '10 Forester docs)
    Not an enthusiast.
  7. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    08-30-2012 10:11 PM #7
    At what speed are you hitting full steering lock?
  8. Member CSFiend's Avatar
    Jan 13th, 2007
    Minneapolis, MN
    03 Outback
    08-30-2012 10:27 PM #8
    Quote Originally Posted by vwlarry View Post
    The ignorance of what you said there is so multi-faceted; it's like a kaleidoscope of ignorance.
  9. Member dieselraver's Avatar
    Nov 11th, 2007
    08-31-2012 01:33 AM #9
    low speeds? mainly when doing u turns, making a sharp turn into my driveway, between 2-8mph?
  10. Member dieselraver's Avatar
    Nov 11th, 2007
    08-31-2012 01:34 AM #10
    Quote Originally Posted by digraph View Post
    its not against the physical limit. its basically to full turn lock, its the same driving routine ive been doing for years, im not forcing it past the point of no [re] turn () but this is a new thing where i get the wheel hop/skidding as well as shuddering
  11. Member thetwodubheads's Avatar
    Dec 6th, 2004
    12 Golf TDI, 10 Ram 2500 Cummins
    08-31-2012 01:59 AM #11
    Is your model one with a fancy lock-up center diff? The older straight viscous fluid diffs wouldn't do this, but if you have one that is supposed to lock, maybe it's siezed up.
    I tried finding a video of someone with a 4wd vehicle turning on hard road so you could compare, but it seems most people with a 4wd rig know not to do that.
  12. Member dieselraver's Avatar
    Nov 11th, 2007
    08-31-2012 10:25 AM #12
    Quote Originally Posted by thetwodubheads View Post
    no this is a 6MT which has the true 50/50 viscous coupling differential. no computers or fancy gadgetry to mess with. albeit a bit slower to respond but with true 50/50 AWD i don't care
  13. Member oh noes! cars!'s Avatar
    Apr 24th, 2007
    Mississauga, Ont.
    '07 Mazda 3s GT, '13 Subaru Impreza Sport
    08-31-2012 10:30 AM #13
    Quote Originally Posted by MK420TH92 View Post
    Now b/c of this im fkn paranoid about mines. For for theifs out there u better watch out... cuz im nockturnal....i dont go to sleep till 4am either.... and i bought a machette a ago... if i see u near my car im running out there and ima chop ur ass up.... real shiitt
    http://www.trailburn.ca
    We are giants, with stars at our fingertips
  14. 08-31-2012 10:30 AM #14
    All of my STIs would stutter and hop (kinda) in a sharp turn at low speeds. The manual stated that it was the rear diff and that it as no problem. Don't know if that is what yours is doing though. Just wanted to throw that out there.
  15. Senior Member Hostile's Avatar
    May 29th, 2002
    NOVA
    a subaru and a vw
    08-31-2012 10:35 AM #15
    Did you ask those retards over at the outback forums?
  16. 08-31-2012 10:39 AM #16
    mine would do something similar until i changed the rear diff fluid with synthetic. it doesnt do that anymore.
  17. Member dieselraver's Avatar
    Nov 11th, 2007
    08-31-2012 10:43 AM #17
    Quote Originally Posted by surefooted View Post
    I wouldn't be so concerned if it wasn't something that seems different, its quite noticeable and never did this before. obviously if it was something that happened from day 1 I wouldn't be making a topic
    you said it yourself. they are retards. they really don't know their ass from their elbow. put it in perspective.
    one guy wants to put a Legacy GT hood (with the hood scoop) on his regular outback to make it cool
    Quote Originally Posted by VeeeDoubleU View Post
    its going to the dealer on the 13th i'll see what they say
  18. Member thetwodubheads's Avatar
    Dec 6th, 2004
    08-31-2012 11:19 AM #18
    Has it been towed? Just remembering that we had an older legacy at the dealer that was towed in for something... Arrived with front wheels on the truck, back wheels on the ground. It would wheel hop after that, the towing company paid for a center diff, the cluches welded themselves together.
  19. Member CSFiend's Avatar
    Jan 13th, 2007
    Minneapolis, MN
    03 Outback
    08-31-2012 11:34 AM #19
    Quote Originally Posted by dieselraver View Post
    That's just like, your opinion, man.
    I'm a frequent contributor over there, and I'm not retarded. Well... perhaps slightly, at times.
    How is the LGT hood on an Outback any different than VW douchebags running Audi wheels?
  20. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    96 Jetta - 300K Club, Truck, Boat, Quad
    08-31-2012 12:41 PM #20
    my truck does this when im @ full lock in 4WD - isn't it just the awd system/rear diff? i always figured it was normal but who knows - that's a truck, not a suby lol...ill check my GF's and see if hers does it
    There aint no OZ in rape.
  21. Member Heffernan's Avatar
    Apr 17th, 2006
    Howard County, MD
    A lifted Outback
    08-31-2012 01:27 PM #21
    Quote Originally Posted by CSFiend View Post
    ^this.
    IAG Performace | AndrewTech Automotive
    Baltimore Ravens - Super Bowl XLVII Champions!
  22. 08-31-2012 02:35 PM #22
    i found that mine started doing that around 30k miles. when i drained the rear diff fluid it was kinda dark and worn out looking. took less then 1 qt. the transmission gear oil still looked like new but i changed it anyways.
  23. Member dieselraver's Avatar
    Nov 11th, 2007
    10-02-2012 06:02 PM #23
    ok new update. got the car back from the dealer. was "unable to replicate problem" i even went with him for the test drive, i drove, full lock both ways, we drove around for about 2-3 minutes, so the engine warmed up, but no noise.... i get to school (about 30 miles away) and the wheel hop is back!!!
    someone has to know what the deal is.
    cliffs:
    1. cold start car does NOT wheel hop
    2. driven for substantial miles (10+) and it does the wheel hop at sharp turns or full lock.
    come on TCL don't fail me now!
  24. Member
    Mar 17th, 2003
    Lehi, UT
    Miata, Wrangler, Soul, Mustang & a turbo minivan
    10-02-2012 06:48 PM #24
    As a Subaru salesman blessed with some actual mechanical knowledge, this sounds like a classic case of the center differential being unhappy with its fluid. When it happens on a Subaru with an automatic transmission, the trick is to get a bottle of limited slip friction modifier and pour it in the diff. This alone will usually cure the problem. If you want to do it the "right" way, have the center diff serviced (read: flush and fill) which is part of Subaru's suggested 30k service.
    However, you have a manual transmission. This means you have the viscous center differential, and the friction modifier trick generally won't affect its operation. Here you'll probably have no choice but to replace the entire viscous unit with a new one. (What causes this to fail? It most often happens after you run tires of different diameters.) The good news is this will be covered by your 5/60 powertrain warranty provided you haven't abused the vehicle. Running tires of different diameters counts as abuse, and Subaru teaches their techs to look for such things when the center diff begins to fail.
    If your tires are all equal, Subaru should be quite happy to replace it for you.
    Dempsey Bowling
    Sales Consultant at Doug Smith Dodge/Chrysler/Jeep/Ram/Subaru/Kia/used (800) 553-3099
    My fleet: 91 Miata, 98 Wrangler Sport, 12 Soul +, 89 Voyager turbo, 06 Mustang GT, 01 Suburban 2500 8.1L
  25. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    10-02-2012 07:03 PM #25
    Loose nut behind the steering wheel.
    Deal with it.
  26. Member MCTB's Avatar
    Dec 29th, 2005
    NoVa
    '12 Focus SE, '72 MGB GT, '58 MGA
    10-02-2012 07:07 PM #26
    Thats probably why it is doing it. Viscous works off of mechanical slippage to lock up. In a turn, one wheel is going farther than the other so you will lock up and get bind. The automatics shouldnt do that since it is electronically controlled. My fiances '12 OB with the CVT does not do that at all.
    You think you hate it now. Wait til you drive it.
  27. Member Pool Runner's Avatar
    Aug 16th, 2009
    Nor Cal
    '13 WRX (sold) , '11 Outback (Sold) , '13 Outback 2.5i Limited SAP, '11 Ford F-150
    10-02-2012 07:40 PM #27
    Quote Originally Posted by TurboMinivan View Post
    Can you you help diagnose my 2011 CVT, 2.5i Outbacks problem? is it the same issue, related or different? as I write this my Outback has been at the dealer a week for the third time trying to diag an intermittent problem that occurs when the car sits say overnight or for a period of say two hours or more. With the car cold, start it and let worm up like I normally do 10-15 seconds or more. Put the car in reverse and apply gas as to back out of driveway or such and then the car feels as if the CVT is seriously slipping, following a shudder of what feels like either the parking brake is on or a typical 4x4 left in 4-Lo range while on pavement.
    The problem is entirely intermittent, has happened 8-10 times over the last year, it never does it for the dealer, only happens in reverse. My Subaru dealer cannot figure it out either and I'm getting more frustrated as the issue keeps recurring.
    Forgot to mention, car has 22k miles has been maintained rigorously since new. I have driven it off-Road once or twice but never abused. Otherwise sees commuter highway miles daily via my wife 98% of the time.
    Thanks in advance
  28. Member lojasmo's Avatar
    Dec 23rd, 2002
    SE MN
    2006 Vue, 2012 Chevy Cruze LT2, Soon to be NA Miata.
    10-02-2012 08:09 PM #28
    change all your fluids.
  29. Member
    Mar 17th, 2003
    Lehi, UT
    10-02-2012 08:48 PM #29
    Quote Originally Posted by Pool Runner View Post
    The issue mentioned above only happens when turning very sharply, thus exaggerating the difference in front-to-rear wheel speed (and maximizing the center differential's duty). Your issue, however, seems to have nothing at all to do with the center differential; when you're moving in a straight line, the differential doesn't really need to do anything since all the tires are rotating at the same speed.
    I have never observed this behavior. It could be brake related (I'm just guessing here). When it has happened, did you manually release the parking brake before engaging reverse, or did you just press the gas pedal and let the car then release the parking brake for you?
    Dempsey Bowling
  30. Member Pool Runner's Avatar
    Aug 16th, 2009
    Nor Cal
    10-02-2012 09:15 PM #30
    Out of habit I & we always do it manually (I don't personally trust that electric brake mechanism) anyway, you just put the car in reverse after it sat. Release brake ofcourse and apply throttle. The car then sudders violently, think of how reversing in a manual would feel like to someone trying to do that for the first time. What's super annoying is that the car only does it 2-3 times in a month, dealer has had car a week while wife & I are on vacation and they say they can't recreate the problem, nor did they fix and denied my wife's clearly blown front passenger side speaker. I feel like Subaru is giving me the shaft with no lube, never mind I'm also less than two weeks into ownership of a new '13 WRX but they don't seem to give a rats that I'm a repeat customer.
    love my WRX, but my '11 Outback 2.5, CVT has been the biggest POS ever, I regret trading my '08 Mercedes R350 for it. At least Mercedes service is always first class.
  31. Member dieselraver's Avatar
    Nov 11th, 2007
    10-19-2012 08:42 AM #31
    finally diagnosed the problem. it was the viscous coupler. can anyone tell me more about this part?
  32. Member dieselraver's Avatar
    Nov 11th, 2007
    10-19-2012 12:45 PM #32
    have you tried a different dealership? my dealership is fantastic, they fix everything and provide me a loaner (which is very rare in NY)
