VWVortex.com - my trunk will not open
    Results 1 to 15 of 15
    Thread: my trunk will not open
    1. Junior Member imaccc's Avatar
      Mar 23rd, 2012
      Toronto
      2009 Volkswagen Passat CC Highline
      09-02-2012 10:04 AM #1
      2009 CC trunk has a short to ground or something. Will not open at all, only option is to have my 7 year old daughter climb through from the rear seats and pull the cord. Anyone have this happen to them? if so is their an easy fix to avoid waiting around at the dealer.
      Thanks
    2. Member ebi718's Avatar
      Jan 15th, 2011
      Brooklyn
      2010 A6 Avant, 2009 A8 L
      09-02-2012 01:37 PM #2
      Have VCDS? Scan for fault(s) to narrow it down. Maybe a faulty lock actuator.
      Sent from my PG86100 using Tapatalk 2
      2010 A6 3.0T Avant
      2009 A8 L
      May 13th, 2010
      2010 CC Luxury
      09-04-2012 06:49 AM #3
      Make sure it is not locked with the key from the driver's door lock near the trunk release button.
    4. Member MrRline's Avatar
      Apr 6th, 2010
      Phoenix,Arizona
      2015 GTI Autobahn, 2012 GLI Autobahn
      09-04-2012 10:59 AM #4
      Make sure after washing it your drying this area in the back. I had the same issue after not drying the trunk area after a wash.
      2015 GTI Autobahn
      2012 Jetta GLI Autobahn- BSH, CTS Turbo, ST Coilovers,AWE, VMR Wheels, GIAC, Milltek
    5. 09-04-2012 01:54 PM #5
      How did not drying cause this problem to occur ?
    6. Member MrRline's Avatar
      Apr 6th, 2010
      Phoenix,Arizona
      09-04-2012 02:05 PM #6
      Hard water buildup as soon as I cleaned and dried no problem with it
      2015 GTI Autobahn
    7. Junior Member imaccc's Avatar
      Mar 23rd, 2012
      Toronto
      10-18-2012 10:44 PM #7
      I took the car into the dealership and they diagnosed the problem as a faulty CCM. My warranty replaced the unit for free.
      OEM+ | UNItronic Stage 1+ | CTS Turbo Intake | Eibach
    8. Junior Member gtinmiami's Avatar
      Apr 22nd, 2009
      2013 Passat S
      01-21-2013 12:58 AM #8
      My trunk stopped opening as well.. i check all the locks. (ie: driver door key lock, 2nd button on remote, unlock button for doors) the only way for me to open the trunk now is to pull emergency manual handle inside the trunk.
      You mentioned a faulty CCM.. r u refering to the main computer? please elaborate. thx
    9. Member LubsDaDubs's Avatar
      Apr 6th, 2004
      Leduc
      a couple o dubs
      01-21-2013 10:47 AM #9
      ccm = comfort control module, used for power windows, locks remote fuel door and trunk
      Its hard to make a comeback if you've never left
      Bad Pennies......We turn up everywhere!!!
    10. Junior Member gtinmiami's Avatar
      Apr 22nd, 2009
      2013 Passat S
      01-21-2013 11:09 AM #10
      thank you for clearing that up.. was not 100% sure. Do you know where it is located on the CC?
    11. Member
      Dec 1st, 2009
      2012 CC DSG, 2001 Corvette 6MT Z51, 2010 Audi S4 6MT
      01-21-2013 02:30 PM #11
      Behind the lower dash close-out panel, behind the tilt-open storage cubby by your left knee.
    12. Junior Member
      Jan 14th, 2010
      Romania
      2009/VW/Passat CC
      01-21-2013 03:10 PM #12
      It happened to me as well last year.
      For some unknown reason the wires that were strapped to the frame from factory got loose and when I closed the trunk one got cut.
      Opened the left panel and taped the wire back and good as new.
      Very lucky otherwise CCM costs here in Romania more than 100 Euro
    13. Junior Member gtinmiami's Avatar
      Apr 22nd, 2009
      2013 Passat S
      01-28-2013 04:05 PM #13
      thank you for posting.. I thought i had a bad module. But like yourself, I think i have a some kind of a short circuit in the trunk.. I used the manual pull lever to get in the trunk then i started checking all the wires around the panels.. next thing i noticed, the trunk started working again... I'll have to keep digging around to find which cable it actually is because a couple days later... the trunk stopped opening.
      VAG-COM log..
      Address 46: Central Conv. Labels: 3C0-959-433-46.clb
      Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
      Component: KSG PQ46 RDK 051 0221
      Revision: 00051000 Serial number: VWZCZ000000000
      Coding: 13910F800186007F3F02141FF0CA8F2E085801
      Shop #: WSC 05311 000 00000
      VCID: 73EFDFCE12E718802CE
      Component: Sounder n.mounted
      Component: NGS n.mounted
      Component: IRUE n.mounted
      1 Fault Found:
      00950 - Central Locking Motor - tailgate (V53); UNLOCK
      007 - Short to Ground
      Freeze Frame:
      Fault Status: 01100111
      Fault Priority: 4
      Fault Frequency: 90
      Reset counter: 126
      Mileage: 000001 km
      Time Indication: 0
      Date: 2027.14.24
      Time: 18:01:45
    14. 03-30-2013 11:18 PM #14
      Hi,
      My 2010 CC Luxury in Canada has roughly 100,000km. so no warranty available.
      Here is chain of events that happened to me:
      1. Closed the trunk as normal
      2. Tried to open. The remote didn't work, the interior button (driver's door) didn't work.
      3. Climbed into the trunk and opened it with the emergency pull.
      4. When started the car it showed that all lights that are located on the trunk door are not working.
      5. Confirmed by seeing that my reverse and the other two lights are not working.
      6. In the garage (it's cold in Alberta) I took apart the trunk and that's where the mystery started to happen.
      When I unplugged the trunk opener motor, the light on the trunk door came alive. As soon as I plug the power into the trunk opener, the lights go off. I decided to check if trunk would open now - when the trunk is opened (upright position) the remote and interior button top open it - it all works. I got prematurely excited since I thought it was just a loose connection of some wires. Put the covers all back closed the trunk - it doesn't work. I open the trunk manually - the remote and the button work. I can hear them move and when I manually close the little tongue on the trunk door - it opens but only when the trunk door is in the upright position.
      I got mad and decided to come to VW vortex for some advice before taking it to my good mechanic.
      It seems that there is no issue with wiring or fuses. It is really weird that the trunk opener will not work when in the closed position but only when in the opened (upright) position.
      Anyone can help me with some advice? Is it some shortage? Or just VW mystery in the electrical department as always.
      Thank you in advance.
    15. Junior Member imaccc's Avatar
      Mar 23rd, 2012
      Toronto
      05-03-2013 03:30 PM #15
      This happened to me. Luckily my car was under 80k. Because they had to replace the CCM. The total cost billed to VW warranty was around $700.
      Tits? or Tires? they are both going to cost you money!
