VWVortex.com - FSV fueling help needed
    Results 1 to 10 of 10
    Thread: FSV fueling help needed
    1. Member Eastep's Avatar
      Nov 15th, 2010
      USA
      Mk2 Golf
      09-03-2012 08:49 AM #1
      Im possibly picking up a set of FSV (Formula Super Vee) intakes with injectors. I would like to use them on a DD 81 Rabbit 1.7l Im curious as to how I could go about providing the correct fueling and what additional parts will be required? The head is stock apart from a port match on both intake and exhaust. Im not opposed to running a 1.8 head with the larger valves if needs be. I would really like to use stock Audi/VW parts as ultimate HP is not my goal, but a cool oldschool reliable motor is. Further plans include the use of flat top pistons/rods from an older Passat and possibly knife the crank and lighten the flywheel.
      I would really like to figure out what parts, pumps, and metering would be used for this type of build. Thanks for the help
      Eastep: making the possible, impossible since:1981
    2. Member Eastep's Avatar
      Nov 15th, 2010
      USA
      Mk2 Golf
      09-03-2012 04:03 PM #2
      No one?
    3. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      09-06-2012 12:25 AM #3
      What ems are you going to use, and what exactly are the FSV intakes? ITB's or what. Seems any stock ems is going to need a common manifold/plenum setup. Sounds like a standalone like MS will fit the bill.
    4. Member Eastep's Avatar
      Nov 15th, 2010
      USA
      Mk2 Golf
      09-11-2012 02:57 PM #4
      FSV is Formula Super Vee. I figure Msquit would be needed. Im just looking to see if/what others have done.
      Was going to buy these but the deal fell through
    5. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      09-11-2012 03:40 PM #5
      Good thing, because:
      1. I don't see how you would fit those onto a counter-flow head in a Rabbit.
      2. I don't see how those could be very easy to live with on a DD car.
    6. Member Eastep's Avatar
      Nov 15th, 2010
      USA
      Mk2 Golf
      09-12-2012 07:17 AM #6
      Quote Originally Posted by ps2375 View Post
      I can see that. ...I still would try though
      How come? They're just like normal ITB's no?
    7. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      09-12-2012 12:22 PM #7
      Quote Originally Posted by Eastep View Post
      For a 1.7 motor these are prolly a larger diameter and the throttle response will be very on/off-ish. Not the best thing for dd. I am just guessing at this, given that these ITB's are meant to go on a race motor that doesn't spend much if any time below 5-6K rpm.
    8. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      09-12-2012 01:00 PM #8
      Actually FSV motors were dry sumped to turn nearly 10K totally unsuitable
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
    9. 09-16-2012 07:09 PM #9
      Those are just CIS injectors, on the FSV they run a rpm based fuel setting so not air plate like VW CIS cars. I'd suspect that you can create a plenum and a CIS flow meter. Those won't fit a cross flow head.. I've seen VW racing engine with those type of long ITB. I believe the rain tray was cut out and possibly some of the firewall.
      Can you tell me how long they are from end to end?
      Cheers
      ny_fam
    10. Member Eastep's Avatar
      Nov 15th, 2010
      USA
      Mk2 Golf
      09-25-2012 05:59 PM #10
      Sorry for the late reply. Im not sure how long they are as the seller decided to keep them. I was thinking that they could be used similar to the mechanical FI used on old Porsche RS's of the like. possibly mounting them on an ABA (Or my wall ) so I wouldn't have intake trumpets sitting in my lap...although I could paint lips on them and... oh never mind
