Results 1 to 6 of 6
Thread: *** CTS Turbo Direct Fit FMIC Kits ***
  1. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    97 A4, 98 VRT, 01 S4, 02 996TT, 04 A4, 11 GTI, 12 Golf R, 13 ??
    08-30-2012 05:51 PM #1
    The CTS 2.0T Direct Fit FMIC Kit is designed as a drop in replacement for the OEM front mounted intercooler (FMIC). That means you can install this kit without any trimming or modification of the bumper. The OEM FMIC is adequate for stock boost levels, however once boost levels are increased by way of ECU upgrades/chipping the OEM FMIC struggles to keep the charged air temperatures in check. Higher charged air temperatures can result in boost cut and timing pull, both reducing the amount of power your vehicle produces.
    The CTS direct fit FMIC uses a high efficiency bar and plate intercooler core, which aids in reducing pressure drop. Reducing pressure drop means that your turbo will not have to work as hard to make a given level of boost. If your turbo makes 30psi of boost pressure in the turbocharger, and your intercooler has a 10psi pressure drop then the boost measured by your ECU would be (30psi - 10psi) = 20psi. With an efficient FMIC like the CTS direct fit FMIC your turbo does not have to work as hard to reach desired boost levels. This is beneficial in two ways, the turbo life expectancy is increased due to more efficient operation, and boost leaving the turbocharger is cooler and more dense resulting in more power to the ground.
    Product Details:
    - Efficient bar and plate construction
    - Low pressure drop
    - Maintains factory mounting points
    - No trimming of bumper or crash supports
    - Rated for power levels in excess of 600HP
    - Core dimensions: 23.00 Length x 2.00" Tall x 16.5" Height
    - Cast aluminium high efficiency end tanks
    Click to order our 2.0T Direct Fit FMIC Kit $799.99 Shipped
    MK5 GTI TSI:
    MK5 GTI FSI with CTS Turbo Big Turbo Kit:
    Golf R with CTS Big Turbo Kit
  2. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    08-30-2012 05:51 PM #2
    PS: Use promo code "Laborfmic" for $100 off and free shipping until the end of the first week of September.
  3. 09-06-2012 06:11 AM #3
    Hi , what HP gain should i expect with this intercooler ?
    My target is to go above 400HP with K04 ...
    Is S3 intercooler OK or is required to go for an aftermarket solution ?
    ( as i see , the price is double ... ) .
    - Golf VI GTI (CCZB engine ) MY 2010 , stock engine .
  4. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    09-07-2012 10:27 AM #4
    Quote Originally Posted by niktsig View Post
    You should expect 10-15HP from our intercooler, and it will definitely work well with your K04 setup, and have more cooling power than an S3 intercooler. If you are interested in a kit feel free to PM or email us directly: sales@ctsturbo.com
  5. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    05-14-2013 11:40 AM #6
    Ordering online? If you are don’t forget to look in the bottom of your box for summer swag. Lucky customers will receive CTS Summer Swag… which could include T-Shirt (you mad bro?), CTS coveted bottle opener, CTS Lanyards, and CTS plate frames. Sneak peak of Summer Swag goodness:
