Results 1 to 17 of 17
Thread: Solid steering rack mount!!
  1. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-07-2012 10:34 AM #1
    USRT just came out with a solid steering rack mount for the mk4 chassid looks pretty beefy . I have a poly one installed. Wondering if anyone has this installed yet and if it's that much of an upgrade over stock with a poly bushing ?
  2. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-07-2012 10:35 AM #2
  3. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    09-09-2012 09:09 AM #3
    Quote Originally Posted by racin2redline View Post
    Those are the Tyrolsport ones. Quality product. Do you track your car?
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  4. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-09-2012 11:26 PM #4
    Yeah realized they said tyrolsport after I looked at the picture and read more. No I dont track it... I do drive quite hard got a good bit of suspension work done though . I noticed a nice difference when installed the poly steering rack bushing with the defcon kit .tighter turn in response definitely more steering feel . I like the idea of the solid aluminum since there's no dampener between the rack and the subframe probably transmit more road feel to the steering wheel.
  5. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-09-2012 11:28 PM #5
    Plus I run no front swaybar so the tighter I get the front end the better!
  6. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    09-09-2012 11:35 PM #6
    Where are ya on LI ?
    bagsarefordeadhookers
    -TCC
  7. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-10-2012 07:50 AM #7
    Yeah long island
  8. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    09-10-2012 08:25 AM #8
    Is it for just better feel of the road ??? Looks cool but what will it inprove ???
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  9. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-10-2012 08:38 AM #9
    If you ever seen what the stock rack bushing looks like and feels like youd definitely understand better lol. And yes even just the cheap poly bushing makes a difference if nothing else it increases steering feel being that it's a much higher density than the soft spongy OEM one .
  10. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-10-2012 08:46 AM #10
    Basically if you ever came into a turn hot and you have the wheel turned hard and you feel hear the front tires start squealing and your holding the steering wheel with white knuckle grip and it feels like your petting a kitten... It's mostly because the front rack bushing is absorbing all that feedback by flexing and dampening everything the tires are trying to tell you
  11. 09-10-2012 03:29 PM #11
    I'm adding this to a much needed steering rack overhaul in my car. The rack also leaks when I put the fat 315 track tires on, a rebuilt is probably needed since holds fine with stock size tires and load.
    racin2redline, where in LI are you? DougLoBue and I were the only two active members here on the island, so it's always good to have new blood.
  12. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-10-2012 03:48 PM #12
    I'm in ronkonkoma
  13. 09-10-2012 04:38 PM #13
    I'm in ronkonkoma
    Cool! Doug is in Huntington and I'm in Westbury
  14. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-10-2012 04:44 PM #14
    Nicee I really don't see a lot of TTs around long island.
  15. Member winTTer's Avatar
    Jul 29th, 2004
    LI, NY & Miami
    02 TT ALMS
    09-11-2012 03:18 AM #15
    And I'm in Blue Point, but I'm not as active as I'd like to be
    The Artist formerly known as g60ingterbo.
  16. 09-13-2012 07:38 AM #16
    I installed the solid steering rack bracket in my gti and it made a nice difference in steering feel. definitely feel the road more, but without any vibration. i like it.
  17. Member racin2redline's Avatar
    Sep 24th, 2008
    Long Island NY
    audiTT225Q
    09-13-2012 11:59 AM #17
    I'll probably order it next time i drop the subframe for something. I'm thinking it will be a minimal difference over a poly bushing. To be honest I want it because it looks nicer
