Results 1 to 14 of 14
Thread: AC's on but the outside fan is not running
  1. Member 01tj's Avatar
    Nov 8th, 2005
    WV
    02 330i, 09 Flex, 01 Wrangler
    09-04-2012 06:58 PM #1
    Our house got pretty hot today and we noticed that the fan on the outside (compressor) of the house is not running. I checked the fuse box and everything looks okay. What else is there to look for
  2. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    09-04-2012 09:25 PM #2
    There will be a pullout disconnect near the a/c unit. Sometimes this box contains fuses. Start there. There's also a small 2-wire cable that turns the unit on. Check for critter damage.
    If you touch these small thermostat wires together in the unit's junction box the unit should come on. If it does you may just have a bad thermostat.
    Garmin Is My Pilot.
  3. Member Rockhead261's Avatar
    Jan 5th, 2004
    Brewster, New York
    '75 Eldorado vert, '13 Sierra Denali CC D/A, '11 Outback 3.6R
    09-05-2012 10:38 AM #3
    No. You will short the control circuit and blow a fuse (if you're lucky) or fry a costly control board.
    OP, you mention the outdoor fan (condensor) is not running. Is the compressor inside the condensing unit coming on? Do you hear a 'click", but nothing happens? Do you feel a great deal of heat emanating from the unit? If your condensor fan has died it is likely the compressor will run for a short time before overheating and shutting down. The unit will be hot and may attempt to restart once it cools. A bad condensor fan is not a death sentance and is fairly easy to replace.
    If nothing is happening it could be one or a combination of scores of problems. Check for the obvious first - a tripped breaker may not appear tripped. Turn it to the 'off' position, then back on.
    Check for power at the outdoor disconnect with a multimeter. If you're not comfortable doing so, stop and proceed no further. Call in a tech.
    If there's power, confirm that your control circuit is sending 24VAC to the condensor. Some older condensors have their own transformers and provide control power for the system. Most newer systems have the control transformers inside the furnace/airhandler. DO NOT touch wires together unless you know exactly what they are.
    No disconnect power = start ringing wire.
    No control voltage = start ringing wire and checking indoor controls.
    Power at the disconnect and control voltage = trouble inside the condensor. Shut off the power and start digging.
    Rockhead
    '75 Eldorado 'vert, '13 Sierra Denali 2500 CC D/A, '11 Outback 3.6R, '12 FLHTCUI
    Quote Originally Posted by minibike hero
    Alternately, you could set his house on fire. Tall grass + leaking fluids + Lucas = plausible alibi.
    Necrospam!
  4. Member barry2952's Avatar
    Jun 13th, 2007
    09-05-2012 10:41 AM #4
    Quote Originally Posted by Rockhead261 View Post
    In all cases? My bad.
    Garmin Is My Pilot.
  5. Member PlatinumGLS's Avatar
    Aug 2nd, 2003
    Shelby Township, MI
    5.3, 2.0T & 1.0
    09-05-2012 02:49 PM #5
    This has happened to me...was the contactor. A $20 part that can be swapped out in 20 minutes. A lot of times, you can look at it and tell right away if that needs to be replaced.
    Quote Originally Posted by admirallaserbeam
    Rotary engines suck, dont get the miata
    2011 Chevrolet Silverado 4x4 | 2011 Buick Regal Turbo | 2004 Aprilia RSVR Factory
    RareSportBikesForSale.com | CarCast | German Cars For Sale Blog | AF1 Racing
  6. Member Rockhead261's Avatar
    Jan 5th, 2004
    Brewster, New York
    09-06-2012 01:18 PM #6
    Quote Originally Posted by PlatinumGLS View Post
    Very common failure and easy DIY. I replace mine every 5-7 years as PM, along with the run capacitor. Cheap insurance. Remember; A/C units only break down during heatwaves.
    Rockhead
    Necrospam!
  7. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-06-2012 11:18 PM #7
    Had my 'contactor' fail as well last year. Cheap and easy DIY fix.
    - Josh
    -Josh
  8. Member e_andree's Avatar
    Nov 22nd, 2001
    Frederick MD
    09-24-2012 02:50 PM #8
    contactor on the right..capacitor on the left, correct? I had the exact same issue as OP.....ended up being bad capacitor...35 dollar part.
    http://r-a-y.org/2010/07/ac-contacto...ch-repair.html
  9. Member barry2952's Avatar
    Jun 13th, 2007
    09-24-2012 04:23 PM #9
    On a metal cased capacitor you'll note a dab of solder near the terminals. When assembled the lid is flat. That solder connection contains a fine wire that's soldered in place. If the capacitor fails the lid will bow, breaking the tiny wire internally. We find capacitors can swell from over current situations and lightning strikes. They are also sensitive to heat. We try and keep them as far away from an HID fixture's ballast as possible.
    Garmin Is My Pilot.
  10. Member Rockhead261's Avatar
    Jan 5th, 2004
    Brewster, New York
    09-24-2012 07:26 PM #10
    Quote Originally Posted by e_andree View Post
    Correct.
    Rockhead
    Necrospam!
  11. 09-27-2012 11:42 PM #11
  12. Member GeoffD's Avatar
    Aug 13th, 2001
    09-28-2012 01:58 AM #12
    Quote Originally Posted by baryyknowseverything View Post
    Reported.
  13. 09-28-2012 08:32 AM #13
    There will be a pullout disconnect near the a/c unit. .
    this happens to me every now and then. all i do is pull that disconnect for 1-2min and plug it back in. it always fixes it
  14. Member vdubman1's Avatar
    Jan 4th, 2004
    Ontario
    10-02-2012 06:05 PM #14
    The top of the cap isn't always bowed out if its bad, I have seen a few that looked normal but when I checked it with my meter it was bad.
    OP did you figure out your problem yet?
