Results 1 to 2 of 2
Thread: HELP PLEASE!!! Timing belt broke
  1. 09-01-2012 03:14 PM #1
    Hi i have a 2004 jetta and im pretty sure the timing belt just broke on it.. My girl was backing out of a parking space when she heard a couple of clicking sounds then the car went dead. Im pretty sure its the timing belt. Whats the chance that the valves are not bent? and how much am i looking to get this fixed? I have a mech that says he will install the timing belt for 150 if i buy the part is this a good price??
    ok here is why i think its timing belt...here are the codes i got P2181 P0411 P0341 Please let me know what you think
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    09-04-2012 05:52 PM #2
    P2181 is cooling system performance
    P0411 is SAI
    P0341 is cam sensor plausibility. This code would appear in the event of a broken belt.
    Remove the upper cover and have someone crank the engine. If the belt isn't moving, it's broken. Almost 100% chance on this car you've got at least some bent valves, but always put a belt on first and try to run it. Is this a BEV or BBW car?
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
