Results 1 to 7 of 7
Thread: No start
  1. Member hubsch's Avatar
    Nov 28th, 2004
    Columbus, OH
    2002 Eurovan, 1998 ML320, 1991 VW Cabriolet, 1981 VW Scirocco
    08-30-2012 07:09 PM #1
    OK...haven't been on here in a while...'02 GLS...
    Just replaced the battery last weekend when the van would not start twice in a month - 2 weeks apart - jumped it and it started immediately.
    Today, sister was driving it around (she also has an '02 GLS in H.B., California)...everything was
    fine...stopped home...turned off the van...ran inside...came back out...nothing...no clicking like a dead battery...
    The previous times...the wife was driving short distances between errands...
    The only code is the sensor P0118...i looked it up and sometimes on other vehicles it produces a no-start symptom...
    I replaced the started probably in '05 or '06 with a Bosch unit.
    Thoughts?
    Apr 30th, 2004
    '02 EV MV Weekender, '11 GTI Autobahn
    08-31-2012 12:41 AM #2
    I had the same issue after driving then no start. I had a bunch of warning lights blinking prior to not starting, turns out it was a dead battery and bad alternator. Changed both out and all is good. So have the alternator checked, might not be charging the battery.
  3. Member AZ_NaTiV's Avatar
    Jan 17th, 2005
    Mesa, AZ
    '02 Eurovan MV
    08-31-2012 11:13 AM #3
    I'm on my third alternator. I seem to replace it as often as I do my battery.
    Just put it on my tab at Harry's
  4. Member hubsch's Avatar
    Nov 28th, 2004
    Columbus, OH
    09-01-2012 10:36 AM #4
    Replaced alternator within the past year...they load tested the alternator before replacing the battery last week...
    I am wondering if it is the starter again...raining outside now so waiting to drop pan and get to
    starter...why couldn't it have died in the garage...
    Thought it might be a switch but I can hear it click when I step on the brake pedal...
  5. Member hubsch's Avatar
    Nov 28th, 2004
    Columbus, OH
    09-02-2012 06:23 PM #5
    Checked the two relays #18 and #175 - those were fine...
    So I am replacing the starter...I got the bottom bolt off but am having trouble with the top bolt...
    Anyone have any words of wisdom...am I going to need an air rachet to get it off?
    Please any tried advise would be appreciated...
    TIA
  6. Member
    Jan 1st, 2003
    Australia
    09-02-2012 07:25 PM #6
    This might seem a late question but...ignition switch?
  7. Member hubsch's Avatar
    Nov 28th, 2004
    Columbus, OH
    09-02-2012 09:12 PM #7
    Thanks Seano...yes I replaced it...I had a spare one...guess I can keep it as a good used spare...the plastic. "Key hole" was still fine...
