Results 1 to 3 of 3
Thread: Changing the timing belt: DIY or head to the shop?
  1. Member teejers's Avatar
    Mar 6th, 2009
    wichita falls texas
    08 MKV GTI
    08-30-2012 10:49 PM #1
    thoughts? I know that I can physically do it but I am worried about any special tools or anything of that nature. I have a limited space and limited amount of tools to work with. I know that the cost at a shop will be rather high but I am worried that the difficulty level may be beyond my means. Thoughts?
    Fast is never fast enough............
    '08 MKV GTI FSI, APR Stage I, BSH True Seal Intake
    http://www.flickr.com/photos/i_am_the_justice_league/
  2. Member derekjl's Avatar
    Jun 23rd, 2006
    2007 VW GTI, 2007 Lexus IS250
    08-31-2012 01:44 AM #2
    If you aren't an experienced mechanic, I would head to the shop. This is a critical part of the engine and it needs to be serviced properly. If you pay any more than $600 you're getting ripped off.
    Need VAG-COM work in CNY? PM me!
    OEM+
  3. Member ROH ECHT's Avatar
    Dec 9th, 2010
    auf asphalt
    `07 gti K04'd
    08-31-2012 03:34 AM #3
    If you find a thorough DIY you can save much $$$. I paid for it all totaling $800+/- I think if memory is correct. But watched the service and it doesn't look too complicated. Just carefully get the cam pulley teeth checked and aligned properly for the two cams so that all goes back together as it was to begin with.
    K04 PLAY...`07 GTI/AWE K04&DV/APR HPFP/S3 INJ's&fmic/RS4 fprv/FORGE fmic & T-B HOSE/TECH.TUNING TB/BSH PCV&MOUNT's/NSP BOOST GAGE/AP Lite-PULLEY/NEUS. P-FLO&BOOST PIPES/GIAC K04 H/O & DSG FILES/13.2"BBK/BILSTEIN DAMPERS/W.A.L.K./H&R SS SPRINGS+F&R-ARB's/TSW 8X18 NURB's...ZOOM DIS! 1/4 mi: 12.82 @ 112 mph
