Results 1 to 13 of 13
Thread: HELP: hooking up lines callaway
  1. Member sutton83k's Avatar
    May 31st, 2007
    A Place
    1983 Scirocco
    09-04-2012 02:03 PM #1
    This is my first time messing with a turbo engine so I just need a little guidance on hooking a few things up. some solid answers.
    Here's the motor:
    Here are the questions:
    and most importantly...
    Apr 10th, 2002
    The Motor City
    Callaway Turbo Scirocco #10, Jaguar XJR, 67 Mustang Fastback, Chevy G35
    09-05-2012 08:04 AM #2
    Pic #2
    large nipple to large nipple on pic #5(cpr)
    small nipple to wastegate
    Pic #3
    goes to aux air valve
    Pic #4
    your wastegate
    Pic #5
    green and yellow open to atmosphere
  3. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    82 Scirocco~Rodolfo~85 Vanagon~El Guapo~
    09-05-2012 09:54 AM #3
    Quote Originally Posted by CALAWAYMK2 View Post
    Pic #2
    Pic #3
    Pic #4
    your wastegate
    Pic #5
    Im glad you got those answers....not to tread jack but on related questions. I need to gather new couplings for those pipes.....Can the OP or anyone one else create a list with OD'd on the flat and humped couplings? Im missing many from the pipes I got.
    Thanks,
    el t
    Quote Originally Posted by Mtl-Marc View Post
    The engine does not need oil, it runs on awesomeness.
    For Sale 14" Steel rims:For Sale 14" Steel rims:http://forums.vwvortex.com/showthread.php?6029120-FS-Great-Shape-14-quot-rims-12-hole-4x100-Steel-rims-with-tires-caps-and-beauty-rings-120
    Apr 10th, 2002
    The Motor City
    09-05-2012 10:10 AM #4
    Pipe hose is 2". Here is my experience having lived with my car for 13 years. All hoses should be hump hose with the exception of the turbo and throttle intake. Why? the engine moves and even with new motor mounts, the movement will pull the throttle elbow of the throttle body. The hump hose give a little play since the intercooler does not move with the engine.
    All new motor mounts is manditory.
  5. Member sutton83k's Avatar
    May 31st, 2007
    A Place
    1983 Scirocco
    09-05-2012 10:41 AM #5
    Can you also help me with this. Im a little confused as to why this part is tapped with theese two barbed fittings?
    Apr 10th, 2002
    The Motor City
    09-05-2012 11:10 AM #6
    They shouldn't be there. Just another butcher job like the throttle elbow. Plug them. If your using water/meth injection the injector is placed further down the casting at the flat spot aiming at the turbo.
    I don't think you can run enough boost to need it. Looking at your setup, I wouldn't boost more that 6lbs.
  7. Member sutton83k's Avatar
    May 31st, 2007
    A Place
    1983 Scirocco
    09-05-2012 05:49 PM #7
    YOUR THE BEST!!! thank you for clearing all that junk up.
    Apr 10th, 2002
    The Motor City
    09-06-2012 09:45 AM #8
    Callaway manual list Bosch spark plug W5CS for your setup with gap .028-.032
    Timing for intercooled is 5 degrees BTDC at 950 RPM. Max boost 10lbs.
    When fully warm set CO to best idle, then reset idle.
    Do you have a dual port vacuum advance?
    Callaway used the vacuum advance from a BMW 2002
  9. Member sutton83k's Avatar
    May 31st, 2007
    A Place
    1983 Scirocco
    09-06-2012 03:42 PM #9
    I dont have the dual port vacuum. I have an MSD 6BTM to hook up. am I selling myself short by not running the 5th injector? I have the microfueler but im not gonna use it. im running the usual 240T fuel distributor. 9:1 pistons. ummmm...
    Apr 10th, 2002
    The Motor City
    09-07-2012 07:24 AM #10
    Quote Originally Posted by sutton83k View Post
    Well, I can only speak to how an original callaway scirocco was delivered to the dealership. There are plenty of other opinions on upgrades and I'm surprised the mega-squirt crowd hasn't chimed in.
    Under boost the callaway distributor retards timing even more than the 5 btdc. It has no provision to advance timing. I don't know what the MSD can do as I'm strictly stock Callaway with the exception of his microfueler.
    The circuit boards on the microfueler were never coated. So after 30 years all the tracers on the board have fallen apart. The only replacement is a HKS AIC. This is even old school today. I paid $1000 for mine used 13 years ago. But, I think that they can be had cheap today if you can find one.
    My car wears the original fuel distributor that VW installed. I don't understand the functioning difference in the Volvo dist. The 5th injector will allow you to increase boost moving you closer to the fine line of the engines limit and pending meltdown. Many people that have tried turboing their Scirocco's have discovered this. Tuning the boost/timing and fuel at 15psi with an AIC is crucial in preventing detonation.
    A 5th injector can be added any time after you get your car running right. After tuning my car, I took it for a quick ride at 20psi. I filled my pants and turned it back down.
  11. Member CallawayTurbo's Avatar
    Mar 14th, 2006
    Netherlands Europe
    Touran TDI , Golf Cabriolet , Golf GTI , Beetle.
    10-28-2012 05:52 PM #11
    Can You update us on the build ?
    Callaway C1 registry vault president./member Callaway Owners Group
    VW Golf mk1 Cabriolet Sportline with Callaway stage 3 engine, engine nearly ready.
    VW Golf mk2 GTI , project dead car to be rebuild Callaway GTI Turbo stage 3 with BBS bodykit and wheels.
    VW Beetle , project dead car to be rebuild Porsche Speedster 356 kitcar.
  12. Member CallawayTurbo's Avatar
    Mar 14th, 2006
    Netherlands Europe
    12-27-2012 04:38 PM #12
    No updates ?
  13. Junior Member
    Aug 23rd, 2011
    Colorado
    1979 Mk1 Scirocco
    12-29-2012 01:58 AM #13
    Warm up regulator:
    "Yellow" goes to the intake manifold. I believe there is a diaphragm that opens up during boost to allow more fuel into the engine during boost. The others can be left open, if it is a daily the "Red" should be filtered.
    The boost gauge can be taken from anywhere after the valve in the throttle body. You just want the pressure in the manifold for a good reading.
    I have not looked into wastegates for a while but I am pretty sure that that one goes anywhere after the the turbo but before the throttle body.
