Results 1 to 7 of 7
Thread: I stripped my check plug (EYN Tip.)
  1. Member tjjoiner's Avatar
    Jul 25th, 2012
    Sheffield, AL (Florence/Shoals Area)
    '02 Jetta GLS 1.8t
    09-02-2012 01:51 PM #1
    OK, so I thought I'd check my transmission fluid levels by taking out the check plug -- nothing comes out, it needs fluid, a little comes out and it's just right, a lot comes out and it's overfilled. I ran into a slight snag, however, when I stripped the plug. Seems that plug is in there nice and snug. I'm having similar issues with my drain plug. Neither of them want to come out!
    Any ideas/suggestions?
    UPDATE: I sprayed quite a bit of WD-40 "BluTorch" rust penetrator around the check plug, let it set for a while, and then epoxy puttied a 5mm allen bit (not a wrench but a bit) into the plug. I don't think this will work -- the epoxy putty will break first -- but it's worth a go.
    .: trevor | I love my wife! | His: 2002 VW Jetta GLS 1.8t Hers: 2005 Hyundai Elantra GT
  2. Member tjjoiner's Avatar
    Jul 25th, 2012
    '02 Jetta GLS 1.8t
    09-03-2012 02:53 PM #2
    I got the smaller check plug out by taking that 5mm allen bit (epoxy putty removed), soldering a bit of silver solder around it, hammering it into the plug, and using a socket wrench to unscrew it. The fluid that came out definitely needs to be replaced. I'll post a photo of the fluid later. Now the problem is getting the drain plug out. It, too, is stuck.
  3. Member tjjoiner's Avatar
    Jul 25th, 2012
    '02 Jetta GLS 1.8t
    09-05-2012 10:10 AM #3
    A bigger wrench (stepped up from a 1/4" drive with 1/4"-3/8" and then a 3/8"-1/2" adapter to a 3/8" drive with the one 3/8"-1/2" adapter) with a slightly longer handle got that plug unstuck. I've heard spark plug anti-seize around the threads will prevent it from sticking in the future.
    As a precaution, I'm thinking about replacing the plugs, especially the stripped drain plug. Where's the best place to find those? Local parts places (AutoZone, Advance, etc.) apparently don't have them in-stock or even special order. Time to scour the internet!
    EDIT: ECS has the larger of the two -- Magnetic Transmission Drain Plug (24x1.5) and Drain & Fill Plug (24x1.5) -- but not the 5mm allen plug. Does anyone know of other sources?
  4. Member tjjoiner's Avatar
    Jul 25th, 2012
    '02 Jetta GLS 1.8t
    10-19-2012 09:53 AM #4
    Does anyone know the part number, know a source (all I can find are replacement drain plugs), or know what size the check plug is on the 09a/JF506E transmission?
  5. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    10-19-2012 11:20 AM #5
    Quote Originally Posted by tjjoiner View Post
    if you get lucky and find one in your local salvage yard... otherwise its probably gonna be easiest to order one from the dealer.
    www.KansasCityTdi.com
  6. Member tjjoiner's Avatar
    Jul 25th, 2012
    '02 Jetta GLS 1.8t
    10-19-2012 11:41 AM #6
    Quote Originally Posted by CoolAirVw View Post
    UPDATE: I just called Hiley Audi/VW in Huntsville and get this... They want $29.16 for one and they'll have to order it.
    $29 for what basically amounts to a 50 cent bolt that I can probably get from Lowe's?!!?
  7. Member tjjoiner's Avatar
    Jul 25th, 2012
    '02 Jetta GLS 1.8t
    10-22-2012 12:22 PM #7
    According to Jay at ECS Tuning, this is what I'm looking for - VW part #N90414203, metric 10mm x 1.0. Apparently, it's also the drain plug for 01M transmissions.
    Quote Originally Posted by Jay Gusic @ ECS Tuning
    Hello
    This should be it here.Thank you.
    + link to cart
    <http://www.ecstuning.com/Cart/?add1=...alesrep=JGusic>
    http://www.idparts.com/catalog/produ...oducts_id=2414
    http://www.jimellisvwparts.com/produ...N90414203.html
    UPDATE: Confirmed! The new plug arrived yesterday and it screwed right in place of the old one, so if anyone ever strips their 09A check/inspection/service/level plug (or whatever term you choose to use), IDParts can have one at your door for $2.80 + shipping.
