Results 1 to 18 of 18
Thread: Aftermarket Cam lift: Is there more power to be had?
  1. 09-06-2012 05:39 PM #1
    If I'm not mistaken, Schrick, Techtonics, etc- they all offer their cams with 11mm of lift. What's the stock 3.2L lift and duration? What would happen with cams that were say, 13 or 14mm of lift?
  2. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-15-2012 04:43 PM #2
    You would coil bind the springs well before that much lift. If you changed the springs and retainers, you would still smack pistons.
    - Josh
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  3. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-16-2012 07:05 PM #3
    But if you are still interested, here are flow #s. 11mm lift is .43
    -Josh
  4. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-16-2012 07:06 PM #4
    And to make any power, we all need to stop breathing through this-
    -Josh
    Oct 26th, 2010
    Little ol UK
    05 MK1 3.3 TT V6T
    09-17-2012 03:46 AM #5
    As said..the runner will be your downfall.
    My head flows this at 10" WG..
    Steve
  6. Member Yak Meat's Avatar
    Sep 28th, 2011
    NH
    04 R32, 00 A4 1.8T, 88 911 Targa
    09-17-2012 11:30 AM #6
    Is the HPA new liquid cooled manifold any better flow wise?
    Garage Sale
    Nothing makes sense on this forum anymore. So I'm going to go masturbate.
  7. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-17-2012 09:11 PM #7
    I wouldn't even run one of those on a turbo..
    There are pictures somewhere showing the 'step-up' in the plenum.
    -Josh
  8. Member LR32's Avatar
    Aug 16th, 2008
    PORT CHESTER,NY
    04/VW/R32
    09-17-2012 11:45 PM #8
    EVERYDAY YOU LEARN SOMETHING NEW.
  9. Member Yak Meat's Avatar
    Sep 28th, 2011
    NH
    09-18-2012 09:33 AM #9
    Quote Originally Posted by PowerDubs View Post
    What do you mean?
    Garage Sale
  10. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-18-2012 02:53 PM #10
    The design of the plenum blocks off roughly 30% of the space directly after the TB.
    (At least from the picture here, on the internet, for what that is worth)
    They were working with packaging constraints to be sure. Just not my cup of tea.
    -Josh
  11. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 08:07 AM #11
    Someone should get flow numbers with the stock IM on there.
    Ps: Josh, tag!
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  12. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-19-2012 08:19 AM #12
    A flow bench would be a fun tool to have...
    As would a dyno..
    -Josh
  13. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 10:33 PM #13
    I keep meaning to make one.. someday.
    -Paul
  14. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    09-19-2012 11:19 PM #14
    Which.
    Both can, and have been home built before.
    - Josh
    -Josh
  15. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 11:43 PM #15
    Flow bench first, it would be easier.
    -Paul
  16. Member Rford71's Avatar
    Sep 1st, 2011
    Silver Spring, Maryland
    2004 Audi TT VR6 32L
    10-02-2012 09:53 AM #16
    I have Schrick cams 268/264 in my mk1 TT 3.2. I plan on turboing my car this winter should I leave the 268/264 in or go back to stock cams? What are the pros and cons?
    Thanks
    Robert
    MK1 TT 3.2 HPA Turbo
    Build thread http://forums.vwvortex.com/showthrea...PA-Turbo-build
    EVACunited
    Never believe what a deaf man said he heard.
  17. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-03-2012 08:22 PM #17
    Rob,
    Cams make pwoer everywhere in the RPM range and have no negatives with the turbo.
    The only reason to get rid of them is if you need to sell them for cash to fund the turbo kit.
    -Josh
  18. Member Rford71's Avatar
    Sep 1st, 2011
    10-03-2012 10:00 PM #18
    Ok,
    Thanks,
    Josh
    EVACunited
