VWVortex.com - 2012 Tiguan: LED HID Headlights retrofit
    Results 1 to 14 of 14
    Thread: 2012 Tiguan: LED HID Headlights retrofit
    1. 09-05-2012 08:51 AM #1
      Hi Guys, this is my first post in Vortex.
      I´m from Brazil, and have a 2012 Tiguan with halogen lamps. I want to put que HID and LED headlights, like this:
      http://www.ebay.com/itm/OEM-original...447e4b&vxp=mtr
      But I have some doubts:
      The seller say that is plug and play, but some people tell me that I need some adapters, and have to chance a central commander.
      I dont need the leveling control or washers, just the HID and LEDs working as original.
      Has anyone due this reto fit? Some tips?
      Regards and sorry my english. I write bad, but I read well
    2. Semi-n00b
      Sep 27th, 2012
      Ft. Leonard Wood Missouri/ ft lostinthewoods
      2011 VW Tiguan
      09-28-2012 12:38 AM #2
      i did this swap and i burned up my central lightiing module.. driver side low beam would not illuminate, but all other lights worked, dealer replaced under warranty but if they had found out that i tryed to install an aftermarket hid light i would have had to pay 2000 bucks.... google phillips xtreme nightvision h7 for the tiguan great reaviews about the bulb its on ebay also
      Jan 26th, 2010
      '15 Tiguan SE 4MO (previously 2012 Tiguan SE & '10 Tiguan Wolfsburg)
      09-28-2012 02:31 PM #3
      Quote Originally Posted by noberryafterdingle View Post
      Guessing that you swapped the originals back in before heading back to the dealer?
      2015 Tiguan SE 4MO Previously: '12 Tiguan SE 4Motion & '10 Tiguan Wolfsburg 4MO - Yeah we like the Tiguan! - and really liking what the '17 Tiguan looks like.
      VW History includes: 412 Fastbacks, Original Beetles, Super Beetles, 4 MKII Scirocco's, Rabbit's & 5 MKI GTI's ... really too many VW's to accurately count or remember
      Follow our Journey Across America at OurRVjourney.com
    4. Member geevis's Avatar
      Jul 23rd, 2012
      CT
      2012 VW Tiguan LE
      09-28-2012 02:59 PM #4
      I've thought about going the HID route as well, but you would need to fabricate the plastic caps that cover the back opening of the headlight, amongst other things such as programming via Vag Com.
      That said I ended up upgraded my low beam bulbs to Silver Star Ultra's and they are indeed a bit brighter than the stock bulbs. I'll be swapping out my DRL/High beam bulbs soon as well.
    5. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      16 VW Golf R MT /// 12 VW Tiguan SEL 4Motion
      09-28-2012 03:08 PM #5
      Quote Originally Posted by geevis View Post
      You don't need to fabricate anything. If one will follow procedure everything will work just fine. These are almost plug and play, one would need this adapter: http://www.kufatec.com/index.php?mai...roducts_id=792 and an access to vagcom to release xenons and that's all there is to it.
    6. 09-28-2012 09:14 PM #6
      Hi guys, sorry my delay.
      I bought this headlight:
      This Central Module:
      http://www.cars-equipment.com/www/en.../#product_5237
      And this adapters:
      http://www.kufatec.de/shop/index.php...oduct&info=702
      Now I have to install. Have someone the wiring scheme? Like this:
      http://forums.vwvortex.com/showthread.php?3597373
      Regards
    7. Member TIGSEL's Avatar
      Dec 22nd, 2011
      The other side
      10-01-2012 02:51 AM #7
      Quote Originally Posted by hugo alvim View Post
      And this adapters:
      Regards
      Why did you buy a BCM? All you needed were headlights and adapter and someone with VCDS cable to release the xenons.
    8. Member ZLEB's Avatar
      Dec 9th, 2010
      LI-NY
      2012 Tiguan S
      10-02-2012 08:14 PM #8
      Vw uses Different Cecm modules for each trim level, my S doesn't even support fog lights never mind HID's (Stupid cost cutting)
    9. 11-02-2012 10:50 AM #9
      Hi Hugo,
      I am from Brazil too and I recently bought a new 2013 Tiguan and now I am looking to install the same OEM headlights with LED that you did. Can you please answer me:
      - What parts from Cables and BCM were really necessary or it was just plug and play after setting the Central Module on to Xenon function
      - Where did you executed the installation and it did not affected your warranty?
      Tks!
    10. Member
      Jan 9th, 2010
      Rio de Janeiro, Brazil
      Tiguan 2.0 TSI 2010 - 4Motion - Auto
      11-03-2012 12:50 PM #10
      Beware that is forbidden to use xenon lights here is Brazil without washers and leveling beams.
    11. 11-06-2012 10:27 AM #11
      sure wish someone made depo projectors for new tiggys
      formerly TVarmy04 & DUBMANG
      SAPPERS LEAD THE WAY
      Quote Originally Posted by jspirate View Post
      Now, having unprotected sex... thats a whole different beast. There are some crazy hotties out there... whew!
    12. 11-27-2012 01:51 PM #12
      Hi Hugo, just curious....
      Were you able to make it work? Is everything fine now?
      Greetings from Another brazilian.
      Fabio
      Remarks- I have a 2010/2011, put the equivalent Chinese ones similar to 2012 model (with LEDs) and everything worked just fine. I just had to use VCDS / VAGCOM cable to be able to activate the DRLs, as oppose to keep the parking lights on via Switch. Now trying to get the Tail lights off via VCDS, just to have front LEDs, like 2012 models.
      Abraço.
    13. 12-07-2012 10:28 AM #13
      Hi Fabio, sorry for delay.
      Yes, the headlights are working good.
      You can see a DIY guide in this topic:
      http://forums.vwvortex.com/showthrea...xenon+retrofit
      Best regards
    14. Member BrownBag's Avatar
      May 18th, 2006
      Gig Harbor, Wa
      2015 GLi
      01-26-2013 08:06 PM #14
      so whos all done this already?
      Instagram: E_GEEEZY
