Results 1 to 24 of 24
Thread: My frame and axle are becoming good friends!!
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    08-31-2012 09:22 PM #1
    So I finally installed my coils on the car because I got tired of the Vogtland springs..they just weren't doing it for me anymore..I'm running fk streetlines all the way down in the front with no helpers and no rear perches in the rear, the car sits about 23" ftg all the way around. lmk what you guys think, only have a few pics for now hoping to get some better ones soon.
    passat 050
    passat 051
    passat 052
    passat 053
    and one from Dubs on the Deleware
    Feb 17th, 2008
    brooklyn ny 11230
    07 passat 2.0t wagon,09 vw cc vr6 4motion
    09-02-2012 03:48 PM #2
    Looking real low
    strictly a lower case poster Mods too many to list
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-02-2012 04:46 PM #3
    Yessir doing little by little at a time, have to finish wrapping my interior and some other stuff by show n go.. You heading over? Haven't seen your car since spring show n go.
  4. Member
    Dec 17th, 2008
    3.6 4mo, 9k Aero
    09-02-2012 05:07 PM #4
    Looks good, headed in the right direction for sure.
  5. Member fastD's Avatar
    Sep 16th, 2011
    NJ
    B6 Passat
    09-02-2012 08:29 PM #5
    you sure you removed your helper springs? cause i dont think you did..i have the same setup and my coils in the front are all the way down as well and its sitting the same in the front with helper springs! js
    UCEURO
  6. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-02-2012 09:29 PM #6
    Quote Originally Posted by bgsapc View Post
    Thanks man, trying to find some 2 or 3 piece wheels to refinish over the winter
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-02-2012 09:30 PM #7
    Quote Originally Posted by fastD View Post
    001
    003
    007
  8. Member SickTRed08FSI's Avatar
    Apr 28th, 2011
    Syracuse, NY
    08 Passat 2.0T, 10 Touareg TDI
    09-03-2012 01:12 AM #8
    Ok....i want to go lower on my ST coilovers. You guys have some pics/diagram/diy on how to modify them to go lower??
    Unitronic>Revo and hauling ass! K04 w/ RS4 injectors, Forge WINtake, Eurojet intercooler, ECS lightweight pulley, APR TBE, APR hpfp, BSH TB pipe, Forge DV, Neuspeed K04 discharge pipe, ECS dogbone mount, BFI stage 2 engine & tranny mount, 42 DD Ultimate catch can, HPFP Upgrade 145 BAR FRV, Snow Performance Stage 2 water/meth kit, Level 10 valve body rebuild
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-03-2012 10:00 AM #9
    Quote Originally Posted by SickTRed08FSI View Post
    Did you remove perches and helpers?
  10. Member SickTRed08FSI's Avatar
    Apr 28th, 2011
    Syracuse, NY
    09-03-2012 10:17 AM #10
    Quote Originally Posted by 1Slow B6 View Post
    Da fuc u talking bout??? Ive never dealt with coilovers until my Passat.
  11. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-03-2012 11:05 AM #11
    Helper springs are pictured above and perches are the adjusters for the rear... take them out an it will sit lower
  12. Member SickTRed08FSI's Avatar
    Apr 28th, 2011
    Syracuse, NY
    09-03-2012 04:48 PM #12
    I did some reading about this. Think im gonna look into this over the winter. I want bags really bad, but im more performance focused right now. Guess ill have to do this over the winter.
  13. Member fastD's Avatar
    Sep 16th, 2011
    NJ
    B6 Passat
    09-03-2012 04:53 PM #13
    001
    003
    007
    ok well looks like we have a classic case of SMARTASS..relax yourself there big guy..my car is sitting at the same height and i did not remove my helpers thats why i said what i said
    UCEURO
  14. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-03-2012 05:33 PM #14
    Lol I am relaxed I didn't take it seriously neither should you, it was a joke
  15. Member fastD's Avatar
    Sep 16th, 2011
    NJ
    B6 Passat
    09-03-2012 05:49 PM #15
    UCEURO
  16. Member butternuts6mt's Avatar
    Feb 29th, 2012
    LINY
    2007 B6 Passat 2.0T
    09-04-2012 10:26 AM #16
    ok so my first question since i have the same set up for anyone else with this same setup is if you have had any issues with the oil pan. im low in the front but not that low( have maybe a half a finger gap in the front. Second question is about the rear perches. someone said these are the adjusters in the rear? isnt that the collar? anyway when installing when my rear was jacked all the way up the spring would not sit flush with the body without the collar, and with the collar on there was still some play untill it was off the jack. then nothing was moving. i dunno if this is normal or not but so far no issues driving.
  17. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-04-2012 12:40 PM #17
    Quote Originally Posted by butternuts6mt View Post
    The only time I had a problem with my oil pan was when I was driving out to pa for dubs on the delaware and that's because the road was uneven and there was a huge dip I couldn't avoid. I didn't crack my oil pan or anything I just have a few scrapes on it
    The perches are just the silver adjusters on the rear, I dont have mine in and didn't have an issues with the spring not sitting right, I'll try to get some pics when I get out of work
  18. Member SickTRed08FSI's Avatar
    Apr 28th, 2011
    Syracuse, NY
    09-04-2012 06:04 PM #18
    Beware if you go that low with Votex lip though. Im all the way down on ST`s and the bottom of my Votex lip is scraped up bad.
  19. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-04-2012 06:43 PM #19
    And I was looking for a lip too lol
  20. Member SickTRed08FSI's Avatar
    Apr 28th, 2011
    Syracuse, NY
    09-04-2012 07:58 PM #20
    Yeah..i have to pull into my driveway a certain way. The votex lip is a lot lower than factory. I wanna find me a new one in case.
  21. Member butternuts6mt's Avatar
    Feb 29th, 2012
    LINY
    2007 B6 Passat 2.0T
    09-04-2012 09:06 PM #21
    it sits flush and tight when the car is off the jack. i was just wondering if anyone had an issue when it was jacked up putting the spring in if it sat flush against the body while the car was in the air bc mine was not untill the car was on the ground
  22. Member butternuts6mt's Avatar
    Feb 29th, 2012
    LINY
    2007 B6 Passat 2.0T
    09-10-2012 01:20 AM #22
    figured it out. we installed the rear springs in the front thinking the longer ones were made for the front and thats why it would not sit flush when jacked up in the rear.
  23. Member
    Feb 9th, 2011
    845,NY
    06 Passat 2.0t
    09-10-2012 01:13 PM #23
    I would of never figured that out lol
  24. Member butternuts6mt's Avatar
    Feb 29th, 2012
    LINY
    2007 B6 Passat 2.0T
    09-10-2012 07:18 PM #24
    your pictures helped too lol
