VWVortex.com - Hatch rattle. FML
    Results 1 to 24 of 24
    Thread: Hatch rattle. FML
    1. Junior Member
      Feb 23rd, 2012
      Cassopolis, MI
      1996 Toyota Camry Coupe V6, 1981 VW Rabbit Pick-up Diesel, 2013 VW Beetle Turbo DSG SSN
      09-06-2012 05:05 PM #1
      Hello all, my 2013 beetle has been driving me crazy and I need to vent. I love this car first and foremost, but the hatch rattle has been a personal struggle. I removed the strut. Noise gone. I would like to use the hatch without holding it, so I have been on a mission. I bought a new strut (matched similiarly to one I found at O'reilys but had to switch the ball sockets..they screw off)--but it makes the same noise as the old one. The hatch strut on the passenger side is the culprit. When removed...no noise...when instlalled, it makes noise. I wrapped the orig strut in 5/8 rubber hose, re-lubed balls, teflon taped the balls, electrical heat shrinked the balls and no luck.
      I adjusted hatch stops and they do not budge. I can adjust it to the point where its difficult to close the hatch. Also, the latch striker appears to be in good condition with minimal wear marks (evidence that it shakes or rattles there).
      I dry lubed the hatch rubber seal, no difference...
      The only Thing I can think of, and this is a stretch for even me....The hatch hinges are being torqued when both struts are installed vs one strut installed via overcoming weight of the hatch itself and lifting up at the hinges over bumps.
      I have had to casualties, one 2mm scratch from a slipping screwdriver and one from the strut intself....I even wrapped the valley the struts recess into...Obvioiusly these are not visible but I know they are there........
      My dealer said they have no fix for the rattle. They could look at it, but beyond what I have already done at my shop, they wouldnt do much anything different.
      Sean
    2. Member plex03's Avatar
      Nov 10th, 2011
      Home of The NHRA U.S. Nationals
      '17 White CC R-Line Executive; '08 Honda Element
      09-06-2012 07:25 PM #2
      Quote Originally Posted by 81RabbitDieselTruck View Post
      Sean
      Sean,
      Many of us feel your pain. All I can do is share what I've done and that's it's cut down on the rattle SIGNIFICANTLY.
      • I cut a piece of a sponge koozie and tie wrapped it to the hatch post.
      • I flipped the struts around so that the bottom was up and the top was at the bottom. I kept them on their respective sides.
      • I've gotten into the habit of closing the truck with slightly more force than one would think would be needed. This seems to yield the best results
      In addition to your theory, I think also the bump stops on either side towards the bottom 1/3 of the hatch/body need adjusting but as my service guy mentioned, too much adjustment would affect the gaps between the body and the hatch. (The hatch would sit lower)
    3. 09-07-2012 01:37 AM #3
      Quote Originally Posted by plex03 View Post
      Sean,
      New struts and connectors comming by first of the year...all I know.
    4. Junior Member
      Oct 25th, 2011
      Cleveland, OH
      2012 Beetle in Toffee Brown
      09-07-2012 10:43 AM #4
      My whole dashboard and the driver's side door rattles & squeaks. Knocking on wood the hatch doesn't act up.
    5. Semi-n00b Enchanter1's Avatar
      Sep 4th, 2012
      N. California
      2013 SSN Turbo Whie/2002 Snap Orange 1.8 GLS
      09-07-2012 03:12 PM #5
      Spent 4 hours in car as a passenger yesterday and did not hear a creak or ratte from our 13 turbo. Very pleased so far
      2002 Orange Snap Beetle 1.8
      2013 White SSN 2.0 Turbo
    6. Member eunos94's Avatar
      Mar 17th, 2002
      Northeast Ohio
      Yellow 1970 Beetle & Yellow Rush 2012 Beetle 2.5L Tiptronic
      09-07-2012 03:22 PM #6
      I had a hatch rattle and no confirmation beep when locking. Soon realized that event though the hatch looked closed it required a "SLAM" to get it to close all the way. No more rattle!
    7. Junior Member
      Jul 17th, 2012
      Rhode Island
      Have had 1959, 1966, 1970 Beetles, 2001 Jetta TDI, 2006 New Beetle Convertible
      09-07-2012 05:37 PM #7
      Quote Originally Posted by eunos94 View Post
      My 2006 New Beetle convertible required a good slam also. Nothing really new for VW's.
      Jun 3rd, 2009
      Lyndhurst, NJ
      2012 FrankenBeetle
      09-07-2012 09:48 PM #8
      I discovered this same thing
      Sent from Tapatalk
      2012 FrankenBeetle.... My thread
    9. Member plex03's Avatar
      Nov 10th, 2011
      09-08-2012 03:35 AM #9
      One thing to keep in mind is that our "fixes" coincided with the weather turning warmer.
      I'm waiting to see if the metal of the hatch is susceptible to shrinkage as a result of colder weather.
      I took delivery of mine in January and it was unbearable for the first couple of months and as mentioned above DIY solutions started popping up just as the weather started to warm.
    10. Junior Member
      Feb 23rd, 2012
      Cassopolis, MI
      09-08-2012 01:20 PM #10
      My rattle is certainly not from an improperly closed hatch. I have confirmation horn beep. I can live with the hatch strut-less for the time being. I have tried everything. I also have sensitive ears...hell my 81 Rabbit has fewer rattles.
      Sean
    11. Member sonic_va's Avatar
      Jul 2nd, 2006
      Arlington, VA
      2015 Audi A3 1.8T
      09-11-2012 10:17 PM #11
      Weird, I swore I heard the rattle more as the summer Virginia heat crept in. Regardless, it's still driving me nuts!
    12. 09-12-2012 02:34 AM #12
      Y'all know it's a a fact that 1/3 of all V-Dubbers eventually end up in the funny house because of all the crack, snapple, pop.
      My VW is my percussion section... those guys at the Puebla plant must have hidden a can full of Mexican jumping beans.
    13. Member
      Jul 18th, 2012
      Everett, Wa
      2012 beetle 2.5
      09-12-2012 05:50 AM #13
      Quote Originally Posted by drtechy View Post
      Sent from Tapatalk
      I had that issue the other day after washing my car, I noticed it didn't beep when it locked, and when I drove to work it rattled a lot, just to come find out I didn't close it all the way
    14. 09-12-2012 11:26 AM #14
      Quote Originally Posted by jpitzer4 View Post
      Happens daily to me, just take a tad more to close the rear hatch. The horn beep is my friend when closing the rear hatch.
    15. Semi-n00b
      Oct 15th, 2012
      Tacoma, Washington
      2000 Dakota - 2013 Beetle/TDI
      08-07-2013 01:02 PM #15
      81RabbitDieselTruck:
      Did you ever get your rattle figured out? I have the exact same rattle ('13 Beetle TDI) and it quit the moment I removed the passenger side hatch strut.
    16. Junior Member
      Feb 23rd, 2012
      Cassopolis, MI
      08-10-2013 08:16 PM #16
      My hatch rattle was so persistent that I removed the passenger side strut. The dealer removed my headliner, the back hatch cover, the sunroof drains, and still couldnt fix it. In fact, their are more quirky rattles as a result from the dropped headliner now.
      I tried an aftermarket strut to replace it, same noise. I lubed the hatch seal, same noise. I tightened door stops, same noise. I greased the ungreased (from factory) balls for the strut, same nosie. In some rare cases, high temperature can either make it go away or get very loud its hit and miss.
      Good luck! (i just have gotten very good at holding the hatch open while loading groceries and such)
      Sean
    17. Member
      Nov 15th, 2012
      '12 beetle turbo
      08-10-2013 10:16 PM #17
      There is a plastic vent in the spare tire well directly underneath the hatch door. Could it possibly be those flaps bouncing open/close that you're hearing?
      Just a thought
    18. Junior Member
      Feb 23rd, 2012
      Cassopolis, MI
      08-11-2013 05:48 AM #18
      It has to be something that when under the correct sprung tension (ie the strut when installed), makes noise. When riding in the passenger rear seat, ive been able to rule out all surrounding plastics/fasteners/etc. The noise is 100% gone with strut removed--crazy. Ill just reinstall the strut when I trade it a few years from now. Im at peace for the most part unless someone has come up with a legit fix.
    19. Semi-n00b
      Aug 11th, 2013
      Minnesota
      2013 Beetle Turbo, 2012 Toyota Camry
      08-11-2013 09:16 AM #19
      have you pulled the trim off and looked at what the strut post is connected to? The issues are probably there since the rattle happens even with an different strut.
    20. Semi-n00b
      Oct 15th, 2012
      Tacoma, Washington
      08-14-2013 06:57 PM #20
      It has to be something that when under the correct sprung tension (ie the strut when installed), makes noise...The noise is 100% gone with strut removed--crazy. Ill just reinstall the strut when I trade it a few years from now. Im at peace for the most part unless someone has come up with a legit fix.
      Quote Originally Posted by savedbydave View Post
      These struts are pretty stiff (hatch is heavy) and my ticking sound suddenly appeared after many months of noise-free driving. I think maybe the ball-mount attachment point loosens up or perhaps has a fine crack that shows itself only when under the shear force of the strut being compressed. Speaking of which, knowing just how stiff the struts are, I thought that closing with only one strut attached might induce an abnormal twisting force to the hatch hinges. I decided to also remove the left side strut--hatch seems only marginally heavier...
    21. Junior Member
      Sep 2nd, 2013
      Tennessee
      2013 Beetle 2.5
      09-03-2013 12:01 AM #21
      I was noticing a persistent rattle noise almost like 2 pieces of styrofoam rubbing together coming from the rear drivers side of the hatch area. I had someone else drive while I say in the back seat - when I pushed on the trim above where the seatbelt comes out of (the piece on the car, not the seatbelt), the rattle went away.
      I opened the trunk & pulled gently on the trim & it came off pretty easily.
      Came to find out there are 3 metal clips that hold on the trim, 2 of which were not anchored to the trim. I pulled out the clips with pliers and slid them into the anchors, re-attached the piece & I have been rattle-free for several weeks!
      Makes me kind of mad it came like that from the factory, but am glad I no longer hear it.
      I hope you find your rattle whether it is from the same source or someplace different.
      Mine came & went with little rhyme or reason with different things I tried up to that point. I wish I could post a picture but not really sure how to do that from an ipad.
    22. Junior Member
      May 1st, 2013
      Copenhagen, Denmark
      2012 Beetle Turbo DSG "Herbie Edition"
      09-03-2013 04:01 PM #22
      Quote Originally Posted by mydogmandy1 View Post
      Definatly not the struts in my car, just tryed pulling them off still rattles. Will give this a go tomorrow.
    23. Junior Member
      Sep 2nd, 2013
      Tennessee
      2013 Beetle 2.5
      09-16-2013 02:05 AM #23
      Quote Originally Posted by jzv View Post
      Just wondering - did you find anything? Rattles can be frustrating.
    24. Junior Member
      May 1st, 2013
      Copenhagen, Denmark
      09-18-2013 01:22 PM #24
      NOPE Still nothing and its getting worse, my mechanic buddy told me i should try adjusting the hatch to make it close tighter it has like 3 spots where you do this but requires some tool that i dont have.
